car overheats when turned off. why?
+ Reply to Thread
Results 1 to 8 of 8
Thread: car overheats when turned off. why?
  1. #1
    Boost is my drug! DigitalDUST's Avatar
    Join Date
    Sep 2002
    Location
    Austin, Tx
    Age
    40
    Posts
    1,317
    ive got stock rad. all cleaned up flushed, stock fan, with cover, fan clutch works great, coolant never leaks, added royal purple coolant chiller whatever it is called, bypassed heater core, new toyota radiator cap. my car drives at normally 80-90*C sometimes peaks at 95 but it comes back down. when engine is turned off it jumps to 10*C which is 212*F (Red zone)
    when the car is running or not, ,temp already at 80-100*C there is no pressure in the hoses. you could still squeeze it but its hot! i checked for leaks. nothing. compression is wonderful. so theres no leak in head gasket (ive got MHG) im still puzzled.. dont know what is causing it.. ive tested the thermostat.. i even took it out and left it in and drilled a hole on thermostat... nothing changes the temp. any idea or suggestion?
    I was thinking of adding another cooler or get a truck sized radiator instead of buying a $500 fluidyne one. that way I can have more cooling capacity, or add more fans on the other side. etx.. any suggestion or ideas would be wonderful!
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Dr. Jeff Lange Jeff Lange's Avatar
    Join Date
    Aug 2003
    Location
    Canada
    Posts
    9,268
    Mainly because when you turn off the engine, the fan stops, so all the heat kinda builds. Hence the reason for Turbo Timers, it allows the engine to cool itself down for a couple minutes after you turn the car off.
  4. #3
    Dr Wheelspin Rh.D. Bishop92T's Avatar
    Join Date
    Apr 2002
    Location
    Red Stick Supras
    Age
    39
    Posts
    4,393
    Yup, anyone with an aftermarket temp gauge will see the car gets pretty f-n hot after you shut it off. There's nothing you can do about it short of installing an electric fan. All the MK3's do it. The trick is the engine itself doesn't produce anymore heat, it's just that the hot water naturally moves up where the temp sensors are so it appears the car is getting hotter.
    However you should have pressure in your hoses, if you don't then you have a problem somewhere. The Supra is a closed pressurized system and once it warms up it should have roughly 12psi of pressure throughout the system.
    I wouldn't worry about the temps though, +115C is where the damage starts happening. Mine runs roughly 90-95C without AC and almost 110C with the AC on in the heat of the day and heavy traffic.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Shawndude
    You should deffinately have pressure in the system. Either your radiator cap is not sealing properly, or you have a small leak somewhere.
    As far as the car heating up after shut down, every single engine does it. This is when the highest temperatures occur, but since it happens so slowly and nothing is moving, it doesn't really put any stress on the engine.
    It's nothing to worry about, and is not bad in itself.
  7. #5
    Join Date
    Sep 2002
    Location
    Austin, Tx
    Age
    40
    Posts
    1,317
    I doublechecked EVERY connection, hose and everything everywhere.. I cannot find a leak.. coolant stays the same level.. NEVER goes down or drains.. so obviously there isnt a leak.. but
    any other ideas about pressure? how can i solve this ??
  8. #6
    Shawndude
    Can you still squeeze the hose after shutting down a hot engine? It should be very firm to the touch.
    I would look more closely at the radiator cap. Inspect the rubber seals and valves/springs, and if you have another unit handy put that in to see what happens.
    Do you still have the stock Toyota radiator? If so, I remember reading on Reg Reimers site, how there are different radiator caps for different years of stock radiators, and are not interchangeable.
  9. #7
    Join Date
    Sep 2002
    Location
    Austin, Tx
    Age
    40
    Posts
    1,317
    yes i have stock radiator and i bought a new radiator cap from toyota... tell me how?
  10. #8
    Shawndude
    http://www.supras.com/pub/SONIC/MA70/RADCAPS.txt
    There are 3 styles of rad caps used on Supras, all three are unique in design and can not be mixed and matched. One of the designs is better than the others. You will have to use the correct cap for your type of radiator. I recently ran into a 1987 Supra Turbo with a rad from a 1990 or newer. The owner was trying to use the cap from the 87 and was driving the car with no pressure in the radiator.
    Style 1. Pn# 16401-36011 Rad Cap is the large round one used on all years MA-67's, it is also used on most older Toyota cars, trucks & fork lifts. This one is the best of all the types and will last much longer than the other two styles. They are used on all opper
    radiators only.
    Style 2. Pn# 16401-83010 Rad Cap is a small diameter cap used on 86.5 to 90 MA-70's, it has very small seal areas and is prone to early failure. My 1990 V6 4 runner is now on its 3rd one in 20,000 miles. I replace them every 24 months or 50,000 miles. If you have a 87 to 90 Supra and don't know if you have changed your rad cap, you need one, go and buy one today!
    Style 3. Pn# 16401-72090 Rad Cap is also a small diameter cap it is used on 1990 to 1996 Toyota Supras. This cap looks very much like style 2 but has redesigned seals, this style will last longer than style 2 but not as long as style 1. I would recommend changing it at the same intervals as the style 2 cap just to be safe.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
