What does the ECT (Engine Coolant Temperature) sensor do exactly?
+ Reply to Thread
Results 1 to 14 of 14
Thread: What does the ECT (Engine Coolant Temperature) sensor do exactly?
  1. #1
    SupraForums Member
    Join Date
    Nov 2003
    Location
    Turbo World
    Posts
    495
    I'm just curious on what exactly does the ECT sensor do? I believe it stands for Engine Coolant Temperature. It plugs into the lower portion of the radiator next to the drain plug.
    Does this operate the temperature gauge on the dash? There are 2 other sensors in the upper water neck as well, just wonder what each of these sensors do.
    TIA
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    May 2001
    Location
    NJ/NY
    Posts
    2,944
    it makes your ass open when you take a dump on hot summer days.
  4. #3
    SupraForums Member
    Join Date
    Dec 2002
    Location
    SF
    Posts
    1,255
    this chart is generally useful for determining what certain sensors do
    http://www.mkiv.com/specifications/ncf/ncf93/ncf103.jpg
    as you can see, it plays a role in many functions & systems...
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Boost Junkie 1A1's Avatar
    Join Date
    May 2003
    Location
    Indiana
    Age
    43
    Posts
    11,439
    Blog Entries
    1
    Turns on the secondary fan, the electric fan to the right of the main mechanical fan.
    Steve K.
  7. #5
    Real Girl Thread FTW! Speedmaster747's Avatar
    Join Date
    May 2005
    Location
    Alvin, TX
    Age
    42
    Posts
    4,626
    Three sensors, three different tasks.
    One, sends signal to the computer for fuel mangement
    Two, sends signal to the computer for the electric fan
    Three, sends signal to the gauge in the dash.
    later
    Quote Originally Posted by Keros
    Your generousity and vigilance is unsurpassed. You are both a gentleman and a scholar!
    Bless your soul.
  8. #6
    MarksSupra33
    Quote Originally Posted by PsyKotiC RydeR
    Great post. Actually no, not at all.
    Evill Supra got it right, it tells the Electrical Fan when to come on. My sensor's back side where the harness is actually BROKE and I just never replaced it. It still plugs the hole fine but it can't plug in. Apparantly, if you separate the harness there, the electrical fan will stay on constantly.
  9. #7
    SupraForums Member
    Join Date
    Nov 2003
    Location
    Turbo World
    Posts
    495
    thanks for the help guys....+1 to everyone who helped
  10. #8
    Respect Jarrett H's Avatar
    Join Date
    Aug 2004
    Location
    Iowa City
    Age
    33
    Posts
    1,185
    I can tell you exactly how it works. Its actually a thermistor, the pcm/ecu sends voltage to it and depending on the temp it reads what voltage comes back. Then it calculates the temp. It uses that input to actually richen up the mixture on startup to heat things up faster. It also depends if you have OBDII or OBDI. Im pretty sure thats a continuous monitor in the comprehensive components so its always looking at the input when the car is in closed loop.
  11. #9
    SupraForums Member IcedSuPrA's Avatar
    Join Date
    Aug 2003
    Location
    Central NJ
    Age
    35
    Posts
    1,784
    does anyone know at what temp it comes on...sometimes i think my fan doesnt work or something becasue honestly i have never seen it go on....i mean is it pretty rare for it to turn on since you have the big fan in the front constantly turning or is mine just broken??
    SOmetimes on hot days i will have the hood up and the car idling for a few minutes after a drive just to see if the fan turns on and it never does..idk maybe i didnt wait long enough or can it be because i have water wetter mixed with my coolant and its actually doing its job and the tmep never really gets that high
    any thoughts..
    anthony
    i guess i can try and test it by pulling the plug or something
  12. #10
    MarksSupra33
    ^^^^ Exactly, just pull the plug and see if it stays on. If not, you need to test your fan to a 12V source and see if it spins.
  13. #11
    SupraForums Member
    Join Date
    May 2001
    Location
    NJ/NY
    Posts
    2,944
    You're right. Actually, no.
    Mind your own business. I know turboexpress in person and my post was made like that on purpose.
    Quote Originally Posted by MarksSupra33
  14. #12
    MarksSupra33
    ^^^^Then do ME a favor and when you wanna talk shit on me in other threads, mind your OWN fuckin business. Case easily closed. Don't say anything else, your response is well deserved.
  15. #13
    SupraForums Member
    Join Date
    May 2001
    Location
    NJ/NY
    Posts
    2,944
    When did I start shit with you Mark? Huh? When? It's funny that you're telling me to mind my own business when it was Y O U who started to yap about my comments on the headlight thread. Just there you go.
    Oh wait, I'm talking to a guy who talks about fucking people up online and sends PM's about such things right? OK, I'm scared. Bye now...
  16. #14
    SupraForums Member
    Join Date
    Apr 2005
    Location
    San Diego, CA
    Age
    39
    Posts
    2,182
    I'm a E-GANSTA and will do a 187 on both yoe asses. Online gangtas foe lyfe!!
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
