Car wont start after 1 month sitting
+ Reply to Thread
Results 1 to 12 of 12
Thread: Car wont start after 1 month sitting
  1. #1
    Made in Stuttgart kevganzon's Avatar
    Join Date
    Aug 2004
    Location
    SoCal
    Age
    35
    Posts
    2,999
    Does anyone know a solution to getting my car to start after its been sitting in the garage for almost a month? the radio, antenna, power turns on but car wont start over I reset the fuses and still no luck! any suggestions??? i want to drive my Supra
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Supra Owner Since 1996 Hands On's Avatar
    Join Date
    Dec 2003
    Location
    Idaho
    Age
    35
    Posts
    2,723
    try charging or jumping your battery. Just because the accesories turn on does not mean there is enough power to crank the starter over. Try turning on your head lights and see if they dim when you try and turn it over. Do you have an alarm? Try unlocking the car with the key in the door to turn off the factory theft deterent.
  4. #3
    1st Lieutenant Team BEYAW ToyoBeastly's Avatar
    Join Date
    Nov 2001
    Location
    Phoenix, AZ
    Age
    33
    Posts
    2,840
    yep, probably a battery. do you have a batt charger? if you are the kind of person that makes a habit of letting the car sit while the weather is nasty, i would get one. any ways, if it still doesnt start with a jump, you may want to get a battery charger and let it sit on a low setting over night, mine has three settings: 2 amp slow, 12 amp fast, and 75 amp jump start. and sometime you have to leave it on the 12 amp setting before you can do the 75 amp start, or at least i do. oh, and the charger was only about $30
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Very Senior Member Silver Supra's Avatar
    Join Date
    Feb 2001
    Location
    2 Pa Low
    Posts
    13,894
    Quote Originally Posted by kevganzon
    Best bet - charge the battery. You may want to take it out and to AutoZone or somewhere to get it checked.
    2nd option - jump start it and drive to Autozone or somewhere....
    no, I don't work for them!!
  7. #5
    Custom LED Tail Lights SupraGodTT's Avatar
    Join Date
    Jan 2005
    Location
    S. NJ & N. Tx
    Posts
    3,315
    Im going to have to agree with these guys .. due to the fact that my car has been sitting for about 3 months now and I have the same exact problem and when spring comes around I will be buying a New Battery .. And not sure if its going to be from AUTOZONE lol .. but thats what my car does sometimes .. and im lucky if any lights come on .. AT ALL !!
  8. #6
    SupraForums Member chrisfosupra's Avatar
    Join Date
    Nov 2005
    Location
    colorado
    Age
    28
    Posts
    112
    maybe the starter cylinoide is out cus u do have power to all the other things right??? and after a while of sitting it is posible the cylinoide could have ate it
  9. #7
    Bench Racer of the Year briguy453's Avatar
    Join Date
    Oct 2003
    Location
    Kentucky
    Posts
    692
    It's the battery. I rarely drive my car, and I learned my lession after the first dead battery. If you don't drive your car, disconnect the battery.
    Click here to enlarge
    1997 TOYOTA SUPRA TURBO
  10. #8
    Hayai Kuruma! Suprachik8's Avatar
    Join Date
    Oct 2004
    Location
    Endor
    Posts
    1,357
    yup it's definitely the battery! My car is 98% of the time garaged, rarely driven and after 3 die hard batteries, and jump startin it time and time again, I finally decided to just get a trickle charger and leave it hooked up to the car all the time. The one I got tells me if my battery is fully charged and then when it starts to reach that point where it's losin it's juice, it starts to charge it on its own! Awesome! Now I have no worries of it ever dying, though I ofcourse start it up every other 3 days to get the engine goin even if it just sits there.
    Hope this helps.
    Btw, trickle chargers run from $30 to $200. Good investment.
    This is the one I got: http://www.sears.com/sr/javasr/produ...ers+%26+Cables
    and here's a listing of the other ones:
    http://www.sears.com/sr/javasr/searc...=searchresults
  11. #9
    Swing on deezz!!! ra24man's Avatar
    Join Date
    Aug 2005
    Location
    Vantucky, WA
    Age
    42
    Posts
    2,155
    This being my first winter with my Supra, and actually having a car hibernate for the season, I've come to have the same problem. I bought this sucker just a few days ago after my Optima was dead for the second time in the last couple of months. Schumacher makes it, 1.5 amp, it's fully automatic and cost about $35. It came with mounting brackets and loop terminals for permanant mounting in the engine compartment. I cut them off and installed a couple of alligator clips. Run the extension cord up though the left side duct.. no more worries I hope
    Mark
  12. #10
    Join Date
    Aug 2004
    Location
    SoCal
    Age
    35
    Posts
    2,999
    Thanks guys for the input. I did exactly what you guys suggested and it worked. car needed a jump start. this was my first time storing the car over the winter.
  13. #11
    Join Date
    Feb 2001
    Location
    2 Pa Low
    Posts
    13,894
    I would still get the battery checked. Most parts places will do it for free!
  14. #12
    SupraForums Member HmoobSUPRA's Avatar
    Join Date
    Feb 2001
    Location
    Clovis, CA
    Posts
    1,237
    Duplicate posts ARE confusing....glad you the problem is resolved.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
