#2
Re: ETTC Switch Wired into MVP (Fields) Harness Instructions
braddman said:
very very nice article. I wish everything has a DIY explaination like that. It would be so much easier.
How about putting the meaning of the short-terms you use. Not everybody is a supra owner and might not know what the terms mean.
VSV
IACV
EGCV
#3
I agree, great write-up this should be put in the faq so I can use it in the near future.
#4
No problem, it will be moved to the faq shortly, and when I write part 2 I will improve this part as well with more terminology.
#5
Again this is very good information. This needs to be on MKIV.com if it isn't.
#6
That is a great writeup indeed.
:beerchug:
Steve T.
#7
:beerchug:
Steve T.
Steve can you copy this over to FAQ please! Thanks.
