2JZGE intake manifold pics ( 56K no way!!)
+ Reply to Thread
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 25 of 79
Thread: 2JZGE intake manifold pics ( 56K no way!!)
  1. #1
    2JZA70 SDstreetracer's Avatar
    Join Date
    Dec 2001
    Location
    San Marcos, CA
    Age
    34
    Posts
    2,424
    I just thought I would post up some pics of what ive been up to lately. I just finished this intake manifold for my friend Mike Carwins ( twincharge on the forums)supra. His car is curently in the newest issue of Dsport magazine sporting some IC piping I made for him. Anyway I unfortunalely wasnt done with the manifold in time for the photo shoot but here are some pics of it.
    Its sporting a billet 90 mm TB and billet velocity stacks inside. I will be fabbing up the IC piping later this week and then hopefully we can get some dyno results after that. the car made 610 rwhp with the stock intake mani just before we took it apart so well see what it does now.
    93 black 6speed stock block S366 10.13@136 25psi
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    2JZ-Phantom SealSupra-6's Avatar
    Join Date
    Nov 2004
    Location
    Sac, California
    Age
    33
    Posts
    2,117
    Really nice, what did you do with the power steering? Also you planning to sell some of these intake?
  4. #3
    Join Date
    Dec 2001
    Location
    San Marcos, CA
    Age
    34
    Posts
    2,424
    the ps resevoir was relocated next to the brake master cylinder. You can see it in the pic in the upper right hand corner. As for making more intakes, I do this as a hobby in my spare time but if someone wanted one I could probably make another. Just PM me if your intrested.
  5. #4
    Join Date
    Feb 2006
    Location
    SC
    Posts
    366
    I dont see the velocity stacks? Did you blend them into the runners? Looks like a copy of the VWR manifold.
  6. #5
    feeding your habit 98mkiv's Avatar
    Join Date
    Feb 2004
    Location
    NH & NC
    Age
    44
    Posts
    4,021
    the stacks are the radiused inlets. typically you see stacks as a raised horn, but this is a pretty reasonable approximation. Welding looks good, you could spend some time with a die grinder and papers and smooth out the outside of the runners for a more finished look, other than that it looks really good. I think this style manifold looks so much better compared to the stock ge setup.
    very nice piece. You can check out my approach to a GE manifold over at clubna-t.
  7. #6
    Join Date
    Sep 2005
    Location
    Wilmington, DE
    Age
    36
    Posts
    566
    looks like an ebay gte mani welded to na runners. Is this the case?
  8. #7
    !black MadMaxx's Avatar
    Join Date
    Dec 2002
    Location
    South East region
    Posts
    4,627
    Quote Originally Posted by The Quickness View Post
    +1
    Grind the welds and powdercoat it. I don't like shinny shit
  9. #8
    SupraForums Member
    Join Date
    Nov 2005
    Location
    so,cal
    Posts
    721
    This is not a E-BAY manifold, it was hand built. The throttle body is another story.
    94 na-t 6spd Turbonetics Billet 8382 Motec M-800 Motec CDI-8 ID Dailey Engineering dry sump ID 2000's Weldon RPS Triple carbon E-85 1200hp 9.64 @ 146 mph 1.31 60 ft
    93 TT BL auto, Turbonetics T-70, ID 1300, Pro EFI, Vvti, Titan cams
    85 MR-2 Twincharge 320whp 12.5 115mph
    71 Celica 18RG-T 450hp 11.4 130mph
    07 Acura TL-S
    Toyota Master Tech, ASE Master , Toyota MDT.
  10. #9
    Beats and Rhythm simann's Avatar
    Join Date
    Oct 2003
    Location
    Tennessee
    Posts
    2,666
    That is absolutely gorgeous!
    "Life is not a journey to the grave with the intention to arrive safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming: Wow!!! What a ride!"
  11. #10
    SupraForums Member ssao1's Avatar
    Join Date
    Feb 2006
    Location
    Santa Rosa, NorCal
    Posts
    1,054
    I was thinking about doing the exact same thing, but the cost of buying the manifold and making my own is significantly different.
  12. #11
    Join Date
    Oct 2003
    Location
    Tennessee
    Posts
    2,666
    Quote Originally Posted by ssao1 View Post
    http://cgi.ebay.com/ebaymotors/2JZ-G...spagenameZWDVW
    Enough said.
  13. #12
    Join Date
    Dec 2002
    Location
    South East region
    Posts
    4,627
    Quote Originally Posted by twincharge View Post
    Sure as hell looks like a VW/Stryder clone
    Probably easier just to hack up a thai manifold than build from scratch, unless you have all the mats on hand already.
  14. #13
    Join Date
    Feb 2006
    Location
    Santa Rosa, NorCal
    Posts
    1,054
    Yes it would be EASIER to hack a Thai manifold, but it is CHEAPER to make one your own.
    The material for making a manifold is not that much, it is the labor that what makes the manifold to be 500$ from Thailand or even 1100$+ from respected vendors.
  15. #14
    Join Date
    Dec 2002
    Location
    South East region
    Posts
    4,627
    Eh, that's under the assumption labor = free.
  16. #15
    Join Date
    Dec 2001
    Location
    San Marcos, CA
    Age
    34
    Posts
    2,424
    Quote Originally Posted by MadMaxx View Post
    considering I hand built the entire thing and have never seen a virtual works manifold in person Id say I didnt copy anybody. I built it on the car with nothing to go by so it was entirely my own design. there are only so many ways it will look when building these things. I spent more in material to make this manifold than those cheap ebay pieces of shit cost. The billet air horns are from RMR. Some of you guys are rediculous.
    It looks no more like an ebay mani than the manifold you sell.
  17. #16
    Join Date
    Sep 2002
    Location
    Baltimore, MD / Southern NJ
    Age
    34
    Posts
    4,768
    this is getting interesting
  18. #17
    MkIV Pilot mogallo's Avatar
    Join Date
    Jan 2004
    Location
    Austin, TX
    Age
    32
    Posts
    582
    Damn dude that IS rather nice.... How much you selling them for ???
    Click here to enlarge
    PT61 / AEM / 19psi / 478whp
    Props to Dan at Batlground - www.batlground.com
    Myspace - http://www.myspace.com/mogallo
  19. #18
    SupraForums Member speed_vision's Avatar
    Join Date
    Jun 2004
    Location
    Socal
    Posts
    349
    Looks good!
  20. #19
    Join Date
    Dec 2001
    Location
    San Marcos, CA
    Age
    34
    Posts
    2,424
    Quote Originally Posted by mogallo View Post
    Im not sure. I made this one for a friend and didnt really intend on producing these. It really is alot of work to build one. If you or someone else really wanted one PM me and we can work something out. Like I said before its just a hobby for me that i do in my spare time so I can only do stuff on a limited basis.
  21. #20
    Banned rwmotorsports's Avatar
    Join Date
    Oct 2001
    Location
    DFW, TX
    Age
    30
    Posts
    2,722
    The manifold that Josh sells is just a D Plenum bolted to the stock lower runners, not much in common with an eBay piece of crap. Josh's in house welder is fantastic, so don't go knocking his stuff when it works.
    Your's does look a lot like a VW or even a eBay Thailand knock off, whether or not you've seen one goes without saying. It is a good piece of work, but I hate to tell you that velocity stacks on the Supra haven't been shown to improve drivability at all. In fact, a certain vendor on this forum switched from the Veilside to the VW because the velocity stacks disturbed the airflow more than they helped. Just a little FYI for you.
    You've got pretty good skills, I'll give you that. Nice attempt....
  22. #21
    Join Date
    Feb 2004
    Location
    NH & NC
    Age
    44
    Posts
    4,021
    I've never heard of an instance where velocity stacks did not improve flow. In a job I had a few years back, I spent weeks at a flow bench with velocity stacks.... they work, though they are most efficient when raised off the floor a bit.
  23. #22
    Join Date
    Dec 2001
    Location
    San Marcos, CA
    Age
    34
    Posts
    2,424
    Quote Originally Posted by rwmotorsports View Post
    First off, go back and read again. I never said his manifold looked like an ebay manifold or knocked the quality of his product. As for the velocity stack comment once again you should read again/look at pictures again. The manifold I made does not have velocity stacks protruding and disturbing airflow. They are flush if you didnt notice. The way VWR and others make theirs is to hand port the runners to make somewhat of a velocity stack. I just happened to use billet airhorns instead. just look at the RMR manifold.
  24. #23
    Join Date
    Feb 2006
    Location
    Santa Rosa, NorCal
    Posts
    1,054
    Very true about the velocity stacks.
    One of the members did a flow test on a VW and on a Veilside manifold and the stacks did disrupts the air flow and creates less CFM than one without it in that test, which is on the Veilside mani. Read your heart out.
    http://supraforums.com/forum/showthread.php?t=166026
    And from RMR, those stacks are $40, so that is 240$ off from material list already. And you can get schedule 40 aluminum tubing fairly cheap depending on size and length.
    And yes, assuming labor is free
    But nonetheless, the manifold looks great!
  25. #24
    Join Date
    Feb 2006
    Location
    Santa Rosa, NorCal
    Posts
    1,054
    Quote Originally Posted by SDstreetracer View Post
    Those air horn looks good, very creative on getting in the blend, instead of grinding it down.
    Did you made those air horns yourself, or is it from RMR?
  26. #25
    SupraForums Member
    Join Date
    Nov 2005
    Location
    so,cal
    Posts
    721
    air horns
    We purchased them from rmr
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
