+ Reply to Thread
Page 6 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 126 to 150 of 228
Thread: Fender modification pics
  1. #126
    SupraForums Member brianmoss69's Avatar
    Join Date
    Jan 2008
    Location
    Orlando
    Posts
    1,857
    what do you guys mean by pulling the fender i have mine all grinded down. but im still rubbing.
  2. #127
    SupraForums Member FASTEDDIE's Avatar
    Join Date
    Jun 2005
    Location
    maryland
    Age
    32
    Posts
    593
    At what point in cutting/grinding is too much. I rolled my rears then ending up cutting/sealing/painting. Now I have a new setup and have some rubbing issues, I'd rather not jack the car up and was thinking about grinding some more but I am worried about the inner panel and quater seperating. Is this possible?
  3. #128
    Stock Body Supras FTW SupraRy95's Avatar
    Join Date
    Oct 2004
    Location
    Palm Harbor, Dunedin Fl
    Age
    34
    Posts
    1,177
    At what size rim width wise do you have to cut or roll the fenders? Is it 11inch and bigger? I know most of it depends on the size of tire to.
  4. #129
    Newbie nautica2o3's Avatar
    Join Date
    Feb 2002
    Location
    Connecticut drivers suck!
    Age
    31
    Posts
    1,141
    Do you guys cut into the plastic mold towards the rear of the car, or just up to it?
  5. #130
    Is it turbo? Is it stick? TROLL's Avatar
    Join Date
    Dec 2007
    Location
    Stuart, FL
    Posts
    4,347
    I only cut up to it but thats actually where I found I was rubbing the most, so I might try to trim at least a little bit off of there, but I haven't tried yet.
    I actually found that on cut fenders it is only rubbing from 12 oclock and rearward, nothing forward of that... thought it was kind of strange but thats how it is for me.
  6. #131
    ELITECUSTOMBODY exvelocity's Avatar
    Join Date
    Dec 2002
    Location
    Jacksonville Florida
    Posts
    6,399
    Quote Originally Posted by nautica2o3 View Post
    usually if you're going with agressive offset or 305-up ,the upper portion of that trim piece needs to be cut or trimmed
    _Stefan B
    elite custom body + paint
    do what's right,not what's easy
    Need professional advice or opinion on body/paint/assembly or cosmetic related issues?Just ask.
    http://www.facebook.com/ELITECUSTOMBODY
  7. #132
    Wingless by Choice poorman's supra's Avatar
    Join Date
    Apr 2005
    Location
    UT
    Age
    27
    Posts
    1,423
    Thought I'd share mine. Mine have been grinded down then fiberglass was added for Strength in the fender well.
    Devin P.
    94 TT Red/Tan factory wingless 53k miles.
  8. #133
    Join Date
    Dec 2007
    Location
    Stuart, FL
    Posts
    4,347
    I find my point of least clearance is at the rear where the trim piece starts... I'm going to shave a bit of that off to give myself a little more room back there. basically trim it right up to the top fastener, but leave the head of the fastener in tact.
    (On the drivers side), I have 0 rubbing issues from 9 o'clock to 12 o'clock, but I do have issues from 12 o'clock to 3 o'clock (and its the opposite o'clocks on the passenger side). Thought that was kind of strange but I guess thats how it is with Supras...
  9. #134
    Join Date
    Dec 2002
    Location
    Posts
    6,399
    Quote Originally Posted by TROLL View Post
    I have 0 rubbing issues from 9 o'clock to 12 o'clock, but I do have issues from 12 o'clock to 3 o'clock. Thought that was kind of strange but I guess thats how it is with Supras...
    that's pretty normal, all MKIV's will have rubbing at 3 o'clock with bigger wheel/tires combo,that's the way they were built,that area is not as wide as 9 o'clock
  10. #135
    Turbo on the Brain
    Join Date
    Aug 2002
    Location
    Waco, Texas
    Posts
    2,711
    I have put 27 inch diameter tires on my car. I agree with TROLL the most rubbing occurs at the beginning of the front and rear plastics.
  11. #136
    Join Date
    Dec 2002
    Location
    Posts
    6,399
    still the most rubbing will be in the rear of the wheelwell ,right at the tip of the quarter trim
  12. #137
    Join Date
    Dec 2007
    Location
    Stuart, FL
    Posts
    4,347
    Yeah... and I just edited my post to clarify since I realized that 3 o'clock on the drivers is different than on the passengers, I mean its at the rear of the wheel wells where that plastic trim piece starts, which you know I'm sure but others might not.
  13. #138
    we always use a rubber coated baseball bat and utilize the tire on the car to roll a fender, works perfect if you know what your doing and it's free
    "Live Fast Die Hard"
    white 97 limited edition TT bpu "sig"
    Red 2005 BMW Z4 drop top
    white 1989 Z28 with built 350 400hp
  14. #139
    HK USP 45c
    Join Date
    Oct 2007
    Location
    Walnut Creek/Sac CA
    Age
    26
    Posts
    267
    Problem with that is there's a learning curve...which most people wouldn't want to lean on their Supra.
  15. #140
    Join Date
    Dec 2007
    Location
    Stuart, FL
    Posts
    4,347
    Quote Originally Posted by redtargatopturbo View Post
    you do this without pulling the fender or cracking the paint?
    the only people i've ever seen do that dont really care much about how the finished product looks...
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
  16. #141
    yeah I have never cracked the paint, if you have never tried it before you may not want to start on a supra, but zzt23-...thats why I said "if you know what your doing"
  17. #142
    SupraForums Member 95mkiv's Avatar
    Join Date
    Jul 2008
    Location
    Escondido, Cali
    Age
    32
    Posts
    436
    I rolled mine a bit with the rolling tool but, belive it or not supra's have some heavy duty sheet metal on the Q-panels because it was a bitch to do.
    I was gonna have my body shop cut them but, he said DO NOT cut them.
    The reason is that the q-panle sheet metal is welded to the fenders and thats why there is a few spot welds on the inner lip & it makes it difficult to roll. I was told if you cut them it could cause the Q-panels to vibrate/shake and it reduces the strenght of q-panles.
    HKS T04Z, HKS VPRO
  18. #143
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Philadelphia,PA
    Age
    37
    Posts
    1,764
    Quote Originally Posted by JamesN1830 View Post
    yes and yes. Trailors are a pain no longer!
    Good idea, I just hope no one ever steals it, that would make for a quik get away.
    9.73 @142 (2004) Daily Driven
    Drag Video Here http://www.youtube.com/watch?v=Oukz1GTfV-o
  19. #144
    Newbie
    Join Date
    Jun 2009
    Location
    Walsall, UK
    Posts
    2
    just a bit of technical help for those that dont understand the terms
    http://www.archenemy.co.uk/tech.htm
  20. #145
    SupraForums Member
    Join Date
    Aug 2006
    Location
    NJ
    Age
    26
    Posts
    2
    NIce...
  21. #146
    Newbie
    Join Date
    May 2008
    Location
    Arcadia, CA
    Posts
    5
    Quote Originally Posted by zzt23- View Post
    I'm with you, wouldn't want to do it with a bat with no experience.
  22. #147
    SupraForums Member
    Join Date
    Jul 2009
    Location
    NYC
    Posts
    202
    Quote Originally Posted by adamroutley View Post
    Wow thanks. I read through all 6 pages guessing at what everyone was talking about.
    On my brother's m3 the rear fender was flared. Probably the sexiest looking rear end I've seen in my life.
    Infiniti Q45 1997
    Infiniti Q45 2005
  23. #148
    Join Date
    Dec 2007
    Location
    Stuart, FL
    Posts
    4,347
    I had the bodyshop cut my rear fender lips off before they painted... they did an awesome job. The edge is very low profile but still slightly rounded so its not sharp at all... they put seam sealer up in between the panels and redid the undercoating. I talked to quite a few people about cutting it before I went ahead with it but in my research I never found anyone who had a problem with cutting, just theories with no backing. Speaking to a bodyshop that does a lot of work on Supras as well as a few other owners, all those who have cut them have had 0 problems so I felt fine with it.
    The one thing they left is they didnt trim any of the plastic rear trim piece which clips to the rear bumper. The top corner of that is the point of least clearance still so I'm going to shave the corner of it off so its not sticking out in the way any more.
    I'll get some photos next chance I get with the wheels off, looks 'factory' though .
  24. #149
    SupraForums Member
    Join Date
    Jun 2006
    Location
    Cardboard box down by the river
    Age
    34
    Posts
    290
    anyone want to rent me the tool?
  25. #150
    Junior Member
    Join Date
    Apr 2008
    Location
    Las Vegas
    Posts
    118
    Quote Originally Posted by rawfish View Post
    What tool....here you go bro!!!!
    http://www.youtube.com/watch?v=Wxmw-4A0DEQ
    The lesson starts about 1 minute in. To pull the fender simply keep going untill the desired amount is there.
    Here is my car fresh from paint with a 2" pull all around to clear 275's and tuck! 18 x 10 +0.
    After setting camber and height. Baseball card clearance fellas!!!
    [IMG][/IMG]
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
