cracked water pump housing????
+ Reply to Thread
Results 1 to 6 of 6
Thread: cracked water pump housing????
  1. #1
    SupraForums Member TURBOYZZ's Avatar
    Join Date
    Mar 2004
    Location
    Utah
    Posts
    316
    I saw I was leaking a little coolant the other day and decided to take a look and see where it was coming from. It was dripping from the water pump area but not from the usual weap hole when the seal and bearing goes out. So I decided that I would have a local toyota dealer do my water pump along with my valve seals. Well after all said and done and a new crank dampener pulley that was about to fall off , I went too pick up the car and took a look at the old water pump and there it was a nice crack in the housing. So I was just wondering if anyone else has had this same problem?????
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Jul 2003
    Location
    Killadelphia
    Age
    31
    Posts
    366
    Quote Originally Posted by TURBOYZZ
    Happened on my old 93.5 Supra. The car sat for long periods and the stock water pump uses rubber seals that can crack and wear which caused my car to leak coolant excessively. Had it replaced and never had a problem since.
    Although I took it to my local supra mechanic who did my timing belt, water pump, crank seals, and valve seals for only 400$ He is the man, try to keep it away from the stealer if possible!
  4. #3
    Join Date
    Mar 2004
    Location
    Utah
    Posts
    316
    It was not the seals it was acutually the aluminum housing that cracked
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member Alex D's Avatar
    Join Date
    Jul 2004
    Location
    MD
    Posts
    3,688
    Only time i've seen cracking on the water pump is from really over tightening the bolts, and i mean really over tighten.
  7. #5
    When cars say, "NO MORE!" SJ's Avatar
    Join Date
    Apr 2002
    Location
    PA
    Age
    34
    Posts
    2,112
    they prob dropped the water pump or something after they pulled it off
  8. #6
    SupraForums Member
    Join Date
    Dec 2003
    Location
    Los Angeles, CA
    Posts
    23
    The water pump could have possibly been cracked due to a bad fan clutch...
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
