what makes a single turbo MKIV supra so fast??
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 62
Thread: what makes a single turbo MKIV supra so fast??
  1. #1
    GetSmackedSpili
    k im serious, im aware how fast these cars r, but i just dont get it.
    its a 3 liter engine, with one turbo, rear wheel drive car.
    can handle 800+ rwhp stock blah blah blah
    what i dont get is how, for example, a supercharged viper, or a mustang with a turbo on it making the same hp not able to beat it???
    is it the gearing that makes the supra so fast??
    im just curious
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    488ci V10 Power
    Join Date
    Sep 2001
    Location
    Mchenry County, IL
    Age
    39
    Posts
    2,555
    BIIIIIIG TURBO!
    1999 Viper GTS/ACR Edition - Silver/Blue Stripes (1 of 30 Built)
    Roe Supercharged, T&D Rockers, PBJ Intake, Borla Exhaust
    618 rwhp, 651 ft/lbs torque
    Click here to enlarge
    1998 Quicksilver Supra Turbo - 980rwhp / 746 tq
    Sound Performance Built and Tuned
    SOLD
  4. #3
    Acting my age MattOneDime's Avatar
    Join Date
    Feb 2003
    Location
    Portland, OR
    Age
    39
    Posts
    3,968
    Re: what makes a single turbo MKIV supra so fast??
    Driver!
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    GetSmackedSpili
    guys im serious
    im really curious to find out
    waht makes its so much better and give it the ability to walk from 10 second mustangs
  7. #5
    488ci V10 Power
    Join Date
    Sep 2001
    Location
    Mchenry County, IL
    Age
    39
    Posts
    2,555
    guys im serious
    I answered your question already! ONE BIG ASS TURBO!
  8. #6
    GetSmackedSpili
    sorry to bring the mustang example into this again
    but if u look at some of the turbo mustangs vs. supra vids that exist. u can see that the mustangs do have huge turbos, and produce same hp as the supra, with less lag, cuz of more displacement, but they still get raped
  9. #7
    Retired Super-Mod quick's Avatar
    Join Date
    Jun 2001
    Location
    Silicon Valley / Bay Area
    Posts
    13,330
    On the highway? Gearing.
  10. #8
    trilabs
    The modifications.
  11. #9
    How does my exhaust smell Bad4URHeart's Avatar
    Join Date
    Nov 2002
    Location
    Moreno Valley, CA
    Age
    42
    Posts
    1,014
    Gearing and rpm range. Most big singles have full boost from 4000-8500 rpms. Most v8 domestic have huge torque numbers but a much smaller HP band.
  12. #10
    SupraForums Member
    Join Date
    Oct 2003
    Location
    N/A
    Posts
    133
    Show us some of these videos of mustangs with huge turbos racing single turbo supras with the same horsepower. If you're watching a turbo mustang vs. single turbo supra and you think they're making equal horsepower, chances are you're wrong. Remember a supra can make 800+ RWHP on the stock block, crank, rods, and pistons. For a 5.0 mustang to make more than about 550 RWHP, you need to go spend atleast 1500 dollars on a new block, a grand on a new crank, a grand on some good rods, and 800 on some pistons. It's pretty cost prohibitive to make a ton of power. A lot of the races you see of supras are 750+ RWHP cars vs. stock block 306 mustangs with a vortech making 500 RWHP. Yes, it may be a 10-second mustang, but if it's only doing 125-130 MPH traps in the 1/4 it is going to get raped on the highway by a supra that may run low 11's, but it's doing it at 140 MPH. Put an 800 RWHP single turbo supra next to an 800 RWHP single turbo mustang next to each other, with similar weight, going from say a 40 dig, with the supra not spraying, the supra would have almost NO chance. The big-inch motor spools the turbo faster, so you make more low end torque and accelerate much harder, and you will have a much more broad powerband alltogether, so even though they may make equal peak RWHP the larger inch turbo motor will have a TON more area under the curve, a ton more average horsepower, and accelerate faster.
  13. #11
    oi Silver88Turbo's Avatar
    Join Date
    Mar 2003
    Location
    not worth mentioning
    Age
    32
    Posts
    3,796
  14. #12
    GetSmackedSpili
    turbofiveoh, good responce
    i think i understand it more
    so theoretically, if u had a 800rwhp single turbo mustang, with a better geared transmission, the 800rwhp single turbo supra would have no chance?? even though the supra has a broader rpm range?? allthough, it will be the lack of displacement holding it back
    guys, im just trying to learn, because it is unbalievable to watch these cars kill ferraris on the highway
  15. #13
    SupraForums Member
    Join Date
    Oct 2003
    Location
    N/A
    Posts
    133
    I hope my little quickie graph I made explains this a little bit better.
  16. #14
    Member Thingy kale's Avatar
    Join Date
    Aug 2001
    Location
    Kailua,HI/Corvallis,OR
    Posts
    1,922
    it's really hard to quantify this question with a single concise answer given all the variables, but basically with an equal peak horsepower, the higher displacement engine -generally- will have an advantage over a smaller one, however, it depends also on the gearing of both cars, available rpm range and area under the curve which determines what each car will do in each gear etc. also, since we are speaking of mustangs, they are -usually- equipped better for the launch which will nine times out of ten rocket them right out of the hole past -most- supras. it's not a good idea to assume much more past this, because there are simply too many variables in the equation.
    that said, if i had to call it, hp for hp i'd say an average 800hp mustang would walk a common 800hp supra out of the hole, and the supra would definitely, not have an easy time catching up, if at all.
  17. #15
    SupraForums Member silvino's Avatar
    Join Date
    Dec 2001
    Location
    San Jose, Ca.
    Age
    42
    Posts
    4,165
    I agree.
  18. #16
    GetSmackedSpili
    thanks fellas
    so those vidoes that "claim" a 800rwhp mustang vs. 800rwhp supra r not accurate
  19. #17
    SupraForums Member
    Join Date
    Feb 2003
    Location
    El Paso, TX
    Age
    33
    Posts
    687
    DON'T LISTEN TO THIS GUY, everyone knows it's our big ass wing.
    Yes my car is black. Yes thats my hood. It's shiny huh?
  20. #18
    -Getting High on KAI- TheDane's Avatar
    Join Date
    Jan 2003
    Location
    Denmark, The Real home of Vikings : )
    Age
    37
    Posts
    272
    NO..... DON`T LISTEN TO THIS GUY, everybody knows it`s our great looks and long hair who makes the Dawg so fast.
    Black MkIV 1993 Hardtop, Still Bpu
    Black MkIV 1994 T51r Kai, AEM SOLD
    Black Lightning 2002 APU++ 500rwhp+
    Black rs4 2001 stage 3 400awhp SOLD
    Now looking for a new baby
    Driving with OEM engine Mounts, is like fucking with a Darn condom!!! You can`t feel shit, when the girl is trying to Rock your world!!!
  21. #19
    TRNSFST 4G63's Avatar
    Join Date
    Jan 2002
    Location
    Midwest
    Age
    34
    Posts
    993
    NO NO..... DON'T LISTEN TO THIS GUY, everybody knows it's because for those 10 seconds or less, you're free.
    2JZ no shit!
    billy
    1993 Supra ~ Garrett, Full-Race, Motec, John Reed tuning
    3020lbs and going for 29XX = weight junkie
  22. #20
    Moderator MKIV Surfer's Avatar
    Join Date
    Jan 2003
    Location
    The Beach, FL
    Age
    32
    Posts
    827
    2JZ no shit!
    billy
    NO NO....DON'T LISTEN TO THIS GUY, everybody knows it's because we have 2 bottles.....two of the big ones.
    You've never surfed have you?
    Then you don't know the feeling.
    To know the feeling you have to experience it.
    To experience the feeling you have to surf.
    And, in turn, you surf for that feeling.
  23. #21
    SupraForums Member
    Join Date
    Dec 2001
    Location
    LA
    Age
    33
    Posts
    3,743
    the thing with that graph is this, most mustang and higher ci motors make there hp at lets say 5500rpm, but it fades off to redline. So they might make 500rwhp at 5500rpm, but it drops to 450rwhp at 6500rpms.
    With a big single supra, it only gets higher as the revs climb. And when your on a highway race, your always in that deep rev range making good power.
    Other things like gearing and such make a big part too.
  24. #22
    SupraForums Member MDoe8's Avatar
    Join Date
    Jul 2001
    Location
    Northern Colorado
    Posts
    1,231
    NO NO.....DON'T LISTEN TO THIS GUY, Everybody knows it's because the rotary gurder is attached to the canuter valve on our cars, which in turn recalibrates the articulation unit. DUH!
    -88 LS1 RX7
    *heads/cam/turbocharged/200-4r'd
  25. #23
    Join Date
    Jan 2002
    Location
    Midwest
    Age
    34
    Posts
    993
  26. #24
    SupraForums Member
    Join Date
    Oct 2003
    Location
    N/A
    Posts
    133
    If a motor is maxing out 500 RWHP @ 5500 RPM's, the person wouldn't spin the motor to 6500 RPM's
    EG: Take a look at the dyno sheet of this mustang. 19 pounds of boost from a T76 Q-trim, motor is only spinning to 5600 RPM's. If you raced this 864 RWHP car vs. 864 RWHP supra, what do you think is going to win? The supra keeps building power as the revs go, while the mustang has a powerband as flat as Saskatchewan and is pulling just as hard, but sooner in the rev range and it will have peak power longer; and therefore will accelerate quicker.
    Edit: Please don't take this the wrong way and flame me for being a troll or anything, as I do like supras and have owned a couple. My point was that more area under the curve means faster acceleration, and 99 times out of 100 a larger displacement motor is going to have more area under the curve than a small displacement motor, so given equal peak horsepower the bigger motor usually wins. Most highway races you see of big power supras are won because of a massive advantage in power and superior aerodynamics to your average mustang or camaro.
  27. #25
    Join Date
    Jun 2001
    Location
    Posts
    13,330
    ...and the fact that the Supra is geared to 154mph in it's 1:1 gear and 207mph in the overdrive gear (talking 6spds here).
    Don't underestimate the effect of gearing. You can make huge power but if you're geared to short or too wide you will lose on the highway.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
