New Wheel & Tire fitment guide.
Page 41 of 41 FirstFirst ... 31 32 33 34 35 36 37 38 39 40 41
Results 1,001 to 1,012 of 1012
Thread: New Wheel & Tire fitment guide.
  1. #1001
    Wheel Fitment Guru
    Up here
    3,650
    Quote Originally Posted by SVTBAIT View Post
    Hi guys, I've been doing lots of research, reading, measuring and converting. This is for a '95 Supra with stock rear suspension.
    I'm in the middle of re-hooping my rear wheels and I have it virtually figured out. I want to run it by Radride first to make sure this makes sense.
    I have two options:
    1) 19x10.5 +58
    -or-
    2) 19x11 + 51
    My questions are:
    A) Would there be any inner clearance issues running a wheel with 8.02" BS?
    B) How much of a pain would it be to get a 19x11 +51 to fit? Would it simply be rolling fenders? Or would it be far more involved than I am playing out in my head.
    I am not necessarily opposed to running a couple mm spacer if need be...
    Thank you for the help!
    Is this just for the rear fitment? I don't do back spacing because its not as accurate as offset in MM. I'm not sure what your starting point is but I'll reference flush fitment so your 10.5 +58 will be sunken into the fender by 23mm (terrible fitment). You'll have room on the inside for sure. No need to roll the fender.
    Your +51 will be sunken into the fender by 9mm. Again no need to roll the fender.
    Fitment is less than ideal.
    R.K.
  3. #1002
    Jul 2014
    Vancouver, B.C.
    9
    I'm kind of a noob with offsets and correct fitment for our cars. Have tein coils and fenders are stock. I am looking at the Work Meister M1's and dont know which offset to go with for flush fitment or at least as close to flush as possible. Any help would be appreciated, thanks in advance!
  4. #1003
    Wheel Fitment Guru
    Up here
    3,650
    Quote Originally Posted by jumpman08 View Post
    Which M1? There is the M1R and the M1 3 piece....
    R.K.
  5. #1004
    Jul 2014
    Vancouver, B.C.
    9
    The M1 3 piece
  6. #1005
    Wheel Fitment Guru
    Up here
    3,650
    The M1 3 piece
    Those wheels aren't supra friendly fitments. I can't get a size and offsets to work for flush or close to flush fitments.
    R.K.
  7. #1006
    Jul 2014
    Vancouver, B.C.
    9
    Thanks for looking appreciate the time and effort you put into this forum!
  8. #1007
    Mar 2010
    In the wind
    57
    I'm looking to buy some Work Meister S1:
    18x9.5 +29
    18x10.5 +49
    I know the front offset are a little on the aggresive side but will I be able to get away with a 255/35 and 295/30?
    Thanks in advance.
  9. #1008
    Wheel Fitment Guru
    Up here
    3,650
    Quote Originally Posted by SCPOW View Post
    18x9.5 +29
    18x10.5 +49
    Thanks in advance.
    The problem is this fitment will look terrible. The fronts will poke past the front fenders by 7 mm and the rear will be sunken into the fender by 14mm. Brutal fitment imo.
    R.K.
  10. #1009
    Mar 2010
    In the wind
    57
    Quote Originally Posted by Radride View Post
    R.K.
    If I use a bigger outer lip to get a 11" rim the offset should come down to 30ish. Would this be a better look?
  11. #1010
    Wheel Fitment Guru
    Up here
    3,650
    Wait, are you ordering these wheels new or bought a used set and trying to re-barrel them?
    R.K.
  12. #1011
    Mar 2010
    In the wind
    57
    R.K.
    Used and I will rebarrel the 10.5's to 11's if it'll be a better fit. If I rebarrel the 9.5's it'll be even lower in offset which is a no no. I don't want to rebarrel them to 9's either.
  13. #1012
    Wheel Fitment Guru
    Up here
    3,650
    If you're adding the 12mm bigger barrel on just the front, your offset will be +43 which will definitely be a better fit. You'll almost be flush with the fender.
    R.K.
  1. Wheel and tire fitment guide
    By Steve Jarvis in forum MKIV Technical
    Last Post: 07-08-2015, 11:02 AM
  2. Updated Wheel Fitment Guide!!!!
    By Steve Jarvis in forum MKIV FAQ
    Last Post: 06-27-2011, 05:20 AM
  3. Please update your wheel fitment guide!!!!
    By Steve Jarvis in forum MKIV (1993-1998)
    Last Post: 10-23-2002, 02:36 PM
  4. Wheel and tire fitment?
    By dmora in forum MKIV Technical
    Last Post: 04-11-2002, 10:13 PM
  5. Steve, fitment guide question
    By jakemarietta in forum MKIV Technical
    Last Post: 12-21-2001, 07:58 AM
