88 7m-gte ecu pinout needed!
+ Reply to Thread
Results 1 to 7 of 7
Thread: 88 7m-gte ecu pinout needed!
  1. #1
    SupraForums Member orvacian's Avatar
    Join Date
    May 2003
    Location
    Pomona, CA
    Age
    41
    Posts
    410
    I need a pinout diagram for the 87-88 turbo ecu. Anyone have one for me? My car will not flash anything on the check engine light when I jumper t and e1 but the timing does change and the check engine light comes on before I start the engine. WTF!
    Bigaaron from Driftmotion
    93 MK4 Supra with a 1.2JZ (it's not a typo)
    88 Supra with 1JZ-GTE.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Brian@7MPower
    it should be lit up when in accessory mode.
  4. #3
    Heavy Metal Momentum prsrcokr's Avatar
    Join Date
    May 2002
    Location
    VA
    Posts
    1,121
    If only you had specified that you would recieve email I could send one to you. I can't post it here since it is too big.
    Send me an email and I can send it out.
    Brian.Walker@ecolochem.com
    Brian 88T
    "Two things are infinite: the universe and human stupidity; and I'm not sure about the universe."
    -Albert Einstein
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    May 2003
    Location
    Pomona, CA
    Age
    41
    Posts
    410
    After finding the wire on the ecu that goes to the check engine light, I found that the ecu IS flashing codes, it's just not connected to the ce light on the dash. The light does not even go to the computer but somehow it stays on with accessory even the computer completely disconnected. But what would make it turn off after the engine starts? I guess I gotta pull the cluster and see what the hell is going on in there.
  7. #5
    greasemonkey williamb82's Avatar
    Join Date
    Aug 2002
    Location
    spring hill, florida
    Age
    35
    Posts
    3,104
    can you email the pin out to me? my email address is williamb82@yahoo.com thanks.
    william
  8. #6
    Just some guy Racefiend's Avatar
    Join Date
    Feb 2002
    Location
    Bay Area, CA
    Age
    39
    Posts
    1,919
    Well, I don't know if it's this way in your case, but I once rewired the check engine light on one of my cars to the check battery light so I could pass smog. I'd say trace the wire.
    Christian
  9. #7
    Join Date
    May 2003
    Location
    Pomona, CA
    Age
    41
    Posts
    410
    Unfortunately, that was over 6 months ago! It was fixed back then. Better late then never! LOL You were right, the previous owner jumpered the check engine light to the battery warning light, I just pulled the jumpers off and it worked great.
    You can see electrical schematics at:
    http://www.cygnusx1.net/supra/library/TSRM/d/D_03.html
    just click "next page" till you see the part you need
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
