Properly gapping new NGK Iridium Spark Plugs
+ Reply to Thread
Results 1 to 16 of 16
Thread: Properly gapping new NGK Iridium Spark Plugs
  1. #1
    SupraForums Member YoudLse's Avatar
    Join Date
    Dec 2003
    Location
    Florida
    Posts
    97
    I just got my new NGK Iridium spark plugs today from MVP...
    What gap would you go with for the following mods... Intake, Catback, Test Pipe, 11.5 PSI? I know that .032 is stock, what would you recommend?
    Also, how do you gap your plugs accurately with one of those crappy disc shaped tools? Is there something better? I would like to have accuracy to the millimeter... My idle has been crap ever since the engine swap about 6 months ago. I have tried swapping the coil pack and wires from my other Supra.. Please help.
    Current Mods:
    Supra 1 - 1989 5 Speed
    JDM 7MGTE
    ARP Head Bolts
    Rebuilt turbo from Majestic Turbo with the 60-1 wheel
    K&N FIPK
    Fidanza flywheel and new Exedy clutch and pressure plate
    SupraSport Upper Intercooler HardPipes
    Greddy Type S BOV
    BIC DDP
    Test Pipe
    Megan Racing 3 inch catback exhaust
    Joe P MBC
    935 Motorsports front strut tower bar
    Eibach lowering springs
    LM1 Wideband
    Supra2 - 1989 Automatic
    Status - BHG Repair
    My Gallery: http://www.mysupragallery.com
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Dec 2004
    Location
    Lex KY
    Posts
    197
    I would leave the plugs alone, unless the ones in there now are bad.
    Same with the gap.
    I use a wire type gap adjuster good accuracy.
    So the idle is bad. Is the idle speed too slow? Does it rise and fall? Any more info would help.
  4. #3
    Join Date
    Dec 2003
    Location
    Florida
    Posts
    97
    Same with the gap.
    Yes. The idle is low, around 500 RPM, after it warms up. Also, I can hear the car constantly misfiring about once or twice every second.
    With regard to the new plugs, are you saying I should just leave it at whatever the new plugs are already gapped at? According to the disc guage, they are at about .037 gap right now.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    92 TURBO
    Join Date
    Apr 2004
    Location
    Wallingford, CT
    Posts
    998
    Re: Properly gapping new NGK Iridium Spark Plugs
    I was told you can't nor should you try to gap Iridium plugs. They are suppose to last like 250k miles. Electrode made from material from meoterites <[sp]
  7. #5
    Red Rider turbo_smallblockchevy's Avatar
    Join Date
    Nov 2003
    Location
    martin county, fl
    Age
    31
    Posts
    975
    the electrode is very fine and need not be gapped i was told. if it is missing check your plug wires and make shur there was no oil in the plug galley when you did the job as that seems to interfear with operation
    iridium is found here on earth also
    Treasure coast imports!
  8. #6
    Supra Fan
    Join Date
    Aug 2002
    Location
    Philly
    Age
    36
    Posts
    4,115
    My NGK Iridium XI spark plugs came out the box gapped at .028. I re- gapped them to .031. I havent used them yet so i dont know how they will work out.
  9. #7
    wastegate hose is pulled chevyeater-on-sf's Avatar
    Join Date
    Jun 2003
    Location
    NJ/FL
    Age
    42
    Posts
    4,586
    The round wire type is the best gapping tool. Just don't bust the center electrode off. Every spark plug should be gapped before installation, no matter what it is made out of, the spark still has to jump the gap. Gap them to the stock setting, should be fine for your mods.
  10. #8
    SupraForums Member
    Join Date
    Dec 2004
    Location
    Lex KY
    Posts
    197
    ngk plugs are pre gapped
  11. #9
    Professional White Man hoser813's Avatar
    Join Date
    Apr 2004
    Location
    Williamsburg, VA
    Posts
    2,674
    Id say you might want to invest in a feeler gauge. They arent that expensive, and it will help you with many different engine clearance issues, and also spark plug gap. And I hear that copper plugs are better for FI than iriduim.
  12. #10
    Join Date
    Dec 2003
    Location
    Florida
    Posts
    97
    Thank you all for your replies. I really appreciate them.
    Some feedback on the NGK Iridium's...
    I installed them using the factory pre-gapped setting of .037, according to my disc-shaped gapping tool. I torqued each plug to approx. 13 ft/lbs using a torque wrench.
    Before installation, I had constant misfiring and stalling after decellerating for a stop light.
    After the install, the idle was smooth as butter and I felt more power from the car (to be expected with better ignition).
    I would highly recommend the NGK Iridiums to any MKIII Supra owner, if you want an awesome plug. I have tried the Autolite 3923 Copper plugs gapped to .032, and didn't have great success with them.
    And thank you MVP for quick shipping!
  13. #11
    Supra Fan
    Join Date
    Aug 2002
    Location
    Philly
    Age
    36
    Posts
    4,115
    Yes but not pre-gapped to the right specifications
    you need to gap them to .031
    - 1990 Black turbo/targa/5spd SOLD(May 2006)
    - 1990 White turbo/hardtop/5spd R.I.P (2001)
  14. #12
    SupraForums Member sneakypete's Avatar
    Join Date
    Feb 2003
    Location
    Belleville/Newark NJ
    Age
    32
    Posts
    132
    You arent supposed to gap platinum or iridium plugs. They should be purchased pre-gapped. You risk breaking off the side electrode when you gap platinum or iridium. Thats the last thing you would want in your combustion chamber.
    -pete
  15. #13
    Supra Fan
    Join Date
    Aug 2002
    Location
    Philly
    Age
    36
    Posts
    4,115
    -pete
    Dont know who told you that . Like I said 2 replies ago: I measured my ngk iridium xi's out the box and they were gapped at .028. thats why i gapped them to stock(.031).
  16. #14
    SupraForums Member
    Join Date
    Dec 2004
    Location
    Lex KY
    Posts
    197
    NGK plugs are pregapped, just buy the correct ones and your set...
  17. #15
    United States of America isnms's Avatar
    Join Date
    Jul 2003
    Location
    Oklahoma
    Age
    51
    Posts
    1,469
    Its recommended Not to regap iridiums.
    http://www.spark-plugs.co.uk/pages/specials/Denso.htm
    center of the page - "**DO NOT REGAP IRIDIUM SPARK PLUGS!!** "
  18. #16
    Stormcock approves Shlongor's Avatar
    Join Date
    Jan 2004
    Location
    Wheeling, IL
    Age
    31
    Posts
    1,859
    Yeah, trust the pregap. Just like those NGK plugs I bought that required something like a 13/16 socket, which as you may know, will never fit down in the spark plug holes...
    03 Z06
    Sorry guys :( I had to!
    Next Mod: Money
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
