LS400 Front Brake Upgrade..The Easy way!
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 62
Thread: LS400 Front Brake Upgrade..The Easy way!
  1. #1
    EFI Certified Tuner dejacky's Avatar
    Join Date
    Feb 2004
    Location
    Traveling Tuner
    Age
    36
    Posts
    1,877
    Thumbs up LS400 Front Brake Upgrade..The Easy way!
    The Lexus LS400 brake calipers (1995-2000 models) are more powerful 4-piston calipers that are also lightweight compared to stock sc300/sc400 and mkiv Supra NA calipers. They stop these cars a lot better, were designed to stop the ls400 cars from 150pmh to ZERO mph, and are easy to install. Here is how I did mine:
    1) Remove your wheels and lug nuts
    2) Our Brake Calipers are held in place by TWO 17mm bolts. Unscrew these and the brake caliper is now loose and slides off the brake rotor (aka disc). Since the lug nuts are off and you've just removed the brake caliper, there is nothing securing the brake rotor (aka disc) in place. So, slide the brake rotor off the wheel studs and replace it with a LS400 brake rotor.
    3) Put the wheel lug-nuts on and hand tighten to keep the new LS400 brake rotor steady & secure.
    4) Make sure you Hammered/Bent/Cut parts of the sc300 brake dust shield to fit the LS400 brake calipers & rotors.
    5) Place LS400 calipers on the rotor and align the TWO mounting holes. Install TWO LS400 17mm Brake Caliper bolts (shorter than sc300 ones) and torque them to 87 ft/lbs of torque.
    6) Disconnect your stock brake lines from the sc300 brake caliper (2-piston inferior design) and screw that same bolt-brake line into your LS400 calipers = very simple. You're just plugging the same brake line, that was in the sc300 caliper, into the LS400 caliper.
    7) Bleed your brakes properly!
    http://www.3dprinteros.com (Secure 3D Printing = FTW)
    EFI-Advanced Certified Car Tuner
    Figgie: How in the name of Sir Isaac Newton does "25 lbs" of air become "40 lbs" of air?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member Anthracite93's Avatar
    Join Date
    Aug 2003
    Location
    Langhorne, PA
    Age
    34
    Posts
    330
    nice pics/write-up
  4. #3
    2JZ-Phantom SealSupra-6's Avatar
    Join Date
    Nov 2004
    Location
    Sac, California
    Age
    34
    Posts
    2,117
    dejacky, will these caliper clear the stock rim size or do we need to upgrade to 17 inch rims?
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    !black MadMaxx's Avatar
    Join Date
    Dec 2002
    Location
    South East region
    Posts
    4,625
    Welcome to 3 years ago
  7. #5
    SupraForums Member Suprazzz's Avatar
    Join Date
    Jan 2005
    Location
    PA
    Posts
    281
    Good info.Now I just need to find the calipers and rotors.
  8. #6
    SupraForums Member javi1012's Avatar
    Join Date
    Jul 2004
    Location
    nowhere
    Posts
    538
    same here clublexus here i come
  9. #7
    Join Date
    Feb 2004
    Location
    Traveling Tuner
    Age
    36
    Posts
    1,877
    Quote Originally Posted by MadMaxx View Post
    I was never satisfied with any of the previous write ups that didn't show good pictures of what exactly needed to be done ;p . You will need at least ls400 wheels (16inch) or 17inch + wheels to clear these brake calipers.
  10. #8
    SupraForums Member
    Join Date
    Apr 2006
    Location
    Sacramento
    Age
    38
    Posts
    338
    does everything bolt up perfect because in other write up it saids you have to trim part of the caliper to fit properly and also you have to change the brake lines but from you write up it seems like everything fits perfectly?
  11. #9
    Join Date
    Nov 2004
    Location
    Sac, California
    Age
    34
    Posts
    2,117
    you have to trim the brake dust shield.
  12. #10
    Join Date
    Feb 2004
    Location
    Traveling Tuner
    Age
    36
    Posts
    1,877
    Quote Originally Posted by SealSupra-6 View Post
    correct. I bent back parts that didn't need to be cut and just cut the necessary parts of the brake-shield off. It's probably best to cut the entire shield off, but since my cutter was very coarse, I wanted to minimize potential for slipping and slicing an important brake part off . Since I'm using mkiv Supra twin turbo wheels (17inch and high-disc fitment compatible), my calipers didn't need to be cut or modified in any way.
  13. #11
    SupraForums Member zupar1187's Avatar
    Join Date
    Jun 2006
    Location
    orlando fl
    Posts
    177
    where can you get performance rotors for the ls400 calipers?
  14. #12
    Addicted to Boost hksyota88's Avatar
    Join Date
    Apr 2003
    Location
    Land O' Lakes Fl.
    Age
    31
    Posts
    336
    will this work for a mk3 supra? this seems like a good upgrade... i like it
    87 Supra Turbo -Sold
    91 240sx HB-Sold
    93 240sx coupe with s13 silfront-Sold
    89 Supra Twin Turbo Targa(1g-gte)Sold
    95 240sx SE'-Sold
    97 Acura CL 2.2 vtec-totaled
    98 4runner 2wd 2.7 (3rzfe)
  15. #13
    Join Date
    Feb 2004
    Location
    Traveling Tuner
    Age
    36
    Posts
    1,877
    You use the same procedure for installing supra twin turbo brakes too. I know that supra tt 17in wheels fit the mkIII supras, so perhaps mkIII cars can accept this brake upgrade too. I just got good oem quality (made-in-usa) LS400 rotors from NAPA for ~$74 for the front pair.
  16. #14
    Found E85 NOT in NJ! twinturbosupra94's Avatar
    Join Date
    Jul 2004
    Location
    Wayne, NJ
    Age
    29
    Posts
    5,251
    sweet job dejacky +1
  17. #15
    Join Date
    Apr 2003
    Location
    Land O' Lakes Fl.
    Age
    31
    Posts
    336
    so thats all that needs to be done with TT brakes>?..... how big are the LS400 rotors?
  18. #16
    Join Date
    Feb 2004
    Location
    Traveling Tuner
    Age
    36
    Posts
    1,877
    Quote Originally Posted by hksyota88 View Post
    LS400 brakes are ever-so-slighty smaller than the Supra TT brakes. For all intensive purposes, they supra TT front brake calipers and rotors are practically the same size as the LS400 ones...if I remember correctly it's a rotor diameter difference of about 0.75 inches...
  19. #17
    SupraForums Member
    Join Date
    Jun 2006
    Location
    pittsburgh
    Posts
    220
    So is there an upgrade for the rear calipers too?
  20. #18
    Join Date
    Apr 2003
    Location
    Land O' Lakes Fl.
    Age
    31
    Posts
    336
    good writeup ..i now need to make decisions
  21. #19
    Moderator
    l337 M0d3r4t0r
    ZaZZn's Avatar
    Join Date
    Feb 2002
    Location
    Toronto/San Francisco
    Age
    34
    Posts
    12,865
    highly doubt it will work on a mk3 as it probably needs the nighpager adapters too
  22. #20
    Join Date
    Jul 2004
    Location
    nowhere
    Posts
    538
    i was wondering the same thing, what options are there for the rear brakes?
    if these are so cheap, could a group buy be made for a full kit calipers, rotors, pads, brake lines for the front brakes for us NA?
  23. #21
    SupraForums Member
    Join Date
    Mar 2003
    Location
    nyc
    Posts
    1,007
    i have a set of front calipers from a ls400, 220 shipped for the set(calieprs, pads, pins, shims, etc)
    all you need to purchase are some rotors.
  24. #22
    Newbie michaelvanle's Avatar
    Join Date
    May 2003
    Location
    South Jersey
    Posts
    11,219
    Quote Originally Posted by dejacky View Post
    You don't really need a write up with pictures for this. It's very straight forward.
    Unbolt caliper, take out rotor, install rotor, bolt on new caliper, bleed.
  25. #23
    Join Date
    Feb 2004
    Location
    Traveling Tuner
    Age
    36
    Posts
    1,877
    Thumbs down
    Quote Originally Posted by michaelvanle View Post
    And you really don't need to make more useless posts than you already do that contribute nothing to the thread topic.
  26. #24
    wasting my life on SF muchoboosto's Avatar
    Join Date
    Jul 2006
    Location
    Haslet/Arlington TX
    Age
    30
    Posts
    1,807
    maybe an uber stupid/nooooooob question. but, this is a viable upgrade to na mkivs correct? the 400 brakes are still superior to the supra brakes?
    thanks and sorry for the dumb assery
    Click here to enlarge
    1994 Supra NA-T/R154
    1968 Dodge Charger 440/727 AUTO
    1968 Dodge Charger Drag Car-full tube chasis on 32x14x15s
    My site,
    www.backoutofwhack.com
  27. #25
    Join Date
    May 2003
    Location
    South Jersey
    Posts
    11,219
    If you are talking about the TT brakes, I wouldn't say it's better, by any means, than the TT's. I think it might be lighter though.
    You get a free cookie from SF if you reach 10k post, so I was told.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
