+ Reply to Thread
Page 11 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11
Results 251 to 263 of 263
Thread: Tech Article: Brad's Engine Detail Secrets!
  1. #251
    Join Date
    Nov 2010
    Location
    SoCAl
    Posts
    50
    Thanks brad! Ended up using the method on my car, and works great!!! Going to use this method on some of my friends dirtier engine bays!
  2. #252
    Slow2JZ
    Join Date
    Oct 2011
    Location
    SoCal
    Age
    28
    Posts
    236
    WTF! That one before and after pic.! Going from Oh..sorry my hood won't open to LOOK AT THIS! Thanks for the tips!!
    -97 Supra TT Targa 6spd 39k- Twin Garrett GT2876R's w/ ProEFI-850hp@25psi-
  3. #253
    Join Date
    Nov 2011
    Location
    Concord NC
    Posts
    45
    I don't use aerosol products or simple green but I think mine cleaned up pretty good. Nice write up!
  4. #254
    SupraForums Member
    Join Date
    Feb 2012
    Location
    Houston, Texas
    Posts
    365
    Great method with nice end result!
  5. #255
    Gavrilo Petrovich dima126's Avatar
    Join Date
    Dec 2003
    Location
    Da Ladna
    Age
    25
    Posts
    1,640
    Aren't you worried about water getting in the spark plug valley when you're rinsing off the engine bay? I use an almost exact method for plenty of engines, but always worried about the 2jz because I have heard horror stories about water being left in the spark plug valley and making the engine run like shit afterwards.
    "Unless you're the god damn Batman, and you're not, don't wrap/paint your car in flat black." - John79
  6. #256
    SupraForums Member
    Join Date
    Jan 2011
    Location
    Chicago
    Age
    29
    Posts
    176
    ^+1... That happened to my na supra...motor sits on an angle and water got in the spark plug area , resulted in $$ to clean it out...i never washed an engine again! Lol
    1994 Toyota Supra TT BPU+
  7. #257
    SupraForums Member
    Join Date
    Jun 2011
    Location
    Georgia
    Posts
    281
    From what I have read, water only gets in the GE spark plug valley that easy... It happened to me and my car was not running right for two days, nothing a air compressor and the right blow nozzle can't take care of. My car is currently in a build stage so before we finish the NA-T setup I am going to use this detail process, thanks Brad.
  8. #258
    SupraForums Member SilverAWD's Avatar
    Join Date
    Oct 2006
    Location
    Columbia, SC
    Posts
    808
    So tempted to try this...but so afraid I'm gonna fuck shit up on my new baby
    03 Evo (sold)
    05 Ruckus - GY6 swap
    98 4runner - the rolling stone
    94 Supra - Single
  9. #259
    Join Date
    May 2009
    Location
    Long Beach, CA
    Posts
    58
    This thread is awesome!!!!!!!
  10. #260
    Join Date
    Apr 2009
    Location
    cyprus
    Posts
    1
    best thread ever,thank you so much...i wash'd my N/A today,i just put a towel on the spark plugs and plastic bag on my filter and start cleaning,but i was really carefully coz of first time.the car is running perfect...but my problem is that 2 screws have loose from the back of the top of the engine and oil came out and didn't clean well from down and still make some smoke,i guess ill have to take it to a pro..
    cheers
    steve
  11. #261
    Join Date
    Jan 2012
    Location
    FS
    Age
    24
    Posts
    8
    Isn't it dangerous for engine to wash with water?
  12. #262
    Join Date
    Nov 2011
    Location
    Concord NC
    Posts
    45
    No really dangerous...I own a detail shop and have cleaned engines on a daily basis for 15 years. On straight sixes you just need to not drench the spark plug galley because water will get under the seal and gather at the plug base. This will cause the car to miss. If you get water in there you can pull the plug wire and roll up a piece of news print to wick the moisture out or blow it with compressed air. Using the head of a shop vac as a blower will work as well. The only engines in my experience to have issues with cleaning are Volks Wagon's and GT 3000's. The main thing is to not run a wet engine in an effort to try to dry it out...alway's find the moisture and remove it. Here's my engine bay cleaned with all purpose and a pressure washer with a little dressing to set it off.
    1989 Turbo Targa 5 spd
  13. #263
    Join Date
    Jan 2012
    Location
    ATHENS, AL
    Posts
    34
    Great write up. I have always used WD-40 after I use the air to dry it. Let it sit for about 30 minutes, then dry off excess if any. This also displaces majority of the water in places it shouldn't have to begin with.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
