Originally Posted by
MR.MECHANICAL
One solution for all (with the exception of the before mentioned oil drainage problem ??), BETTER CRANKCASE VENTILATION!! seals are seals not gaskets or o-rings, seals are not made to hold pressure they are just made to hold oil from leaking, think about how much pressure it takes to install the seal in the first place, not much, any supra with over 500hp in my opinion needs additional crankcase ventilation, equation is simple, more hp = higher cylinder pressures = more blow-by the pistons, the higher you go the more crankcase pressure produced, the extra pressure has to go somewhere and it aint though those tiny factory pcv valves, thats for sure,.
