why do i have to push the brake pedal so far down?
+ Reply to Thread
Results 1 to 15 of 15
Thread: why do i have to push the brake pedal so far down?
  1. #1
    SupraForums Member BB6SE's Avatar
    Join Date
    Jun 2004
    Location
    AB, Canada
    Posts
    1,012
    i have to really get on the pedal for it to brake.
    would it be my master brake cylinder?
    thanks in advance guys.
    Click here to enlarge
    06 Gallardo
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Apr 2005
    Location
    Posts
    1,604
    Have you a friend with another Supra to compare with? Compared to some other cars, the pedal travel is more. Yes, master cylinder could be at fault.
  4. #3
    SupraForums Member
    Join Date
    Aug 2005
    Location
    Birmingham, AL
    Age
    27
    Posts
    2,437
    on a somewhat related note, did anyone ever determine exactly what causes the 'mushy', or 'dampened' pedal feel in the mkiv? pistons, m cylnder, or actual pedal?
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    Oct 2005
    Location
    Las Vegas
    Age
    27
    Posts
    229
    i would also like to know this
  7. #5
    Original Owner MyKarIsVicious's Avatar
    Join Date
    Sep 2001
    Location
    Southern CA
    Posts
    5,269
    ditto kiddos
    ----- MVP / Competition GT / GSC / Boost Logic Powered -----
    Tuned By: Tuning Concepts / Robispec / AMB Aero Design
    2010 Castrol Syntec Top Car Challenge Winner
    2010 Super Lap Finals Limited RWD 2nd Place :(
    2008 Super Lap Finals Street RWD Winner
    2006 Super Lap Finals Street Overall Winner
    2009 BMW X5 Diesel
    2007 Ducati Sport Classic SE
    2003 Ducati 999s
    2008 CLK63 Black Series (SOLD)
    Profile
    Epic Ownage
  8. #6
    PRSRIZD Member
    Join Date
    Jan 2005
    Location
    Phoenix
    Posts
    246
    how are your pads? when was the last time you bled the brake system? also you can usually tell if the master cylinder if you pump the brakes and on ur 3rd or 4th pump it becomes solid like it should be.
  9. #7
    SupraForums Member
    Join Date
    Jun 2004
    Location
    MA
    Age
    30
    Posts
    1,602
    I am using Stoptech rotors and calipers all around on my car along with SS braided lines as well. I have no mushy pedal whatsoever, and the car stops on the DIME.
  10. #8
    Super Moderator
    !!ON PATROL ALL OVER!!
    Ranger498's Avatar
    Join Date
    Apr 2001
    Location
    <--NY/NJ-->
    Posts
    17,734
    I As well have SS braided lines and I have no mushy pedal whatsoever.
  11. #9
    i always say toyota !
    Join Date
    May 2003
    Location
    bayarea, CA
    Age
    38
    Posts
    2,761
    yup, usually its the master cylinder with this problem. if you don't have any brake fluid leaking. and if this started right after your big brake kit. you can try to bleed the brake system first.
  12. #10
    TE44 NA-T adversary's Avatar
    Join Date
    Nov 2004
    Location
    Tracy, ca
    Age
    30
    Posts
    1,026
    most likely air in the brake system.
  13. #11
    SupraForums Member WhiteBlazze's Avatar
    Join Date
    Mar 2004
    Location
    Woodbridge, VA
    Age
    36
    Posts
    2,561
    either air in the system, ur leakin fluid everywhere, or your pads/rotors are way below minimum thickness
  14. #12
    SupraForums Member
    Join Date
    Apr 2005
    Location
    Posts
    1,604
    Quote Originally Posted by BB6SE
    Tell us more about what you have serviced, replaced or know that's not right. Then we can narrow it down.
  15. #13
    SupraForums Member MattyTrashed's Avatar
    Join Date
    Jun 2003
    Location
    NY
    Age
    32
    Posts
    1,430
    when is the last time you had your brakes bled?
  16. #14
    Join Date
    Jun 2004
    Location
    AB, Canada
    Posts
    1,012
    Quote Originally Posted by MtFujiSupra
    hey bro,
    we just got this supra. and the pads have a lot left.
    the front rotors seem warped but we're going to replace those asap.
    whenever i pump the pedal it gets stiff. i can hear a sound coming from under the hood when im doing this also. thanks for your input guys
  17. #15
    SupraForums Member
    Join Date
    Jul 2006
    Location
    Issaquah, WA
    Age
    46
    Posts
    75
    If your brake come back after pumping the pedal, that sounds like master cylinder. I noticed you said you have a bad rotor, is that confirmed. I ask because if the car has power brake assist (not sure if they do) the pedal will go down near the floor and as you come to a stop you might feel a pulsating and the pedal will push back against your foot. The pulsating feels simular to a warped rotor.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
