+ Reply to Thread
Results 1 to 11 of 11
Thread: Car is missing after cleaning engine
  1. #1
    bwarren228
    Sorry for the NewB question, but I got some PS fluid in the engine bay and it smoked slightly so I was going to clean it off. No problem. I sprayed the engine degreaser and waited, then washed it off. I cranked it up and it didnt sound the same. It was idling low (550-650 jumping around sort of). I went right down my street and it was sort of bucking on me. It would go, then miss I guess, and then take off again. Friend of mine from this board says its prolly a fouled plug. Should I go ahead and get new plugs or is there anything else that could be causing it. Thanks.
  2. #2
    SupraForums Member
    Join Date
    Oct 2003
    Location
    Tampa Bay Area
    Posts
    238
    If you got water in the area where the plugs are it has no way out and will short the plug wires. There was a thread here once where a guy washed his engine and drove it like that to dry it off. His cat caught fire and burned his car up.
  3. #3
    Banned Justin727's Avatar
    Join Date
    Aug 2003
    Location
    gulfport
    Age
    28
    Posts
    4,172
    yep u got water down in there. I'll be over shortly to help you fix the problem!
  4. #4
    Search Justin's Avatar
    Join Date
    Dec 2002
    Location
    Spokane, Washington
    Age
    28
    Posts
    3,305
    Quote Originally Posted by bftsupra
    I guess I got lucky. We had someone detail the 88T and there was water in the plug journal.... drove it for a while trying to figure out wtf was wrong. by the time we figured out it was just water, the car was running like champ again.
  5. #5
    Banned vntperformance's Avatar
    Join Date
    Apr 2002
    Location
    Severn, Maryland
    Age
    35
    Posts
    5,114
    Your plugs are fouled due to water getting in that spark plug gally.
    I did this on my honda prelude a few years back, good times!
    vnt
  6. #6
    bwarren228
    Well we replaced the plugs and its like night and day. Really woke it up. Iridiums had been in there from the previous owner at least for a year if not longer. I'll get pics up when I get the digital back. Thanks Justin727
  7. #7
    Join Date
    Aug 2003
    Location
    gulfport
    Age
    28
    Posts
    4,172
    No problem! Got to clean things up while stuff was off so it wasnt bad. Not only that but those iridiums really needed to be changed. Even before you got water in there with the iridiums the new plugs were like night and day. Got some power back you lost over the old plugs. Woke her up! Very pleased to feel boost agian! I miss it!
  8. #8
    Needs More BOOST SupraSnd's Avatar
    Join Date
    Jan 2002
    Location
    Flinton, PA
    Age
    42
    Posts
    459
    You need to quit cleaning the engine!!!! Been there done this one in the past!!!!!!
  9. #9
    Supra Fan
    Join Date
    Aug 2002
    Location
    Philly
    Age
    32
    Posts
    4,114
    You washed the engine bay! Doh!
  10. #10
    bwarren228
    Yea next time I'll just let the extra PS fluid burn off instead of cleaning it
  11. #11
    Join Date
    Aug 2003
    Location
    gulfport
    Age
    28
    Posts
    4,172
    yes he knows guys.. he didnt spray it too much.. mainly more oil then anything from previous owner. needed a plug change anyways.. Denso Iridiums over a year old isnt a great thing to have!
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
