+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 56
Thread: New SP Toyota Transmission Upgrades
  1. #1
    www.spracingonline.com Sound Performance's Avatar
    Join Date
    Feb 2001
    Location
    Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
    Age
    47
    Posts
    10,904
    Stage 3 Toyota Transmission Upgrade:
    Replace low, intermediate, and overdrive sprags regardless of condition or mileage.
    Alto clutches, koleen steels, additional clutches added over stock number of clutches
    New pump out of a Lexus tranny
    Deep pan out of a Toyota truck tranny.
    The valve body and trans case are both machined for O rings instead of using the paper gasket which has been known to fail under higher pressure.
    Tranny is 100% disassembled, every part inspected and measured.
    Valve body modified for line pressure changes.
    Bushing kit - replaces ALL bushings
    File a small angle on the pump body crescent
    Replace filter
    Buff drums
    Install custom-made upgraded second gear band with high-energy friction material
    Upgrade spacer plate and accumulator springs with custom replacements
    Flush and check all solenoids
    Reassemble and pressure check engagement of every gear.
    This is not just an upgrade. It is an upgrade and a complete rebuild to new specs.
    3 year service warranty
    $3499
    Stage 2 Toyota Transmission Upgrade with 2nd gear sprag upgrade.
    Check all Bushings, replace if needed
    Replace filter
    Buff drums
    Upgrade accumulator springs with custom replacements
    Reassemble and pressure check engagement of every gear. Dyno test.
    Install custom 2nd gear sprag. CNC shafts and race for sprag.
    This tranny is similar to many of the other trannys being offered by our competition with the addition of the upgraded 2nd gear sprag.
    $2699
    Stage 1 Toyota Transmission Upgrade
    Replace filter
    Buff drums
    This tranny is similar to many of the other trannys being offered by our competition.
    $1699
    Please note that stage one and two are upgrades while stage three is a complete rebuild also. In all stages all parts are checked and cleaned. A functioning core is required in all cases.
    Larry
    SP
  2. #2
    Super Moderator
    Piss me off. I dare you.
    FYRARMS's Avatar
    Join Date
    Jul 2001
    Location
    In your nightmares.
    Posts
    18,741
    Great post! That should answer a lot of people's questions!
    a) Is the CNC'd custom second gear sprag replacing the one that normally takes a shit at HP over 600+?
    b) You didn't list it, but I assume the CNC'd sprag is also included in Stage 3.
    c) Any idea on HP level maximums of the Stage 3?
    2003 Z06: AFR heads, FAST90, Comp Cams, Borla headers/exhaust, RPS twin clutch
    Miatas: #1 choice of fags worldwide.
  3. #3
    Sooooooo JDM Ryan23's Avatar
    Join Date
    Feb 2003
    Location
    Newburg, MD
    Age
    38
    Posts
    1,221
    Nice to see everything broken down, Larry. What do you see as the max power threshold of a stage III? Is there a converter out there that is equally as stout? I have a pair of HKS twins I'm considering upgrading to GT30's for my SC. I already have the drivetrain out of an auto TT, so I would prefer to use what I already have. Do you think a pair of GT30's with say a 75 shot would be taxing a stage III, assuming cooling is addressed?
    Thanks,
    Ryan
  4. #4
    Hardtopper VR4_007's Avatar
    Join Date
    Oct 2002
    Location
    Las Vegas, NV
    Posts
    850
    Quote Originally Posted by FYRARMS
    AGREED!!!
  5. #5
    SupraForums Member
    Join Date
    Sep 2004
    Location
    Milwaukee, Wi
    Age
    32
    Posts
    81
    what's the HP level maximums on all 3 stages respectively
  6. #6
    SupraForums Member supralover93's Avatar
    Join Date
    Mar 2002
    Location
    Sacramento, ca
    Age
    28
    Posts
    3,573
    is there a warranty offered with the stage 1? how well would the stage 1 handle the budget kit?
    thanks
  7. #7
    Super Moderator
    FYRARMS's Avatar
    Join Date
    Jul 2001
    Location
    In your nightmares.
    Posts
    18,741
    Larry, stop browsing porn sites and answer our questions, you bastard.
  8. #8
    Join Date
    Feb 2001
    Location
    Age
    47
    Posts
    10,904
    Quote Originally Posted by supralover93
    thanks
    Stage 1 and 2 are only offered with a 30 day warranty. Any stage wil handle the budget kit fine.
  9. #9
    Join Date
    Feb 2001
    Location
    Age
    47
    Posts
    10,904
    Quote Originally Posted by supra213
    There is no way to put any HP level on these trannys. I can tell you that it will be as strong as any built Toyota tranny out there. If you think that a Toyota tranny will be 100 % reliable at 750+ RWHP you are kidding yourself. Do not be fooled by other tranny company's advertising.... I get calls from people with broken trannys from EVERY manufacturer or Toyota trannys out there. In fact just got one today from a guy who went through two from a very reputable tranny builder..... then he brought it to a local tranny repair shop and found out it was 99.9% stock on the inside.
    If you have a single turbo and you want 100% reliability, there is only one option...... and it is not a Toyota tranny.
    Larry
    SP
    Sound Performance
    630-893-5002
    DO NOT PM ME!!!
    Email - XXSUPRAXX@AOL.COM
    Instant Messenger - XXSUPRAXX
    Text or Cell Phone - (630) 205-6690
  10. #10
    Yes, brothers own Supras Silver Orchid SP60's Avatar
    Join Date
    Feb 2001
    Location
    Honolulu, Hawaii
    Age
    43
    Posts
    2,285
    Quote Originally Posted by Sound Performance
    Larry
    SP
    Cmon Larry..give us a lil something. Will the stage 3 will be at least good enough for 700rwhp and below? I mean, at least it would blow after a few good passes at the track? Most of us just want to do a few track runs maybe once or twice a month and have the tranny hold for that and daily driving.
    How about this? Give us a recommended max turbo size for each stage.
  11. #11
    Boost Junkie 1A1's Avatar
    Join Date
    May 2003
    Location
    Indiana
    Age
    39
    Posts
    8,368
    Blog Entries
    1
    I don't drag race much at all, if any, but would rather not put a 400 in my car. It would be nice if you could put a max hp or sized turbo for each stage.
    Steve K.
  12. #12
    Join Date
    Feb 2001
    Location
    Age
    47
    Posts
    10,904
    It is not possible to rate a max HP on these trannies!! I have seen people break them at BPU and I have seen guys with 800 RWHP make them last for a full season.... There are too many variable... driver style, tires.... etc
    A car with sticky tires is much more likely to break a tranny as well as a heavier car. Im not gonna lie to you guys and say it will handle 750 RWHP like other companies.... only have you call later and say it broke at 500. I get those calls about other companies way too often. If youre gonna keep the Toyota tranny.... you are rolling the dice. So do you feel lucky?
  13. #13
    Banned, jk lol GotToyota?'s Avatar
    Join Date
    Sep 2004
    Location
    Portland, OR
    Posts
    3,851
    Can the Stage 1 Upgrade fit an MKIII?
  14. #14
    Join Date
    Feb 2001
    Location
    Honolulu, Hawaii
    Age
    43
    Posts
    2,285
    If thats the case then why bother making the different stages since they all are basically a crap shoot? In other words dont go single with the auto unless you want to run a TH400.
  15. #15
    SupraForums Member
    Join Date
    Nov 2003
    Location
    Missouri
    Posts
    834
    Quote Originally Posted by GotToyota?
    What he said. Also need price of your SP58 turbo upgrade...
    Thanks;
    Will
  16. #16
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    2,908
    The key to making them last is how you drive on the street. It is obvious how you will drive it on the track, but if you also drive it like that on the street - full power upshifts, etc - that is where you are pushing it!
    You can enjoy an auto Supra on the street without a single full throttle upshift! 2nd gear will take you from 30-90, 3rd gear will take you from 50-130.
    Al
    94TT Auto, HKS Twins
    9.57@142.42 stock longblock w/ 264's, 32 psi, 10/29/06
    9.90@139.00 stock longblock, 30 psi, 4/13/04
    10.74@125.73 built motor, street tune, 19 psi, 3/7/10
    Previous car: 90 Talon AWD, 5 spd, FP 60-1
    10.56@132.36 built motor, 28 psi, Sept 2000
  17. #17
    Join Date
    Feb 2001
    Location
    Age
    47
    Posts
    10,904
    Yes we can also upgrade MKIII trannys.
  18. #18
    Join Date
    Feb 2001
    Location
    Age
    47
    Posts
    10,904
    Quote Originally Posted by Silver Orchid SP60
    To hit diff price points.... Stage one is the basic upgrade while three is the complete rebuild also. Stage two offers the sprag upgrade.
  19. #19
    Join Date
    Feb 2001
    Location
    Age
    47
    Posts
    10,904
    Quote Originally Posted by T6Rocket
    Al
    He is 100% correct!
  20. #20
    When cars say, "NO MORE!" SJ's Avatar
    Join Date
    Apr 2002
    Location
    PA
    Age
    30
    Posts
    2,112
    Quick question since I will definately be doing the tranny this winter...which stage directly compares to boost logic's tranny upgrade?
  21. #21
    Join Date
    Feb 2001
    Location
    Age
    47
    Posts
    10,904
    Quote Originally Posted by SJ
    stage 1
  22. #22
    SupraForums Member j0hnyboi's Avatar
    Join Date
    Dec 2002
    Location
    Cali
    Age
    33
    Posts
    511
    SP! Question Stage 1 Built Tranny
    How much power will stage one tranny support with a 3200 stall? Also, is this comparable to BL's $1800 built auto? I believe BL rebuilds the tranny though.
  23. #23
    SupraForums Member
    Join Date
    Jun 2004
    Location
    KL
    Age
    38
    Posts
    278
    in your website you only list $3400 for MKIV. Which stage is that? How much is stage 1 upgrade?
  24. #24
    Join Date
    Dec 2002
    Location
    Cali
    Age
    33
    Posts
    511
    I'll be straight with you!
    I just want to run 400rwhp all day long, no more and no less. Now which stage would you recommend? I will use a 3200 stall with a fat ass transcooler.
  25. #25
    Administrator
    Auto Admin
    RSA Supra's Avatar
    Join Date
    Feb 2001
    Location
    3.4 cars in front of your 6 speed (So Cal)
    Age
    34
    Posts
    6,883
    Quote Originally Posted by j0hnyboi
    If you're going to take the trouble of pulling the tranny out of the car and rebuilding it, I would go with the Stage 3. The only reason in my mind that anyone would go with the lesser stages is if they just can't afford them.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
