Does the 2JZ-GTE fuel rail bolt in? How about a top feed rail kit for a GTE?
The search is down...... Thank you!
i believe they line up and work but you have to fabricate mounting brackets. or i think dave h makes a rail
why get the TT fuel rail? Cant the NA fuel rail flow enough to support like 800hp?
Well I have top feed 550's here as an option, just buy a rail instead of injectors if it's cheaper. That's why. They came off my 7M, and they are still gooder than the stock 2JZ-GE, and 1JZ ones. I saw rails for $250 shipped for 2JZ-GTE head. Which are cheaper than the $500 800cc side feeds. I can't afford the fuel setup I want. It's have a car with 550's that runs or 800ccs that doesn't run, and dude, I'm that short so I need to know.
no the stock rail wont support anywhere close to 800. a bored out stock rail on 600 is pushing it. id suggest a titan rail or a universal -10 rail and get it drilled depending on how much hp your looking to make
Originally Posted by JaxSc3
Another person posting who has no clue...
Yeah, a stock rail will support 800....its inner diameter is similar to some aftermarket rails! What one needs to modify is the feed lines to the rail, preferably dual feed from each end and a center outlet for the regulator...
David
Originally Posted by turbodg
Would you happen to have a diagram of what you just have describe?
What is the thread pitch of the ends on the rail?
From what I understand, the 1jz fuel rail may fit the 2jz-ge. I believe the mounts line up as well as the injector ports.Originally Posted by RacerXJ220
Thanks man,
Eric
damn, thats a really good idea, has this been done are you just suggesting that as an option? b/c it might come out cheaper to just get an aftermarket rail for the same price of fabrication that some ppl chargeOriginally Posted by turbodg
No one has made 800 whp on a GE motor much less delivered fuel to one using a modified GE fuel rail.
I made 630whp using the modified dual-feed, center-return rail shown in the attached pic with a GE motor; consequently, you're safe up to that power level.
Believe it or not, I've had more problems moving to an aftermarket rail because the FPR is now much more sensitive to heat soak with the larget diameter ID fuel rail. I never had FPR heat soak problems with a modified GE fuel rail.![]()
-scott
'95 sc300 6-speed, AEM, T74GTS, DaveH intake,
RLTC, 1000cc inj, Tilton clutch, 272 cams, meth inj, etc.
838whp@32psi: http://www.youtube.com/watch?v=9rMEy3s8I7s
Thanks for all the input guys. I really do appreciate it. I'll go with the stocker.
oh i have no clue huh its just plain not safe, ask any company that makes fuel delivery products for 800 hp no less than a -8 fuel rail. the stock rail is slightly larger than a -6 how would i know??? maybe because ive measured already. sure you may be able to barely make it by but id prefer be safe and not blow my shit up. im running aeromotive raw -10 rails drill for my NA. know your facts before you call someone out who actually know what they are talking about.
/rant
Maybe no one has, but its not the rail that is the limiting factor...its ID is enough to support 800hp is my point. With proper feed and properly sized injectors, the rail will not be the limiting factor...Originally Posted by motorheaddown
David
Oh, and I don't know what I'm talking about? I've been drag racing since 1987, probably the year you were born! I put a couple of pics of a vehicle I built and by built, I mean I built everything, from fuel systems, to intakes, rollcages, to turbocharger manifolds, heck I even made my own 2jzgte to Powerglide tranny adapter...Originally Posted by JaxSc3
And as an fyi, the ID on a stock GE rail was the same as the aftermarket rail I had on my 2jzgte which made 695whp and there was more left in it(how much more, I don't know...probably run out of injector or pump before rail)...yes, bigger can be had, but the stock one will suffice for 800hp...it's diameter is not the limiting factor...I stand by my assertions
and the last picture is credited to Joliroger to whom I sold the truck and who ran a 9.4 at 143mph...
David
Agreed. Stock rail and -8 will support 800 wheel. Simple as that. Im going to cut a rail in half on monday and measure the true id, just out of curiousity.Originally Posted by turbodg
I havent made that much yet, but im certain the rail will be the least of my concerns when the boost gets turned up.
Josh@FSM
(who thinks that taco is sick!^^^)
i agree with both Quickness and Turbo Dog, he deffinately knows wat he's talkin about, and ive seen a numerous amount of NA-ts making big numbers, all of which were run on stock rails....
