small hole in my transmission?
+ Reply to Thread
Results 1 to 9 of 9
Thread: small hole in my transmission?
  1. #1
    SupraForums Member
    Join Date
    Apr 2004
    Location
    Frederick, MD
    Posts
    3,825
    I went under my car today and theres a small hole in the bottom of my manual transmission its about the size of a dime and I didnt know if I should just fill it up with jb weld or leave it alone. Any ideas on what I should do?
    14 Mustang
    14 Explorer XLT
    96 RHD Supra hardtop built 3.0
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Apr 2004
    Location
    Frederick, MD
    Posts
    3,825
    any one? its a hole is it good or bad? do i have to fix it? is there suppost to be some kind of liquid in the manual transmission?
  4. #3
    Digital Dreamer Stretch's Avatar
    Join Date
    Aug 2004
    Location
    Toronto, Ontario
    Posts
    898
    I think I had a similar thing in my auto. I found someone had stuffed some blue gummy crap in it to plug it, but fluid was slowly slowly leaking out. I could see the trails. I'm not sure if it's meant to be there but I think if it looks kinda like it wasn't stamped out my the factory, then chances are it's a problem.
    eric
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    HKS T51R toyota_supra_1988's Avatar
    Join Date
    Dec 2003
    Location
    Surrey B.C
    Age
    29
    Posts
    2,732
    of course theres sappose to be "liquid in the transmission" its called transmission fluid or gear oil....is anything leaking out of the hole?
    98 Maxima SE 5MT -- Intake/Y-pipe/Custom 2.5" Catback/Eibach Springs/Tokico Illuminas/Eibach camber plates
    14.43@95MPH, 2.31 60FT I/Y only
    Looking for a MK3 in the 604.
  7. #5
    Supra Fan
    Join Date
    Aug 2002
    Location
    Philly
    Age
    36
    Posts
    4,115
    LMFAO
    - 1990 Black turbo/targa/5spd SOLD(May 2006)
    - 1990 White turbo/hardtop/5spd R.I.P (2001)
  8. #6
    Dr. Jeff Lange Jeff Lange's Avatar
    Join Date
    Aug 2003
    Location
    Canada
    Posts
    9,266
    You either need to get that hole fixed, or you'll be finding yourself another tranny, there's not supposed to be any holes...
    is it threaded?
  9. #7
    1/2 Na-T Project JT87NA's Avatar
    Join Date
    Aug 2004
    Location
    Rochester, NY
    Age
    35
    Posts
    987
    is it threaded?
    What do you mean by threaded? Does that mean that someone has sewn threads with a needle into my transmission? If so then no its not, however it does look like someone knit a sweater for the hole but it must be worn out. Is it ok if I use peanut oil in my transmission, it is supposed to have less fat then other conventional cooking oils.
    87 1/2 Na-T 5 spd(under construction), Rebuilt US Spec Engine(15k), HKS 1.2mm Metal Head Gasket, ARP Head Bolts, Reprogrammed ECU(Techtom), Megan Racing 3" DP, Test Pipe, Blitz Nur Spec Exhaust, Custom Intake with K&N Filter, Custom Hard Pipes, Monza SSQV, AFM Flap Mod, HKS Twinpower Ignition Amplifier, Innovate LM-1 Wideband, Apexi S-AFC, Eibach Pro-Kit Springs, Tokico Struts, Front/Rear Cusco Strut Bars, TR Motorsports 17 Inch Rims, Kumho Ecsta Supra Tires, Clear Corners, Weight Reduction(no a/c, cruise control, spare, jack).
    1 of 1814
    Quarter Mile
    NA: 15.256@ 90.24
    Turbo: Coming Soon
  10. #8
    Join Date
    Aug 2003
    Location
    Canada
    Posts
    9,266
    LOLZ.
    In any case, also, to confirm: YES, there is supposed to be some kind of liquid in there. 4.0L of Manual Transmission Oil.
    Redline MT-90 is great stuff!
  11. #9
    SupraForums Member Spoolme's Avatar
    Join Date
    May 2004
    Location
    Roswell, NM
    Age
    32
    Posts
    3,727
    stupid ass troll
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
