+ Reply to Thread
Results 1 to 12 of 12
Thread: How to cut ABS plastic
  1. #1
    SupraJ128
    Alright, I have installed by Profec A where my ashtry goes by cutting a whole in ABS plastic (the stuff that make Stereo DIN's out of) and it took a long ass time. I am going to do it again today better, but I am wondering...How is the best way to cut that stuff? Thanks
    Jason
  2. #2
    Moderator/Troll Slayer SupraTrey's Avatar
    Join Date
    Mar 2002
    Location
    Midwest
    Age
    34
    Posts
    6,036
    Hey Jason... why dont you buy the Din Kit for the controllers? makes it easier and you can leave your dash stock.... looks better IMO
  3. #3
    87Tmk3
    Sharp razor blade works the best. But you can also use an air saw or jig saw.
  4. #4
    SupraJ128
    any other techniques?
  5. #5
    tsupra
    cnc mill works great.
  6. #6
    SupraForums Member
    Join Date
    Oct 2001
    Location
    Upstate NY
    Age
    33
    Posts
    1,652
    I usually use a Bridgeport. If you don't have one available, set up guides for a rotozip and you can get very good results too.
  7. #7
    This Is Why I'm Hot..... Larry_A's Avatar
    Join Date
    Oct 2001
    Location
    SoCAL
    Age
    52
    Posts
    2,005
    Dremel
    One of the best things Jeff Montigny ever turned me on to.....
    the Dremel.
    Once you get one, your life will change forever! No, I'm not exaggerating, really.
    Daily driver:
    6'2" Stinger
  8. #8
    Hooligan
    I used a bandsaw to make the custom gauge cluster in my Celica. There's a picture HERE .
  9. #9
    ef9
    In no special order when working with plastics:
    1. Dremel
    2. Rotozip
    3. bandsaw
    4. jigsaw
    5. hot knife (soldering iron with an x-acto blade at the end)
    Stan
  10. #10
    tsupra
    actually i think it would be a good idea to clarify a few things when cutting abs plastic. if you use a dremel, use the carbon fiber cut off wheel that goes in it. for the rotozip, the cutting bit. using a jig saw isn't a very good idea on abs due to the blade heating up and melting the plastic slightly making it very difficult to cut. also a circular saw or table saw works pretty good for long cuts. if you're cutting round holes use a hole saw.
  11. #11
    Supra { bhg: true } cmw_2000's Avatar
    Join Date
    Jan 2002
    Location
    Omaha, NE
    Posts
    399
    tsupra-that pic is pretty cool...nice use of space!
  12. #12
    Moderator
    l337 M0d3r4t0r
    ZaZZn's Avatar
    Join Date
    Feb 2002
    Location
    Toronto/San Francisco
    Age
    31
    Posts
    12,468
    Dremal is the best tool ever.
    I cut out my ashtray so I could fit a old style AVC-R in with the ashtray there.. Looks VERY VERY good.. I'll post pics when I can......
    I cut just about everything with my dremal
    Eric W
    MK3 87T 2JZ 430WHP 435TQ Stock Twins
    IS-F 08
    Old setups
    Click picture for Mods
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
