Rotary Supra build
Results 1 to 18 of 18
Thread: Rotary Supra build
    Newbie
    Dec 2016
    Maryland
    2
    Rotary Supra build
    I have a 89 7M GE auto. I originally just wanted to do a manual trans swap but it's pretty hard to find a W58 ot R154 around where I live. So I've decided to go with a rotary swap instead of the usual uz jz ls swaps. I'm just not sure if I should go with a renesis REW or 20b
    SupraForums Member vovka's Avatar
    Sep 2005
    wa
    28
    338
    Wtf
    Nov 2014
    Bayside
    798
    Quote Originally Posted by vovka View Post
    Wtf
    I was thinking the same thing I just didn't want to be thto first response. I'm interested as to what people are gonna say here
  5. #4
    Mar 2007
    madison wisconsin
    208
    how about swapping in a cummins....assuming were just swapping for the sake of swapping here, not factoring in cost/hp/time etc....
    when i think nice light high revving rotary i don't think of swapping in a car that is 1000lbs heavier than the donor car lol
  6. #5
    Newbie
    Dec 2016
    Maryland
    2
    Well that was the idea do something outlandish and possibly insane and a cosmo it's all that much lighter
  7. #6
    Supra Tech Bmettie's Avatar
    Mar 2010
    Florida Brevard
    35
    1,716
    My vote is a suzuki G10T...maybe 2 of them?
    Click here to enlarge
    91 White Package Targa Turbo
  8. #7
    Nov 2014
    Bayside
    798
    Ls swap. Why not at this point
  9. #8
    Mar 2007
    madison wisconsin
    208
    Quote Originally Posted by Lxne View Post
    where do you live that you can't find used toyota parts, but CAN find mazda rotaries ? This is what i am not understanding.
  10. #9
    92 1JZ Supra Twin2Turbo's Avatar
    Mill Creek, Wa
    2,675
    Outlandish and insane would be the wrong words for this. Unpractical and disappointing would be better choices.
    Honestly though, do you even know what goes into making a rotary engine even remotely reliable much less powerful enough to make a 3400lb car remotely fun?
    The Renesis is an awful example of a rotary engine and is designed terribly. 40k miles on one and they're toast. 90% of the RX8s I see with over 50k will need a new engine. They cant keep compression for anything. Not to mention they're gutless to say the least. Rx chassis is considered a light and agile chassis as well and they are far from ballsy.
    I'm saying this from experience as I'm a certified Mazda technician, unless you have a very large amount of money and knowledge for a sophisticated rotary setup, id steer clear of them.
    92' High Rpm JZ
    |1JZ|AEM V.2|PTE 7068|Carrillo H Beams|Diamond Pistons|Shimless Buckets|Goleby Billet Tensioner|BRE FFIM|
    |2% OB Crank|BC272|Technico Gears|Remote EWP|Remote PS|Mechman ALT|Sumped|Meth Injected|Caged|
  11. #10
    Nov 2010
    Toronto
    32
    20B is one of the most expensive motors out there. the cost of a 20B you can buy 2 2jzs,or 3 1jzs. Plus most 20Bs require rebuilds, so 4 grand for amotor that most certainly requires a rebuild = Ls or JZ
  12. #11
    Super Moderator Wreckless's Avatar
    Albuquerque, NM
    9,020
    A 20B is fucking expensive. Rotaries are best in small cars with small engine bays that enjoy low curb weights. Rotaries are best owned by people that like wrenching a lot more than driving.
    If you want outlandish and unexplored territory, that's as easy as looking at what engines came in such a huge variety of 90's-00's sedans and other cars & trucks.
    My favorite two 'outlandish' swaps into a MK3 so far have been a BMW V12 from a 750IL sedan, and a 6BT Cummins.
    I'd love to see someone do a 3UR-FE 5.7L Tundra V8 or a 1FZ-FE 4.5L from an FZJ80 Land Cruiser.
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
    Click here to enlarge Originally Posted by KING Click here to enlarge
    Who would have ever thought.....the impact an automobile can make.....
  13. #12
    Apr 2004
    Auckland, New Zealand
    57
    1,528
    Don't play around with a 20B, go all the way and put in a 26B.
    http://www.themotorhood.com/themotor...-powered-lexus
    V8KILR - Precision 6870 AR 0.81, SPA manifold, 4" down/mid pipe, 3.5" AdrenalinR mufflers, Link G4, E85, 760whp @ 26psi (Dyno Torque), Getrag 6 spd, 10.94 @ 130 mph (19 psi low boost run as no cage).
    Owned and raced since Feb 1998.
    http://www.mkiv.co.nz
  14. #13
    Mill Creek, Wa
    2,675
    Quote Originally Posted by Wreckless View Post
    This was done a while ago, 1FZ with a 98mm turbo in a mk4. And it's AWD
    Quote Originally Posted by 360rwkw View Post
    Why stop there when you can go 6 rotor!
  15. #14
    =1/2π(√k/m) MK3Brent's Avatar
    Feb 2003
    Pittsboro NC
    9,713
    Subscribed.
    Let's see what you do.
  16. #15
    Logically a rotary is a bad decision... But for the sake of being different. I think it is a badass idea. 3 or 4 rotor with some boost and you are good to go! Good luck with the build man.
    "Never Drive Faster Than Your Guardian Angel Can Fly"
    89' Mk3 1Jz 432whp/332wtq @ 15lbs - AEM Infinity, R154, PTE 6262, 650cc Sard, 272 BC Cams Springs & Retainers, Shimless Buckets
  17. #16
    Oct 2015
    Wyoming
    188
    Late to the party, but I love driving a rotary. However, I'm not a huge fan of the sound, especially compared to some of the better sounding piston engines that are reasonably priced. Could a 20b make for a suitable engine for the Mk3? Sure, the Cosmo it came out of is a comparable car to the Mk3.
    That said, what do you want? Is it to go fast? Is it to be different? Is it the sound? The terrible fuel economy? The questionable reliability? What you want, is what you need to iron down before you commit to a build.
    I can say from experience that being different isn't always the best approach. I love my car, but if all I wanted was to go fast, a used C6 Z06 would have been my absolute best option. If you want to make a Mk3 fast for reasonable money, it's hard to beat an LS swap. Certainly compared to a rotary swap anyway...
    Either way, your car man, save up your money, and when you have a very healthy budget, do what feels right for you.
    -Brad
    87 Supra 1jz, monster in the making
    99 Miata DD, 46 Chevy Fleetmaster garage ornament
  18. #17
    Dec 2016
    Edmonton, AB
    18
    I know it's been done by a few before, but I would love to see this swap happening more often. I can only imagine how torquey these bastards are..
    I'm guessing the issue is the shortage of blocks in this part of the world?
  19. #18
    Oct 2015
    Wyoming
    188
    Quote Originally Posted by Boostfreak15 View Post
    Good alternative that would be readily available, at least in the US, would be the Atlas 4.5L from the Trailblazer. Even in NA form, it's pretty healthy if you let it breathe. Plus they're cheap as dirt in most cases.
  1. Rotary Engine on the supra?!
    By Bryanf89 in forum MKIII (1986.5-1992)
    Last Post: 06-11-2010, 04:51 PM
  2. Rotary Invasion
    By Raid3n in forum New Members Forum!
    Last Post: 12-06-2008, 07:10 PM
  3. Got my new rotary polisher!!
    By Kracin in forum Exterior , Interior, and Detailing
    Last Post: 07-17-2008, 06:22 PM
  4. rotary injectors?
    By garagefujimoto in forum 1JZ/2JZ Swap
    Last Post: 01-04-2005, 11:50 PM
