+ Reply to Thread
Results 1 to 21 of 21
Thread: Just changed spark plugs car starts but smokes
  1. #1
    Bay Area Supras boyer's Avatar
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    Well after fouling my old plugs from excessive cranking, i replaced my spark plugs and started the car up on first crank without a problem, now smoke is coming out my exhaust and alot of smoke from the engine bay, near turbo when car is on, but when its off it comes out near front of the valve cover.. not sure ... anyone know what it could be?
    1988 Supra Turbo (Wrecked)
    1988 Honda Crx Si (daily driver)
  2. #2
    Z0rn
    Well, I had a smoking turbo problem, but it was just that the bolts holdiing the turbo to the motor were so loose I could move them by hand, so I tightened them and have been fine ever since. It could be the same for the valve covers, when I got my car and changed the spark plugs the valve cover bolts were so loose I could move them by hand as well. If that's the case was there alot of oil in the plug valley when you changed your spark plugs? If so, that's all the oil that fell into the plug holes and is now being burned off... what colour is the smoke?
  3. #3
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    black smoke, yeah there was oil in the valleys... so i guess its that? but would it be coming out the exhaust?
  4. #4
    Z0rn
    Yes it'll be coming out the exhaust because you have oil in the combustion chamber, so now oil is being ignited along with the gas so itl'll come out the exhaust. Tighten those valve covers, also when I changed my plugs I took an old turkey baster and sucked out all the oil cleaned everything up then put the plugs in. I has some black smoke for a little bit, but after a few days it went away. This is normal if it only happens for a day or so.
  5. #5
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    coo, i thought somthign was burning maybe i blew the gasket ..
  6. #6
    Z0rn
    Well, if the smoking started after a plug change I can't see it being a BHG, but if everything is loose like that... the smoking might be a warning sign. Have you done the head, atleast a re-tourque?
  7. #7
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    not yet, im going to though soon as i can get up to sacramento, and have talk with poi_dog.. he is gonna change my harness 2, also need to replace my valve cover gasket and gasket 3
  8. #8
    SupraForums Member
    Join Date
    Jul 2003
    Location
    GA
    Posts
    101
    you should of cleaned out your spark plug valley before you put new plugs in there!
    A turkey baster, brake cleaner and some rags is all you need.
    I figured you would of done these things before putting your motor in, what a genius....
  9. #9
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    done what things? i didnt put the engine in, i had someone put it in. who did a poor ass job and is being taken to court.
  10. #10
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    well car wont start again... after a day of it starting fine does the same thing, next thing im gonna change the wires.. and see what sup with that, if not could it be the coil pack?i notice that on one of them you cant see the metal inside so i took a screwdriver and scraped the crap out... but i dunno. where is the fuel pump located? hard to get to?
  11. #11
    Z0rn
    The fuel pump is in the gas tank, is it hard to get at? Well if you consider dropping your gas tank out easy, then no it's not. I would consider it a huge pain, especially if everything is corroded.
  12. #12
    Supra Stalker
    damn boyer i told you to get the starter replaced, and the smoke you should be normal, if its coming from the engine bay its most likely you need to tighten something down or a gasket is gone, look more closer once and while those problems should be easy to fix, btw maybe your timing is off or cps is broken.
  13. #13
    SupraForums Member
    Join Date
    Jul 2003
    Location
    GA
    Posts
    101
    Quit working on cars period!
  14. #14
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    time was set at 10 give or take 1 and the cps.. i dunno if its broken but.. thing is just giving me a shit load of problems
  15. #15
    1991 1JZ lagged's Avatar
    Join Date
    Apr 2004
    Location
    new york
    Age
    27
    Posts
    1,157
    posts like that really help ...
    let it just be a lesson learned about letting a garage work on your car. they will never love it as much as you do, and therefor they will never be as careful as you will. take the extra time to learn how to do it, instead of having to fix other peoples mistakes later.
  16. #16
    Supra Stalker
    was the timing set at 10 when the terminal connectors connected? if so did you also check if the timing should be at 12 after you remove it.
  17. #17
    SupraForums Member crazyone2044's Avatar
    Join Date
    Nov 2003
    Location
    Orange County
    Age
    30
    Posts
    839
    if oil is coming out from the valve cover , it can easy go down to a header which is very hot and burns oil.
    this what happend to me
    just change these damn gaskets 14$
  18. #18
    Join Date
    Feb 2004
    Location
    Oakland, Ca
    Age
    27
    Posts
    692
    that was fixed now it doesnt start up again, just keeps cranking but wont start it like putz like it wants to start up but then doesnt..
  19. #19
    Eclectic soup's Avatar
    Join Date
    Dec 2002
    Location
    vancouver
    Age
    29
    Posts
    1,136
    maybe you've drained your battery after all the tinkering. .
    charge it up and try again.
  20. #20
    Oldie but a Goodie
    Join Date
    Dec 2003
    Location
    Chicago burbs
    Age
    27
    Posts
    1,440
    And also.. i didn't see anyone else mentioning it but black smoke isn't caused by burning oil.. that'd be blue smoke. Black smoke from the exhaust usually means unburned fuel... soooo maybe you're not getting enough spark??
  21. #21
    Oldie but a Goodie
    Join Date
    Dec 2003
    Location
    Chicago burbs
    Age
    27
    Posts
    1,440
    Here's my best guess. When you scraped the crap out of the coil pack you shorted it out. This would cause some smoke from the engine. The coil pack not functioning properly would then cause the loss of spark and unburnt fuel exiting the exhaust system causing the black smoke out the tail pipe. Get those coil packs checked.
    Super Red 1992 Toyota Supra 5spd Hard Top Factory Moon Roof Shadow Grey (Black) Leather 86k Miles
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
