+ Reply to Thread
Results 1 to 7 of 7
Thread: TRD LSD - fluid type?
  1. #1
    Bad Karma Supra
    Join Date
    May 2001
    Location
    Philly area....
    Posts
    3,752
    Hey Jeff -
    What type of fluid is recommended for the TRD LSD? Are we talking stock toyota differential fluid or is something else preferred?
    I'm assuming is takes the stock amount of fluid.
    Thanks!
    Jay
    377" V8 | 106mm | 2288hp | 1.32 60' | 5.35 @ 141 1/8
    J & E Performance | Drag Radial
    2012 Jaguar XKR | 2013 RR Evoque
  2. #2
    Newbie JWatson's Avatar
    Join Date
    Dec 2001
    Location
    Pole Position
    Posts
    2,187
    Toyota 75W140 at $11 per quart OR
    Royal Purple 75W90 at $8 per quart
    Also a bottle of GM LSD additive at $6 a bottle
    All in stock
    Jeff Watson
  3. #3
    Bad Karma Supra
    Join Date
    May 2001
    Location
    Philly area....
    Posts
    3,752
    Sounds good...which is preferred - the $3 difference isn't gonna sway me - just which do you recommend?
    Also, how does the GM LSD additive work in there?? What I mean is....pour in GM additive and fill the remaining volume w/ the differential fluid right?
    Just started driving the car and I notice some strange sounds at VERY low speed when I'm at full turn lock (forward or reverse)...I mean when I'm just creeping at full turn...say 1-3mph.
    Sounds like the rear is locking/unlocking or something...however at speed going around turns is perfect and smooth..same for all straight line action.
    I'm thinking something may be fishy in whatever fluid they used in there...at very least I want to put in what i KNOW is in there.
    I'll phone you in the AM - but wrap that stuff up - what's shipping to Marlton, NJ 08053? I'll take it.
    Jay
  4. #4
    Join Date
    Dec 2001
    Location
    Pole Position
    Posts
    2,187
    It sounds to me like
    1. The differential was not broken in correctly. Or is still being broken in, you might need to give it some time.
    2. It might be making noise because of no LSD additive
    Royal Purple
    Jeff
    1-800-327-2087
  5. #5
    Bad Karma Supra
    Join Date
    May 2001
    Location
    Philly area....
    Posts
    3,752
    Thanks Jeff - I'll shoot you a call in the AM.
    Actually, another friend of mine mentioned breaking in the diff - other than that no one has ever mentioned that?! I'd say it has ~200-250 miles on it, the guy who mentioned breaking it in...said hit a big parking lot and do some figure 8's for 15min's or so...
    I'm gonna swap the fluid and add the LSD additive...any other break-in procedures I should be looking at?
    Thanks!
    Jay
  6. #6
    Made in Stuttgart kevganzon's Avatar
    Join Date
    Aug 2004
    Location
    SoCal
    Age
    31
    Posts
    3,008
    what is the proper step by step procedure to break in right after installation? do figure 8's? how long and how many miles need to be driven before driving under heavy acceleration???
  7. #7
    SupraForums Member
    Join Date
    Jul 2008
    Location
    Earth
    Posts
    580
    Jeff,
    Does the additive need to be added to the royal purple oil too? I have heard some people act like the royal purple includes the additive.
    Also the Toyota oil you recommended had different numbers than the royal purple is this to break in the diff with?
    I was planning on using Valvoline 75w 90 to break it in with then switch to the same weight royal purple afterwards is this OK ??
    Is GM the only maker of the additive it needs?
    TIA,
    Anthony
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
