PRICING UP-DATED 1/1/11
11400-49088 SHORT BLOCK ASSY LIST 2884.18 COST 2495.00*****
15100-46052 OIL PUMP LIST 226.88 COST 170.00
04111-46094 FULL GASKET KIT LIST 549.28 COST 415.00
[includes valve stem seals and everything else you'll need]
11115-46052 HEAD GASKET ONLY LIST 173.89 COST 130.00
00295-00103 FIPG PAN SEALER LIST 13.82 COST 10.44 EA X 3
90915-YZZD3 OIL FILTER V8 USA LIST 5.41 COST 3.96
00272-1LLAC-01 ANTIFREEZE RED LIST 25.59 COST 19.53 EA X 2
90363-12002-77 PILOT BEARING LIST 10.34 COST 7.90 [ 6SPEED ONLY]
90402-16015 OIL PRESSURE SWITCH ADAPTER LIST 10.37 COST 7.92
15710-46020 OIL COOLER LIST 631.44 COST 480.00
[MANDATORY IF YOUR MOTOR HAD ANY INTERNAL DAMAGE]
15670-46070 BRACKET OIL FILTER LIST 99.06 COST 75.63 [ FROM NA MODEL TO ELIMINATE STOCK TT OIL COOLER IF YOUR GOING TO USE AN AFTERMARKET ONE]
ABOVE IS BARE BONES REPLACEMENT PARTS
16100-49846 WATERPUMP LIST 166.70 COST 125.00
13505-46041 T/BELT IDLER LIST 91.11 COST 69.57
13568-49036 T/BELT LIST 35.58 COST 27.17
13540-46030 T/BELT TENSIONER LIST 77.42 COST 59.12
ABOVE IS OPTIONAL ITEMS NEEDED[inspect and replace as needed]
13011-46051 TT RING SET LIST 237.55 COST 180.00 [ std only]
13101-46091 TT PISTON LIST 85.16 COST 65.00 EA X 6 [ std only]
13201-46040 TT CONNECTION ROD LIST 88.63 COST 65.00 EA X 6
13041-46013-XX ROD BEARINGS LIST 16.21 COST 12.38 EA X 6
11071-46020-XX MAIN BEARING #1 LIST 26.63 COST 20.33
11701-46020-XX MAIN BEARING #2-#7 LIST 28.76 COST 21.96 EA X 6
11011-46030 THRUST WASHER SET LIST 42.09 COST 32.13
13401-46022 CRANKSHAFT LIST 988.48 COST 750.00
11401-49715 BLOCK NAKED LIST 2468.35 COST 2016.00
ABOVE IS FOR REBUILDING YOUR BLOCK
There are 5 different sizes of main and rod bearings. I need the numbers off the Face of the block, rod caps and on the crank counterweights for correct sizing.
*** Factory Warrantee against manufacturing defects found at time of assembly. NO WARRANTEE on improperly installed, foreign objects in oil system,poor tuning,too rich, too lean, over-reved,forgot to put oil in, forgot to add coolant, leaking gaskets, too much boost, no break-in period, improper break-in procedures,clogged oil cooler from previous blown motor, contaminated oil cooler,improper torque of main / rod bolts,detionation,knock sensors not functioning, bad fuel MAP on your AEM/ MAP ECU/Greddy E-manage/HKS-VPC,Pro-EFI ,Motec ,improper cam clearances, Meth injection not set-up properly,E85 FUEL etc etc etc
[shipping USA 135.00-225.00 range]
