+ Reply to Thread
Results 1 to 5 of 5
Thread: safc tune numbers
  1. #1
    Is it turbo?? Jr24dawg's Avatar
    Join Date
    Dec 2003
    Location
    Spokane, Washington
    Age
    31
    Posts
    761
    safc tune numbers
    in a 4th gear pull i put down 11.2 - 11.6 afr. safcII tuned for 4k and above.
    then i did a 3rd gear pull, it was 10.4 - 10.6 afr..
    Is this normal???
    Chris
    SOLD 95 Supra na-t
  2. #2
    Har Kisiko
    Join Date
    Jun 2005
    Location
    USA
    Age
    35
    Posts
    105
    curious as to what what your tuned to?
  3. #3
    Newbie michaelvanle's Avatar
    Join Date
    May 2003
    Location
    South Jersey
    Posts
    11,228
    Not sure if it should differentiate (sp?) that much. But when I do diff gear pulls the a/f's change too. I normally tune to 3rd gear though. Because that's where most of the pulling is.
  4. #4
    Join Date
    Dec 2003
    Location
    Spokane, Washington
    Age
    31
    Posts
    761
    i used to tune from 3k rpm and up. then i read somewhere that tuning below 4k rpms is bad because the ecu is in closed loop until 4k rpms. therefore it can affect the afr's everytime you do a pull. im not sure if this is true though...
  5. #5
    Join Date
    May 2003
    Location
    South Jersey
    Posts
    11,228
    You are OBDI, so it won't affect you. It's only for the hotwire cars.
    Ever wonder why OBDII's convert to OBDI?
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
