2JZGTE 6 speed on 7MGTE?
+ Reply to Thread
Results 1 to 3 of 3
Thread: 2JZGTE 6 speed on 7MGTE?
  1. #1
    SupraForums Member
    Join Date
    Feb 2003
    Location
    VILLABE
    Posts
    857
    Is it possible to instal a 6 speed 2JZGTE on my MKIII please?
    Is there someone you've done this modification?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Boost Dealer
    Join Date
    Jan 2002
    Location
    Pittsboro, NC
    Age
    44
    Posts
    1,208
    The V160/V161 Getrag transmission (6 speed MKIV) does not
    have any bellhousing that mates to the 7M-GTE engine. So unless
    you have swapped to a 1JZ-GTE, you cannot mount this tranny
    to your stock engine without completely fabricating a new clutch
    bellhousing/flywheel/assembly. I'm sorry. If you have a 1JZ-GTE
    engine in you MKIII (which it says you don't), then you can bolt it
    right up using a 2JZ-GTE clutch and flywheel set. You would also
    need to make a custom driveshaft as well.
    Good luck.
    Jeff
  4. #3
    GreenPunkBlood
    jeff is exatly correct. The 6-speed wont connect to the 7m engine. if you are also swaping in a 1j or 2j, than it will fit. many say that the transmission wont fit in the tunnel, but thus is utter bull s**t. it does fit, the shifter will require some custom work, but thats it.
    you can find lots more info on this thread
    http://www.supraforums.com/showthrea...hreadid=105024
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
