what do bad wheel bearings sound like or just brakes?
+ Reply to Thread
Results 1 to 20 of 20
Thread: what do bad wheel bearings sound like or just brakes?
  1. #1
    Nottin' like boost... 99YellowStang's Avatar
    Join Date
    Nov 2001
    Location
    Tampa/Gainesville
    Age
    33
    Posts
    1,870
    When I coast by another car, or close to a building i notice my car makes a shimming noise of like metal on metal, everytime the wheel turns it makes the noise, its not that loud, but still annoying knowing its there, i first noticed it a while ago when I had new brake pads put in, did they not move the piston on the caliper back far enough and its just lightly rubbing or does it sound liek a bad wheel bearing? Is the brake pad lightly rubbing in one spot possible because for stock pads they put out a HUGE amount of brake dust, more then normal I assume.
    Click here to enlarge
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Join Date
    Nov 2001
    Location
    Tampa/Gainesville
    Age
    33
    Posts
    1,870
    ttt
  4. #3
    i lift trucks domoMKIV's Avatar
    Join Date
    Nov 2001
    Location
    Oviedo, FL
    Age
    34
    Posts
    1,377
    when the bearings on my gf's civic went out (rear passenger side ONLY).....it made a really loud whirring noise, very similar to road noise you get from the tires but MUCH louder. it was enough to give me a horrible headache when on the freeway at 65-80.
    so that might rule out a bad wheel bearing but im not POSITIVE, just sharing some info as far as noises are concerned.
  5. #4
    GReddySetGO
    Do you hear it even at low speed? Like MKIV said, wheel bearings make a whining type of noise, and usually not audible until at higher speeds. It sounds like something is touching your rotor.
  6. #5
    SupraForums Member
    Join Date
    Nov 2003
    Location
    East Coast
    Posts
    274
    Some bad wheel bearings on my friends car sounded like a small grinding noise and eventually got louder as he drove the vehicle. Finally coming to the point of not driving the car.. Until he got them fixed.
    See you on the street.
    GGP MKIV 6spd
  7. #6
    Mechanical Engineer Supra-Holic's Avatar
    Join Date
    Jul 2001
    Location
    Dallas, Texas
    Posts
    347
    I have something similar going on. Its coming from my driver side rear. Replacing the wheel bearing myself not to long ago. I know thats not it.
    When my wheel bearing went out. It started off as a soft grinding until it go so bad that the whole car was shaking, snap, crackle, pop style.
    94' 6-speed TT Black on Black "Wingless"
    Inventor of the "Space Helicopter"
  8. #7
    SupraForums Member WhiteBlazze's Avatar
    Join Date
    Mar 2004
    Location
    Woodbridge, VA
    Age
    35
    Posts
    2,568
    If your wheel bearings get that bad....I hope you also replace the wheel hubs!!
  9. #8
    SupraForums Member rex03's Avatar
    Join Date
    Mar 2002
    Location
    San Antonio, Texas
    Age
    43
    Posts
    2,000
    I wondered the same thing. I know of 2 MKIVs here that do it....the MKIVs here that dont do it are all n/as...dont know if this has anything to do with it, but sort of a strange coincidence, isnt it? Well if you figure it out, let us know.....its sort of a "binding" noise when you turn the wheel, right? Dont have to be moving or anything...right?
  10. #9
    EchoDeDupra Supradedupra's Avatar
    Join Date
    Oct 2003
    Location
    Tallahassee/Jacksonville/SFL
    Age
    29
    Posts
    4,121
    ive replaced two wheel bearings...
    and one of the wheels i replaced it on is making that noise again
    fucking shops
    It's not what you have; it's what you know.
    Click here to enlarge Originally Posted by exvelocity Click here to enlarge
    Actually this car did catch fire at my shop,at that time it had more leaks than a torn off roof in a hurricane
  11. #10
    Demented Motorsports
    Join Date
    Jul 2004
    Location
    Cajun Country, LA
    Age
    35
    Posts
    343
    Wheel Bearings
    For all of you changing wheel bearings. CLOSELY inspect the Hubs (part with lug studs in them) for wear. If your wheel bearings are making noise, its probably gotten to your hubs too. I would not even do another wheel bearing job without getting new hubs for my car after doing my MR2 wheel bearings 2 times in 3 months. DO NOT PRESS BAD HUBS INTO NEW BEARINGS it won't last at all.
    And yes, it sounds like brakes grinding.
    Patrick
    Patrick Harris
    1991 Nissan Skyline R32 GTR
    1991 MR2 Turbo Road Race car and GT2 2010 Champion
    1994 Toyota Supra 6-Speed Twin-Turbo Hardtop - Baltic Blue SOLD
  12. #11
    Join Date
    Jul 2001
    Location
    Dallas, Texas
    Posts
    347
    Yeah, I had to replace that(hub) also. As soon as the e-brake came off the hub basically fell out. The whole process was a PITA, no power tools.
  13. #12
    Join Date
    Oct 2003
    Location
    Age
    29
    Posts
    4,121
    both times i have replaced the hubs with the bearings
  14. #13
    SupraForums Member Ryan P's Avatar
    Join Date
    Jun 2001
    Location
    Akron, Oh
    Posts
    2,070
    When my drivers side wheel bearing went bad, it made almost no noise on the highway. The only symptom it had at early stages was a clicking noise with each revolution of the wheel at very low speeds. I couldn't even hear it until I was next to a building or something. I jacked the car up and found a tiny bit of paly on the rear wheel. Despite catching the problem this early, the hub was still unusable. I wouldn't even take a chance replacing the bearing without replacing the hub. Make sure you order all new dust and grease seals as well. I think the total in parts was around $180 or somethiing like that from Jay Marks. Toyota will charge $500 for this job MINIMUM. It's not too bad to do, the ball joints are kind of a pain to pop off the spindle, and you need a press to press out the old bearing and hub. Other than that, it's straight forward.
    Phantom Black Evo X GSR (sold)
    2006 Mitsubishi EVO IX MR (sold)
  15. #14
    AEM Nutkase BLKMGK's Avatar
    Join Date
    Nov 2001
    Location
    Manassas VA
    Posts
    3,863
    Aw geez, guess who needs to do this! Driver's side rear hub has been making a little noise, thought it was a brake dragging. Checked it out, found nothing, and then when putting the wheel back on I saw it shift. Uh oh! Nut on the hub was finger tight, I'm quite sure it was due to the bearing being TOAST.
    I'm not sure I've got time to do this. I have a lift and a press but this is my daily driver! I'll be calling the local stealer tomorrow to see what they have to say for an estimate. Fun fun. If I had the parts on hand I might consider doing it but....
    Anyone got part numbers for the hub and bearings?
    10.8@129mph ET Streets race gas
    11.02@129mph Nitto DRs pump gas
    71GTQ (was T-78 when times run), AEM, 4ROW, 4inch exhaust, my tuning :) 623RWHP on pump with T78 1.7BAR, 719RWHP on the 71GTQ - 2.3BAR, mine and JS's tuning. Sadly the car may be totalled - stay tuned.
    E-mailing me is almost always better than PMs :(
  16. #15
    THE NOTORIOUS BHP Raretoy's Avatar
    Join Date
    May 2002
    Location
    Stroked and I'm Stoked!
    Posts
    4,520
    i noticed bad brakes dont change noises on hard turns. A bad bearing will really act up if you turn hard.
  17. #16
    SupraForums Member
    Join Date
    Jan 2002
    Location
    South Florida
    Age
    36
    Posts
    253
    When my driver rear wheel bearing went out, on right turns where load was placed on that side the noises would get louder and vice versa for left turns.
  18. #17
    Digital DNA
    Join Date
    Aug 2002
    Location
    Valrico, FL
    Age
    32
    Posts
    353
    It could possibly be your rotor(s) dragging, especially if they are warped. Could be the brake piston not being flushed back in properly as well. Your issue doesn't sound like a wheel bearing problem. Most likely a brake issue of some sort.
    Damn! I can't believe people would go see something so sad and vulgar. I mean, a scene full of savage barking and hair raising screams is not for me either.
    Sincerely,
    Ashlee Simpson
    "Metalingus"- Alter Bridge
    I've been defeated and brought down
    Dropped to my knees when hope ran out
    The time has come to change my ways
    On this day I clearly see everything has come to life
    A bitter place and a broken dream
    And we'll leave it all, leave it all behind
    On this day its so real to me
    Everything has come to life
    Another chance to chase a dream
    Another chance to feel
    Chance to feel alive
    1997 Mitsubishi Eclipse GS-T
    North Star White
    Mods= A'PEXi Power Intake, HKS SSQBOV, T-25 Compressor, Boost Control Solenoid Restriction Removal.
  19. #18
    Join Date
    Nov 2001
    Location
    Tampa/Gainesville
    Age
    33
    Posts
    1,870
    yeah thats what i get for going to "just brakes"
  20. #19
    4 T's and an X T AND X's Avatar
    Join Date
    Nov 2003
    Location
    Socal
    Posts
    2,058
    Check the tabs on your brake shims. They are a little warning system designed to make a sound when your brake pad get low.
  21. #20
    Republican Ckanderson's Avatar
    Join Date
    Jun 2003
    Location
    Southbay.
    Age
    33
    Posts
    8,421
    OK, let me educate ya...
    about pistons not being pushed back far enough.....
    rotors arnt cut flat. they have what is called lateral runnout. in effect it is kinda wavy (not some thing that you can see) this is done to effectivly push the pad away from the surface of the rotor, when your not braking, so the pads dont drag. when your stering wheel wobbles when you brake, that is because you have excessive lateral runnout, meaning your rotors are wavier then they should be. or "warped"
    I bet its just the sound of your pads dragging a little. ask if they resurfaced the rotors. also, wheel bearing noise is more promenent when your turning, or putting load on the wheel on the freeway. i.e. changing lanes. it will make a very distinct wirring noise. sounds nothing like brakes. the bad wheel is the ouside one. (you turn left, the right wheel bearing is fucked)
    now next time, do the brakes yourself!
    My HID GB has been shut down by SF staff due to a site sponsor confliction. Everyone who paid will be getting their kits without a question. Please PM me for more information.
    All kits ARE shipped.
    [/IMG]
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
