Car revs high before changing gears
+ Reply to Thread
Results 1 to 14 of 14
Thread: Car revs high before changing gears
  1. #1
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Las Vegas, NV
    Posts
    75
    I just got my car back today, it sat for six month. It is an 87T auto, I replaced the engine with a JDM 89+ 7mgte low mileage. Before the engine change the car changed gears fine, but now with the new engine it revs high before it changes gears. Is this an ECU problem, tranny problem (I'll check the tranny fluid when the car cools off). When I drive it sounds and feels like the car is in low gear. Can anyone give me some helpful information?
    Thanks.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    sorcereur
    You check tranny fluid while the car is Hot, not cool.
    And, what happens when you lay off the gas while it's shifting? Not that you're supposed to, but does it still rev up?
  4. #3
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Las Vegas, NV
    Posts
    75
    In Las Vegas even letting the car sit for a little while it's still hot. The car doesn't rev high when I lay off the gas. The rpm seems normal when I'm not stepping on the gas.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member Kroze's Avatar
    Join Date
    May 2002
    Location
    usa
    Posts
    1,181
    your tranny is dyiing!!
  7. #5
    Brian@7MPower
    Sounds like slizzipage.
  8. #6
    bigdough666
    Yes sir, sounds like what my tranny was doin when it was on its last leg. I had a tranny guy tell me that the seals inside the tranny were old and worn down. When the tranny was cold it would shift like shit, but when it heated up it was better, but still shitty. The estimate was like $1200 to fix it, so I paid $450 and got a full R-154 5-speed swap.
  9. #7
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Las Vegas, NV
    Posts
    75
    I checked the tranny fluid while it was hot and while it was cold the next day it is way past the full mark. I think they accidently over filled it. The mechanic said there may have been tranny fluid that thickened and didn't drain, and once the car got hot it added to the new fluid. The car sat for six months.
  10. #8
    27836-12121 ARTSUPRA's Avatar
    Join Date
    Jan 2002
    Location
    Vancouver BC Canada
    Age
    26
    Posts
    1,739
    do 5spd swap ,don't bother with auto.
    Give the auto tranny to you grandpa he'll put it into a good use
  11. #9
    Republican Ckanderson's Avatar
    Join Date
    Jun 2003
    Location
    Southbay.
    Age
    33
    Posts
    8,421
    the car has to be running to check tranny fluid...
  12. #10
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Las Vegas, NV
    Posts
    75
    I know that the car has to warm up and be in neutral when you check the tranny fluid. I have the owners manual and a repair manual, but there are also marks for checking a cold transmission it's in the owners manual. The fluid is way past full with a hot running engine and cold engine.
  13. #11
    Join Date
    Jun 2003
    Location
    Southbay.
    Age
    33
    Posts
    8,421
    oh... heh, nm ill shut up!
  14. #12
    Some Guy With A Supra BoostMan03's Avatar
    Join Date
    Apr 2003
    Location
    Sacramento California
    Age
    32
    Posts
    378
    Can having too much tranny fluid present problems??
  15. #13
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Las Vegas, NV
    Posts
    75
    According to the repair manual too much fluid can cause, slippage, overheating, and damage tranny seals.
  16. #14
    SupraForums Member crafty's Avatar
    Join Date
    Jul 2002
    Location
    Wisconsin
    Posts
    314
    An over filled tranny will cause the fluid to start foaming. You can't pump foam well, so your pressure drops. Not enough pressure to keep the clutches applied and you will get slipage which will create heat which is the biggest killer of the tranny.
    Pull the drain plug and take out a quart and recheck it. Hopefully it not to late.
    HTH Dennis
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
