torque specs for 2jzgte HELP!!!
+ Reply to Thread
Results 1 to 17 of 17
Thread: torque specs for 2jzgte HELP!!!
  1. #1
    evil will always triumph supraman741's Avatar
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    ok, so i did a search and didnt find what i was looking for....
    i am currently building a 2jz and am putting ARP head studs, main studs, rod bolts and flywheel bolts....
    what are the torque specs for the main studs, rod bolts, and flywheel???
    i am going to torque the head to 90 lbs
    current mods are/will be
    full cryotreatment of complete engine.
    cleaned and pressure tested block, milled block
    polished crank, might knife edge it
    stock rods
    stock TT pistons with ceramic coated domes
    stock TT piston rings
    clevite 77 bearing kit
    crower 1mm oversized valves
    crower springs and titanium retainers
    head is getting fully portmatched and polished
    5 angle valve job
    JUN 264/272 cams
    JUN lightweight flywheel
    HPF feramic clutch with ACT pressure plate
    31X12X4 custom intercooler
    T-62 t3/t4 turbo for now
    4:10 gears soon to be 4:30s
    NX 50 shot wet kit( got from a friend for $100 who could pass that up??)
    all new stock gaskets
    havent decided on a headgasket yet, or a timing belt
    anyways any help would be greatly apreciated
    thanx
    chris
    If You Aint Blowin You Aint Goin!!!
    Eagles may soar.... but weasels never get sucked into jet engines
    "So, Lone Star. Now you see that evil will always triumph...because good is dumb."
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    OCC SupraTuRD's Avatar
    Join Date
    May 2001
    Location
    Bay Area, CA
    Posts
    1,037
    90 ft.lbs.? You'll destroy/over-stretch the ARP headstuds... call ARP and ask them. I torqued mine to 65 ft.lbs. with their lube.
    sushi
  4. #3
    2005 LP640
    Join Date
    Jan 2004
    Location
    Tempe, Arizona
    Age
    29
    Posts
    930
    I've torqued my headbolts to 95 foot pounds, and they do just fine........but then again I have a MK3 :P
    I did it for the lulz.
  5. #4
    Boostin... WEST's Avatar
    Join Date
    Feb 2001
    Location
    In the garage...
    Age
    50
    Posts
    1,480
    Off topic, but I would change out the stock rods.
  6. #5
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    so do i
    sushi...... when i did my search i had come up with people torqueing the head to 75-115 so i am gonna hit it around the middle with 90.....
    as for the rods..... i have had them cryo treated.... hopfully this should be fine for what im trying to acheive(sp?)
    i think the stock 2jz bottom end will hold over 800hp, or so i have heard...... im only aiming for around 600-700 later on but since i bought this 2jz used i figured i would fully rebuild it, then after i got into it i decided to have it all cryotreated..... the stock rods should be able to handle what i wanna throw at it...... and i know the stock pistons will handle more than that....
    basically my funds have run short since i just bought a house, so some of the things i wanted are now on the back burner but everything in that list i already have/ its on order
    chris
  7. #6
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    ANY1????
  8. #7
    !black MadMaxx's Avatar
    Join Date
    Dec 2002
    Location
    South East region
    Posts
    4,625
    Flywheel - 36lbs + 90deg
    Head studs - 25lbs + 90deg + 90deg
    Rods bolts - 21lbs +90deg
    Those are factory ratings...
  9. #8
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    ^^ what about the main studs??
    thankyou for those specs....
  10. #9
    Join Date
    Dec 2002
    Location
    South East region
    Posts
    4,625
    Sorry, missed that one
    main studs are 35lbs + 90deg
  11. #10
    Join Date
    May 2001
    Location
    Bay Area, CA
    Posts
    1,037
    Madmax's specs are for stock hardware, not aftermarket ARP. I hope you take my advice and call ARP to get the proper spec for that particular fastener.
    sushi
  12. #11
    SupraForums Member Taimur's Avatar
    Join Date
    Feb 2001
    Location
    Long Island, NY
    Posts
    1,626
    This may help you a bit with the arp bolts
    http://www.supraforums.com/forum/sho...hreadid=261770
  13. #12
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    ^^ cool thanx
  14. #13
    Join Date
    May 2001
    Location
    Bay Area, CA
    Posts
    1,037
    Keep in mind that over-torqueing the head fasterners can distort the head enough to cause huge leakdown numbers...
    good luck,
    sushi
  15. #14
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    so do u think i should go 70-75? back when i had a 7m in my supra( yes guys im a mk iii owner, but this is a 2jz question so i figured u guys would be best) i torqued the head to 80, but i figured since a few guys on here were running over 90 and i do wanna put a good amount of boost into the engine that i should torque a lil higher.....
    chris
  16. #15
    Stock Twins King Stu Hagen's Avatar
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    4,369
    I did a WHOLE lot of research on this when I did my new head. I even called Jeff Watson. I think the first thing you need to determine is if your going to use Moly Lube of regular oil. That makes a BIG difference one the torque #'s you will use. Using Moly LOWERS the torque requirements. I also did talk to John Reed as well. My best answer came from Ramos who has built many supras and has a proven record. I ended up at using 68 # Moly Lube. You cant use the OEM FSM torque settings since there designed totally different. I think using 65 as a min and 80 as a max WITH moly lube is where you need to be. NOW, if you DO NOT use Moly and use motor oil, then you would need to add 10#'s to these numbers.
    Every ones ideas are based on intended use. TQFQ use these high TQ settings because of problems they had with coolant leaks at very high PSI #'s They also may have 1) Different head gasket 2) Built head, or 3) brand new block. They also DID NOT state whether they used MOLY or Motor OIL, so keep that in mind.
    So this is my .02 worth
  17. #16
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    i will be using the lube that the ARP's come with... so moly lube....
    the engine is going to be built/rebuilt.... im dealing with almost all fresh parts.... and the used parts have been cleaned, pressure tested and all that good stuff, so all in all its a used 1jz head that has been cleaned, decked and worked with all new parts, a used 2jz block that has been cleaned, pressure tested, milled, and hoaned that is using new stock TT pistons that have been ceramic coated, stock rods, stock crank that has been polished and i might knife edge it, all new clevite 77 bearings.... and all the ARPs, also..... everything but the ARPs got cryotreated
    how would i get a hold of the Ramos guy?? so i can talk to him
    thankyou for all of your imput!!!!!! hopfully soon i will have a badasssss running 2jz
    chris
  18. #17
    Join Date
    Nov 2002
    Location
    Johns Creek Ga
    Age
    35
    Posts
    2,225
    alright, so i was looking at the papers the arp headstuds came with....
    it says to torque to 81 ft lbs with the arp moly lube or 105 ft lbs with 30wt motor oil
    all the other arp bolts n studs are still in their packages waiting till i get into my new house so i can start the buildup
    anyways thankyou for all your help..... and ill post up once i get the ball rolling on this 1.5jz
    chris
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
