+ Reply to Thread
Results 1 to 9 of 9
Thread: Stock head unit/radio installation
  1. #1
    SupraForums Member xbbsupra's Avatar
    Join Date
    Jan 2003
    Location
    Bay Area, CA
    Age
    28
    Posts
    1,306
    I want to sale my stock head unit because I installed an aftermarket one awhile ago. Well, I was trying to test the stock head unit and it wouldnt turn on. Would the stock amp need to be connected in order for the head unit to turn on? I tried hooking up the amp, but still nothing. Input anyone? Thanks in advance.
  2. #2
    SupraForums Member mkivbren's Avatar
    Join Date
    Nov 2003
    Location
    PA/MD
    Age
    34
    Posts
    1,267
    I have the same issue..
  3. #3
    Join Date
    Nov 2003
    Location
    PA/MD
    Age
    34
    Posts
    1,267
    ps, I tried to plug the amp back in too and still nothing. I have the dash entirely off, do you?
  4. #4
    Join Date
    Jan 2003
    Location
    Bay Area, CA
    Age
    28
    Posts
    1,306
    Yeah i do, i plugged the amp back in and still nothing!
  5. #5
    Formerly NA-TT Supra SONIC's Avatar
    Join Date
    Mar 2002
    Location
    Davis, CA
    Age
    31
    Posts
    1,607
    Did you install the head unit?
    Is the stock unit getting power, but no sound?
    Is the aftermarket unit still hooked up and working?
    --Justin
    93' Supra NA-TT (sold)
    96' Supra Black Hardtop (For Sale) --Pretty much stock 70k miles
    05' 636 (For Sale) -- Carbon Fiber Fairings|Smoked DB|Exhaust|Undertail|Steering Dampener|CF Sliders
  6. #6
    Join Date
    Jan 2003
    Location
    Bay Area, CA
    Age
    28
    Posts
    1,306
    the aftermarket head unit is unplugged. no power is going to stock deck whatsoever. but when i plug the cord into the aftermarket head unit, it powers fine.
  7. #7
    SupraForums Member
    Join Date
    Mar 2001
    Location
    Atlanta
    Posts
    301
    Depends on what harness you are using for your aftermarket unit. If you are using R6 (15 pin slots) for the aftermarket then you may have an issue, however if you are doing like most and using IH1 joining wire harness (10 pin slot harness on passenger side of tranny behind radio) for aftermarket radio, you need to reconnect the harness otherwise the amp and radio get no power.
    My guess is that the joining wire harness is disconnected and as a result the power for the amp and factory head unit "isn't plugged in."
    SP
  8. #8
    一番 エアロトツプER Ishii's Avatar
    Join Date
    Jan 2004
    Location
    Tokyo, Japan
    Posts
    1,022
    You need to actually bolt the radio back in to give it body ground, or take a wire and ground it and hold it up to the body of the radio. This is another reason why toyota went to a newer style connector with more pins so they could have body ground going straight into the radio
    Ishii
  9. #9
    Join Date
    Jan 2003
    Location
    Bay Area, CA
    Age
    28
    Posts
    1,306
    I ll try those.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
