What are all the things that can cause a rough idle?
+ Reply to Thread
Results 1 to 12 of 12
Thread: What are all the things that can cause a rough idle?
  1. #1
    Dr. Jeff Lange Jeff Lange's Avatar
    Join Date
    Aug 2003
    Location
    Canada
    Posts
    9,246
    I'm just curious about this, what are the most common things to check for if you have a rough idle? I know for a fact I have a busted injector seal on my #1 injector, I'm just wondering if there's anything else I could check for while I'm at it.
    Though I didn't have a rough idle before and AFAIK the only thing that has changed since then is the busted injector seal, but whatever, lol, this could be a good informational thread anyways.
    Couple things I've checked so far, and I've heard to check:
    - ISC
    - TPS
    - Timing
    - Vac/Boost leaks (I replaced a busted accordian hose and a busted PCV hose)
    - Injector seals
    Anything else?
    Also, when I start the car cold, it idles at about 1300-1500rpm for a few minutes until it warms up then drops down to a normal idle, what could be causing this?
    Thanks for the input/help guys, hopefully it'll be a thread that can be searched for later.
    Click here to enlarge
    2011 Lexus IS350 Obsidian "F-Sport 6MT" with LSD
    1986 AE86 Corolla GT-S Supercharged
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    desufnoC myMUSICveins's Avatar
    Join Date
    Jun 2002
    Location
    Lost
    Age
    34
    Posts
    1,841
    I'd say this is normal to an extent. My idle has been off for quite some time now, but it IS supposed to idle high and lower as the engine warms up.
    Im not positive, but I think thats what the ISC is doing. As long as it doesnt idle higher than 1500 when cold, it should be ok.
    87 Supra (Sold)
    87 Supra (Sold)
    89T Supra (Sold)
    2002 5spd IS300 LSD 1JZ-GTE VVT-i
  4. #3
    BOOST87
    I think most car idles like that.. Goes high then lowers when the car starts to warm up..
  5. #4
    Join Date
    Aug 2003
    Location
    Canada
    Posts
    9,246
    Yeah I know that, but mine does it for longer than most, and a lot longer than it used to.
  6. #5
    SupraForums Member
    Join Date
    Jul 2003
    Location
    Toronto
    Age
    33
    Posts
    1,418
    try the cold start time switch that controls the cold start injector, i think it's mounted on the "christmas tree".
    also, clean your throttle body thoroughly
  7. #6
    wastegate hose is pulled chevyeater-on-sf's Avatar
    Join Date
    Jun 2003
    Location
    NJ/FL
    Age
    41
    Posts
    4,586
    Is the engine taking longer to warm up? I believe the idle speed is ramped inversely with the coolant temperature.
    Other rough idle causes:
    Low compression
    Worn/dirty spark plugs
    Faulty spark plug cables
    Faulty ignition coil(s) or circuitry
    Faulty main injectors or circuitry
    Faulty cold start injector or circuitry
    Faulty O2 sensor or circuitry (believe it or not!)
    Incorrect camshaft timing
    Clogged exhaust
    That is about all I can think of right now, besides the things you mentioned Jeff. You sort of mentioned false air readings with the accordian hose so I left that off my list.
  8. #7
    Join Date
    Aug 2003
    Location
    Canada
    Posts
    9,246
    Well I'm pretty sure I already know what's causing my rough idle, just that one injector ring, but just thought I'd ask, everything else seems to be ok, and my idle isn't really that bad, just a little bit rough because it's sitting at about 500-600rpm instead of the usual 750-800rpm.
  9. #8
    londonsupra
    check the timing belt..
    I was having a rough idle for about 2 weeks.. than suddendly my timing belt blew up.. now its fine and doesnt rough idle anymore..
  10. #9
    SupraForums Member
    Join Date
    Sep 2003
    Location
    Greshem, Oregon
    Age
    28
    Posts
    625
    kinda stupid but I've never seen any say it before... How do you check the TPS, ISC, and O2.. I believe I may have a problem with one of them. My idle is iratic from 600rpm-750rpm(watching avc-r) even when its warm.
    Ben K. 89 supra
    "That could, that can, that will!"
  11. #10
    DDDDUUUUUBBBBBZZZZZZZZ suprafly1986's Avatar
    Join Date
    Nov 2003
    Location
    Charlottesville, VA
    Posts
    2,022
    Water temp sensor, sticky throttle linkage, can also cause.
    The Money Pits:
    '88 Supra Turbo A/T
    '99 Mustang Cobra Ragtop
    '06 Cadillac Seville STS
    '95 Suzuki DR650-SES
  12. #11
    bruggles
    egr is what my problem was. Also clean the throttle body it is easy and cant hurt.
  13. #12
    JalopySiR
    My brother's car idled like crap until we pulled a few EGR specific vaccum hoses. Happened alot on old LT1 Caprices.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
