Mixing gas - How to calculate octane?
+ Reply to Thread
Results 1 to 12 of 12
Thread: Mixing gas - How to calculate octane?
  1. #1
    488ci V10 Power
    Join Date
    Sep 2001
    Location
    Mchenry County, IL
    Age
    39
    Posts
    2,555
    Hellooooooooo,
    I usually only run 112 octane gas in my car and i was thinking about mixing in some 93 for the winter since i wont be doing any high boost stuff with the cold weather. Since my low boost setting is 23lbs i will need enough octane to cover that. Straight 112 is overkill since i've run 32lbs on that gas fine.
    The 112 is as follows
    Antiknock Index (R+M)/2 - 112
    RON, Research Octane - 114
    MON, Motor Octane - 110
    I'm wondering how much 93 octane pump gas i can mix in to be save for the boost im running. I'm thinking maybe 3/4 112 and 1/4 93, anyone know what the 93 octane stats are?
    1999 Viper GTS/ACR Edition - Silver/Blue Stripes (1 of 30 Built)
    Roe Supercharged, T&D Rockers, PBJ Intake, Borla Exhaust
    618 rwhp, 651 ft/lbs torque
    Click here to enlarge
    1998 Quicksilver Supra Turbo - 980rwhp / 746 tq
    Sound Performance Built and Tuned
    SOLD
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,657
    110+93=203/2=101.5 50/50 mix that should be enough for the boost you want to run.
    Jason
  4. #3
    488ci V10 Power
    Join Date
    Sep 2001
    Location
    Mchenry County, IL
    Age
    39
    Posts
    2,555
    Quote Originally Posted by HotSoup
    Jason
    Are you sure 93 octane has a MON of 93?
    Im not sure 101octane is enough for 23lbs, might have to datalog it some to watch for knock.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member StokerSix's Avatar
    Join Date
    Dec 2004
    Location
    Cape Canaveral FL
    Posts
    980
    From logging timing on my '97 T78 car I've found that 100 MON is sufficient for around 25psi (~600rwhp). This is with leaded high octane pump mix. In addition, I've found that a leaded/pump mix performs better then the equivalent MON unleaded/pump mix.
    I'd watch your knock sensors since you have that capability though.
  7. #5
    SupraForums Member Taimur's Avatar
    Join Date
    Feb 2001
    Location
    Long Island, NY
    Posts
    1,627
    Here is a calcutor to give you the desired mix
    http://www.t72supra.com/Race_Gas_Formula.xls
    Informative post...
    http://supraforums.com/forum/showthr...ghlight=octane
  8. #6
    Join Date
    Dec 2004
    Location
    Cape Canaveral FL
    Posts
    980
    Quote Originally Posted by Taimur
    Informative post...
    My results disagree with that thread.
    I would never consider running 26psi on GT104. I pulled ~5 degrees timing using TrakTec 105 unleaded at 23 psi.
  9. #7
    488ci V10 Power
    Join Date
    Sep 2001
    Location
    Mchenry County, IL
    Age
    39
    Posts
    2,555
    Quote Originally Posted by StokerSix
    Thanks! Im still trying to find the MON of 93 pump gas.
  10. #8
    Join Date
    Dec 2004
    Location
    Cape Canaveral FL
    Posts
    980
    heh. IIRC, 93 is 89 MON.
  11. #9
    SupraForums Member
    Join Date
    May 2002
    Location
    Huntsville AL
    Posts
    1,212
    you should be able to do do 1/2 tank 110 and 1/2 pump for 23 easy. I run that sometimes with mine no problems.
  12. #10
    488ci V10 Power
    Join Date
    Sep 2001
    Location
    Mchenry County, IL
    Age
    39
    Posts
    2,555
    Quote Originally Posted by Mad TKD
    Ok good! Im actually running 112 octane (110 MON).
  13. #11
    One wheeled junkie
    Join Date
    Sep 2005
    Location
    Tejas
    Posts
    312
    Jason
    i dont mean to steal the thread but i've been wanting to ask you this for a while now, what gas are you running??? whats your mods??? how much psi and whats your #'s????
  14. #12
    One wheeled junkie
    Join Date
    Sep 2005
    Location
    Tejas
    Posts
    312
    dyno #'s i mean with mixed gas and with just 93
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
