Dash panel restoration warning
Results 1 to 14 of 14
Thread: Dash panel restoration warning
    Aug 2010
    us
    37
    I was just wondering if there is a way to put a warning on the dash panel restoration DIY thread. It's 62 pages long that can't be posted to anymore and the first warnings come about 10 pages into it. With dash panels becoming discontinued, it would suck to hear about them being ruined by goo gone. I was super paranoid about doing mine and even tested samples of the plastic before I started.
    The dash is actually made up of abs and ppe plastics depending on the piece, so it's not a one size fits all, as some things eat abs that won't eat ppe. I used isopropyl alcohol and took my time with paper towels after letting it soak for a bit. Better safe than sorry at $1000+ for a set. Just a heads up.
    SF Contributing Member bitshftr's Avatar
    Jan 2009
    Raleigh, NC
    49
    2,403
    Agreed. Rubbing alcohol (or fingernail polish remover) and 00 steel wool is all that is necessary to get the OEM dash skin off the panels safely and quickly.
    WTB (02/16/2015): OEM glass break sensor/mic.
    1995 Supra NA, Baltic Blue, targa, TRD LSD, Recaro Sport seats, Cusco carbon fiber front/rear strut tower bars, 97+ front turns
    Passport hardwired, w/ amped remote speakers in seat harness slots
    Hidden/hardwired garage door opener w/ custom Supra dash button
    1995 Supra TT, BPU+, Baltic Blue, targa, TRD front/Cusco rear strut tower bars, 98 headlights w/ 6k HIDs, 97+ front turns, BNR turbos, Tial BOV, HKS Super Drager exhaust, SSR Professor SP1 wheels, Racelogic TC, VPC/GCC
    Passport hardwired
    Subtle white LED dash backlights
    Nov 2004
    Union City, CA
    992
    subd so i would remember to check it when it comes time to restore... and i also notice that threads that go into diy feels like it just disapears due to no traction in DIY section
    Reverend Hillclimb SlackJawOutlaw's Avatar
    Jul 2012
    Valhalla
    23
    2,591
    #00 steel wool and rubbing alcohol, done a shit ton of sets like this.
    Gets it to the smooth plastic surface, sand, paint. Done
    1994 Renaissance Red Original TT 6-Speed - Hillclimb Monster - Under the scalpel
    Feel free to ask or PM for anything and everything about Computer Hardware
    Aug 2010
    us
    37
    Quote Originally Posted by SlackJawOutlaw View Post
    Since you've done a bunch, what's the safest way to remove odo clear plastic without breaking? Thanks!
    Jul 2012
    Valhalla
    23
    2,591
    Quote Originally Posted by Golfer View Post
    Ive done masking and physically taking them off (they can brake due to age so caution). I like to take them off then glue them back on like stock, because masking is a pain due to the awkward shape. Xacto knife and some patience and you can mask them off. Just be careful not to cut the plastic (dont sneeze lol)
    Mar 2016
    Seattle
    38
    I used brake fluid on mine and it worked sweet. Safe on plastic too!
    Apr 2004
    Brooklyn, NY
    37
    629
    i masked off my odometer plastic with blue painters tape using an exacto knife but got a small amount of paint on it still. I ended up using a dremel and the wool polishing wheel with some meguiars plastic polish and took it right off.
    _____________________________________________
    1994 Toyota Supra
    1997 Lexus SC300 (sold)
    San Diego, CA
    97
    I used yellow Easy Off and that stuff just melted away when I rinsed it and gave a gentle rub with some 00 steel wool. This, of course, will rub off the odometer button labels, but that didn't bother as much as whatever god-awful easy scratch coating Toyota put on the dash.
    Jan 2009
    Raleigh, NC
    49
    2,403
    Quote Originally Posted by Mr. Sparkle View Post
    There's a solution to that too (replacing the labels).
    SupraForums Member silver94tt's Avatar
    San Francisco - Bay Area
    178
    Where can I buy the label?
    Quote Originally Posted by bitshftr View Post
    Jan 2009
    Raleigh, NC
    49
    2,403
    Quote Originally Posted by silver94tt View Post
    I used model train dry-apply labels to exactly match the OEM letters. I used masking tape to make a straight "base" line to get them all lined up. This is a tedious process, and you have to be damn near perfect to make them look right. After applying these letters, I put 2 more coats of the Valspar clear plastic primer over them. I did the same thing for the clock's "H", "M", and "00" labels.
    These were done with Woodland Scenics brand Model Graphics Dry Transfer Decals, item # MG738, which is "condensed gothic, R.R.-white". That sheet has 6 sizes of letters on it, and I used the second smallest of them. The sheet was $6.50 at my local hobby store. They are also available on Amazon. You can use a dull pencil to rub them off the sheet and onto your panel. Make sure to finish with at least 2 coats of some kind of clear spray to "lock" them in.
    For the clock ("H", "M", and "00" labels), I used item # DT575 from the same company.
    See if you can tell the difference:
    Original OEM panel:
    After...with my decals applied:
    San Diego, CA
    97
    Damn, son! That looks spot on! Thanks for the info! More weekend fun with the Supra coming up then.
    Wholesome creamy goodness Supraman16's Avatar
    Apr 2001
    Burbank, CA
    38
    632
    Anyone figure out a readily available spray paint that is similar to the gunmetal color of the 97-98 dash panels?
    2008 Star Fire Pearl Lexus IS-F
    1997 Custom Pearl White Supra TT BPU+++
  1. 93.5 - 96 Dash Panel Restoration
    By HamsMKIV in forum MKIV DIY / How-To Threads
    Last Post: 06-02-2017, 07:11 AM
  2. Dash panel restoration
    By adamthrowsroks in forum MKIV (1993-1998)
    Last Post: 08-07-2012, 11:06 AM
