Smells like battery acid?!
+ Reply to Thread
Results 1 to 12 of 12
Thread: Smells like battery acid?!
  1. #1
    StoplightWarrior
    I have never noticed this smell before, but today I had to swing by my gf's house to pick something up. I parked in her driveway and left the car running...came back about a minute later and when I hopped in the car I noticed a fairly strong scent like battery acid. I put the windows down and drove on to the next destination, about a mile away. When I got there I popped the hood and checked the battery and it looked fine, and I couldnt smell anything either. Was/is this anything to worry about?? What could have caused that smell beside the battery??
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    NA-T T61 SupaSupraSE's Avatar
    Join Date
    Apr 2004
    Location
    C-Bus OH
    Posts
    1,988
    Is there anything moist or dripping anywhere? If there was a leak fo some sort you probably would be able to detect if visually.
  4. #3
    StoplightWarrior
    No, no leaks...the car has no detectable problems at all (besides the damn hatch rattle...grrrr)...this battery acid smell was the first thing I've noticed in the time I've had the car. Like I said though, you cant smell it while the car is in motion.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    Apr 2004
    Location
    C-Bus OH
    Posts
    1,988
    What octane fuel do you run? Im just throwing out ideas, but maybe if your running a low octane fuel your just noticing the smell as you walk in/out of your car.
  7. #5
    When cars say, "NO MORE!" SJ's Avatar
    Join Date
    Apr 2002
    Location
    PA
    Age
    34
    Posts
    2,112
    correct me if im wrong but battery acid is sulfuric acid which is odorless?
  8. #6
    SupraForums Member
    Join Date
    May 2001
    Location
    NJ/NY
    Posts
    2,944
    I don't think there is any smell to battery acid. There definitely is a taste though. YUCK!
  9. #7
    StoplightWarrior
    could be....I run 91octane w/stock boost cause it's hard to find 93 anywhere in CA
  10. #8
    BlueMako
    From what I've smelled(recently blown up batteries, leaking batteries, long destroyed batteries, car batteries in general), battery acid smells nothing like any fuel I've ever smelled, it smells like sulfur
  11. #9
    StoplightWarrior
    ok, well this didnt smell like sulfer...it smelled like, hmm...how can I describe it...metallic...kinda like a sharp metallic smell, maybe...
    fvck, anyone have any clue? I'll go run my car later in my garage and I'll sniff the turbos, the battery, and the exhaust...
    lol
  12. #10
    feeding your habit 98mkiv's Avatar
    Join Date
    Feb 2004
    Location
    San Diego, CA
    Age
    45
    Posts
    4,014
    I'd say run the car for a good hour in the garage. Keep the garage windows and door shut so you can really concentrate the smell.
    Make sure you stay with the car so you can see any leaks....
  13. #11
    Mid-life Realization! banton's Avatar
    Join Date
    Jun 2002
    Location
    Illinois
    Age
    11
    Posts
    2,530
    Maybe my smeller doesn't work too good, but burned radiator fluid can have a metalic smell to me.
    Brad
  14. #12
    Supra Member mkivsoopra's Avatar
    Join Date
    Sep 2001
    Location
    Bay Area, Ca
    Posts
    2,275
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
