What is the "SST 09278-54012"
+ Reply to Thread
Results 1 to 4 of 4
Thread: What is the "SST 09278-54012"
  1. #1
    White89Turbo
    As its mentioned in the TSRM, is this tool of some sort have a better description?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    boost freak drjonez's Avatar
    Join Date
    Sep 2001
    Location
    The Cheese State
    Age
    10
    Posts
    11,270
    hmmmmmmmmmmmm....mayhaps letting us know where it is referenced would help....
  4. #3
    92 TURBO
    Join Date
    Apr 2004
    Location
    Wallingford, CT
    Posts
    998
    SST 09278-54012 is listed as a drive shaft holding tool. It's used to hold the camshaft pulleys from turning when either removing or installing the pulley bolts. It's also used to hold the power steering pump pulley when removing/installing the pulley nut.
    SST- special service tool.
  5. #4
    Supra Fan
    Join Date
    Aug 2002
    Location
    Philly
    Age
    35
    Posts
    4,115
    your manual should have a section in the back explaining each sst.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
