Do aftermarket pulleys add any power?
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 40
Thread: Do aftermarket pulleys add any power?
  1. #1
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,660
    Do they? Does anybody have a dyno sheet to prove it? I have read not to use the crank pulley, so does that affect power gains in any way? Any insight will be appreciated!
    Thanks,
    Jason
    1994 Red/Black TT
    86K miles
    Roller...6 speed swap coming soon
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Newbie michaelvanle's Avatar
    Join Date
    May 2003
    Location
    South Jersey
    Posts
    11,219
    I guess if it doesn't there's no point of "upgrading" them.
  4. #3
    Bullseye Dealer mk4umha's Avatar
    Join Date
    Sep 2001
    Location
    Round Rock
    Posts
    1,136
    you replace the OEM crank pulley with the Boostlogic one because the OEM is weak and prone to cracking with the higher torque motors.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    way over budget lowbudgettarga's Avatar
    Join Date
    Jun 2004
    Location
    Bellingham, WA
    Age
    31
    Posts
    664
    no aftermarket pulley will ever ADD horsepower, it will just take less power to run.
  7. #5
    Inline for the win Suprafied's Avatar
    Join Date
    Dec 2001
    Location
    Dublin, OH
    Posts
    4,734
    Correction,
    Aftermarket "LIGHTENED" pulleys will recover lost horsepower due less rotational mass. Basically every pound of rotation mass is equvilent to 10 pounds dry mass. This will require less output being taken from the crank to run these accessories. Underdrive pulleys are usually made of aluminum versus the default steel type of pulleys. Unless the O.E. pulley weighs less, you will make more HP. Also, a simple example of this has to do with why people are generally worried about how much their wheels weigh in regards to racing / dynoing. Lighter wheels will make your car faster for sure.
    Also, never install an underdrive crank pulley on a 2JZ-GTE engine. You will no longer have a harmonic balancer unless you go with the Boostlogic or Titan dampener. However, both of these units are not underdrive.
    Do more with less......
    '95 Toyota Supra TT 6-spd Targa JRR/MoTeC M130 , AP 3.4L, SP F1, Tilton, Precision, Recaro, HKS ID, Boostlogic, PHR, ETS....
    My Build Thread
    '16 Lexus IS350 AWD F-Sport
    '09 Dodge Ram 3500 QCLB Dually 6.7 CTD EFI Live by Anarchy
    '05 Toyota Camry XLE
  8. #6
    Lost in Dawg-land greenstreak's Avatar
    Join Date
    Jul 2001
    Location
    Dublin, Pa
    Age
    40
    Posts
    652
    Most of the power recovery is from the lightweight and underdriven crank pulley though. With just accessories done I wouldn't expect much.
    For the power I wouldn't risk an undampened crank pulley like most aftermarket units are.
  9. #7
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,660
    So, pretty much pulley's on a Supra are a useless waste of money? I think I will just take the money and put it toward a stall/built tranny.
    Off topic, but if I have a set of Bogarts that weigh 8lbs against the stock polished that weigh ~24lbs, I will save 16lbs which equals 160lbs dry mass? So, that would be roughly .16 in thoery off of my ET right? Since for every 100lbs you remove, you gain 1/10th in ET.
    Thanks,
    Jason
  10. #8
    Join Date
    Jul 2001
    Location
    Dublin, Pa
    Age
    40
    Posts
    652
    That's an awful lot of bench racing. :P
  11. #9
    SupraForums Member WhiteBlazze's Avatar
    Join Date
    Mar 2004
    Location
    Woodbridge, VA
    Age
    36
    Posts
    2,561
    The Unorthodox is NOT an under drive crank pulley like most other aftermarket cranks are. It is also lighter than the stock pulley.
    Most people go for the Boostlogic or Titan crank because they are SFI approved and fully dampened, yet keeping the stock size. This is the best route to go.
    To get more HP from replacing pulleys, weight is key. Less weight = more HP.
    Simple as that really.
  12. #10
    SupraForums Member crossways's Avatar
    Join Date
    Nov 2003
    Location
    New Jersey
    Posts
    1,541
    Sorry to resurrect this thread, but I was just wondering if anyone has ever documented (dynoed) gains with these lightened and/or overdrive accessory pulleys (power steering, alternator, waterpump). I know the N/A Supra guys claim gains of 5-8rwhp, so logic would conclude that the pulleys should gain slightly more on TT models. Does anyone have any hard evidence?
  13. #11
    Join Date
    Nov 2003
    Location
    New Jersey
    Posts
    1,541
    I did a little bit of research and it seems that most of the aftermarket pulley sets are of the same diameter as the OEM ones so the only difference is that they are made of 6061-T6 aluminum as opposed to steel. Aluminum is approximately 1/3 as dense as steel, so assuming a similar mass and the fact that the aftermarket pulleys weigh about 1 lb, that would mean that the stock pulleys weigh about 3 lbs.
    The weights listed here are in line with my estimates:
    http://www.moreboost.org/weights.htm
    0.50 pulley - alternator
    1.34 pulley - power steering
    1.00 pulley - waterpump
    0.20 pulley - Unorthodox alternator
    0.80 pulley - Unorthodox power steering
    0.50 pulley - Unorthodox waterpump
    So in other words we have about 2 lbs savings in rotational weight.
    I believe rotational weight is worth about 2x-3x static weight, so let's be generous and say 3x, netting a 3x 2 lbs = 6lbs advantage or about a 0.5 hp gain.
    I think I'll pass.
    Also, I found this quite amusing:
    http://www.unorthodoxracing.com/inst.../04060120_.pdf
    "The maximum HP gains will occur in 5-7 days of installation, once the computer recalibrates to take advantage of the engines lighter rotational weight."
  14. #12
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Chicago Burbs,IL
    Posts
    1,421
    Quote Originally Posted by WhiteBlazze
    The boostlogic is stock size, but I believe the Titan is actually larger, overdriving the accessories. I'm really surprised no one makes underdrive accessory pulleys for these cars, I know with every car I've ever put pulleys on it's made a difference.
  15. #13
    you should expect bout 1 rwhp gain from a set of lightweight pullies... plus they look trick!
  16. #14
    I Solve Problems lis2k's Avatar
    Join Date
    Sep 2004
    Location
    NYC to NC
    Age
    36
    Posts
    4,289
    I bought pullies that are the same size as stock but lighter and they are polished. I bought them because my stock pullies look terrible, the paint is flaking on them and i wanted to avoid a crack in the future. I also figured if it made any performance gain, then thats only a bonus. By the way, they were $59 shipped and nice quality. I was referred to them by another member here. Use stock size belt as well.
  17. #15
    Join Date
    Jan 2011
    Location
    pakistan
    Posts
    1
    i always like to read some good and informative
    blogs and this blog is also so good and helpful.
    thanks for taking time to discus this topic..
    Sticker Printing
  18. #16
    Join Date
    Apr 2008
    Location
    USA
    Posts
    2,625
    Wtf!!!!!!!!!!!! Bot alert
  19. #17
    Glad To Be Back 2cars=4Turbos's Avatar
    Join Date
    Jun 2009
    Location
    Sarasota, FL
    Posts
    1,340
    Hadji's are taking over SupraForums.....I heard Bin Laden's hideout is somewhere in OT
    1995 USDM Supra TT 6 Speed 3L2
    1993 JDM Supra TT GZ Auto hardtop 1993 #575 built 8800kms -in storage in Japan til 2018
    Click here to enlarge
    [SIZE="1"]
    www.facebook.com/SupraMarket
    TRD Steering Wheels always in Stock!!
  20. #18
    SupraForums Member Yogujuhere's Avatar
    Join Date
    Aug 2010
    Location
    Long Island, NY
    Posts
    697
    UR pulleys are lightened pulleys. Don't really do thaaaaat much. More for bling really. Thats why i like them LOLZ
  21. #19
    Soon to be Single (^_^)
    Join Date
    Mar 2009
    Location
    Waipahu, HI
    Posts
    174
    Quote Originally Posted by kingston123 View Post
    Sticker Printing
    I agree. I speak bad english too, so I can relate. Sticker Printing? Are you an authrozied vendor?! Heh.
    Anyway, I just picked up a set of UR Pulleys not too long ago from MVP. Hopefully, I'll have them installed soon. It's minus the crank pulley, though.
    94' Toyota Supra TT / 6SPD "Lord Vader"
    07' Suzuki SX4 / Auto
  22. #20
    SupraForums Member DenverSupra's Avatar
    Join Date
    Dec 2009
    Location
    Denver, CO
    Age
    31
    Posts
    214
    I recently upgraded my all pulleys, except the crank, for a better look under the hood. I didn't feel a difference in the car's drivability, but I was also not expecting a power gain. Pulleys won't add a substantial amount of power to the point where the driver will feel the difference. You MAY see a difference on the dyno..... but that's still a maybe.
    1994 Supra T88H, 719rwhp SOLD
    2011 BMW 335i X-drive w/ sport package
    2003 Cadillac Escalade
    FORMER RIDES:
    1995 Supra NA-T, 428rwhp
    1994 Supra T66, 618rwhp
    1994 R32 Skyline, 390awhp
    1995 300ZX TT, 509rwhp
  23. #21
    Busy Breeding Balls... J. Cooper's Avatar
    Join Date
    Apr 2008
    Location
    29 Palms, CA
    Posts
    1,681
    I have the unorthodox lightweight pullies. They are much lighter than stock, and are the same size as stock. There are dynos out there that prove small power gains. Ill look around for them.
    - Jeremy
    On the hunt...
  24. #22
    The Caravan Aficionado GodeepGTS11's Avatar
    Join Date
    Feb 2008
    Location
    Everywhere but Nowhere all at Once
    Posts
    4,948
    just won a set of the driftmotion pullies, and i had my car on the dyno before , so hopefully we can get some performance numbers, if any lol
  25. #23
    ELITECUSTOMBODY exvelocity's Avatar
    Join Date
    Dec 2002
    Location
    Jacksonville Florida
    Posts
    6,552
    I had UR pullies for years on my APU car,when my stock crank pulley cracked,I swapped it out with UR crank pulley ,I immediately felt the throttle being more responsive,so I'd imagine there were some power gains,BTW it's been about 2 years,still running fine,drive it everyday
    _Stefan B
    elite custom body + paint
    Click here to enlargeClick here to enlargedo what's right,not what's easy
    Need professional advice or opinion on body/paint/assembly or cosmetic related issues?Just ask.
    http://www.facebook.com/ELITECUSTOMBODY
  26. #24
    Join Date
    Jan 2011
    Location
    united states
    Posts
    1
    This is one of the best platform that provides us an opportunity to discuss valuable topics. thanks for this service. I want to discuss about auto industry. Because it very important to know about it. It is our requirement. I hope other people will also take part in it.
    software download
  27. #25
    SupraForums Member
    Join Date
    Jun 2002
    Location
    Auckland
    Age
    34
    Posts
    146
    Ahaha, those replies make reading random threads worthwhile.
    I got a driftmotion set and am in the process of installing them, once I get this stupid powersteering pump rebuilt, which would go a lot easier if the oil seal would co-operate and come out.
    Weighed a couple while I was at it so might as well post kg weights since I couldn't be bothered converting the lb weights.
    Stock PS pulley 6.08kg
    Alloy 3.4kg
    Stock water pump 4.57kg
    Alloy 2.23kg
    Alternator ??
    Alloy 0.99kg
    I had another reason for buying the driftmotion ones. Suspected a bent PS pulley, OEM is around $200NZD, $58 for a 3 piece alloy set, works well for me.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
