Head porting with oversize valves-cost?
+ Reply to Thread
Results 1 to 16 of 16
Thread: Head porting with oversize valves-cost?
  1. #1
    SupraForums Member
    Join Date
    Jan 2003
    Location
    GlenBurnie, Maryland
    Age
    43
    Posts
    2,644
    I'm in the process of having my motor fully built. Everything for my block is already ordered and being rebuilt. But I can't make up my mind what I want to do with my head. I want it ported, polished and rebuilt. But I can't make up my mind if I want to go with oversize valves. I was quoted a price of $1250 for a fully rebuilt head with porting, polishing, multiangle valve job, bowl work, flow tested and a few other things. My question is how much added expense is using oversized valves, and is it worth it? What kind of prices have you all paid-if you don't mind me asking? Thanks..
    -92 supra turbo
    Built 7M/6262 495rwhp pump gas
    2011 Mustang GT
    399rwhp-twin turbo time.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    I Love Lamp... selz202's Avatar
    Join Date
    Feb 2004
    Location
    Maple Valley Wa
    Age
    27
    Posts
    2,184
    What horsepower are you going for? Id say if you're at 500 and you added a 1 over valve it'll add an extra 20-30.
    I know Duane mentioned his motor probably gained alot more.
    Alot of quotes i got from the machine shops varied alot... it almost seemed as if they had no clue and just pulled the prices out of thin air. Anywhere from an extra $200 to an extra $900. With 24 valves i would expect to pay around $15-$20 each, but you may find even cheaper.
  4. #3
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Age
    43
    Posts
    2,644
    My goal is low to mid 600rwhp on a 67mm turbo, enough to get me a 10 second 1/4 mile time. I'm sure I can reach those goals on a stock head, but I figure with better breathing, I can do it easier with less boost.
    I plan on getting the BC 264 cams (if they ever come in) to compliment the head work.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    JZA70 448 rwhp everyday scottiedawg66's Avatar
    Join Date
    Dec 2002
    Location
    California, Bay Area
    Age
    33
    Posts
    2,989
    head work depends alot on the shop. When i was lookin to get a built head I was quoted $3000 for a totally built ported polished head. bronze valve guides, 5 angle job, port polish, port match, +1mm ferra valves, re surfaced, valve stems, valve springs, and i had to supply cams.
    ~scott
  7. #5
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Age
    43
    Posts
    2,644
    Thanks for the info Scottiedawg. I'm just trying to get an idea.
  8. #6
    tire killer need new tires's Avatar
    Join Date
    Aug 2004
    Location
    Dayton, Ohio
    Age
    31
    Posts
    437
    if you do the porting yourself and have the machine work done on a flat head it will be around $600.
    285 for the 1mm valves
    60 for the comp springs
    187.50 for the vavle job(what i was quoted this week)
    anything else is going to change the price but that should give you a ball park number.
    -shane
  9. #7
    SupraForums Member newbsupra's Avatar
    Join Date
    Jun 2006
    Location
    Sask, Canada
    Posts
    189
    Is something like this worth getting done on a stock 7mgte? Or? My goal is 300rwhp.. And my head is off right now.
  10. #8
    Join Date
    Dec 2002
    Location
    Age
    33
    Posts
    2,989
    no, you can spend the money elsewhere and net more power per dollar.
    ~scott
  11. #9
    Join Date
    Dec 2002
    Location
    Age
    33
    Posts
    2,989
    Quote Originally Posted by MRSUPRA View Post
    "More than u can afford pal"
    ~scott
    JZZ31 drift build in progress. Previously MK3 owner for 12 years, single 1jz swap in 2005, 448 rwhp.
  12. #10
    SupraForums Member gilberjj's Avatar
    Join Date
    May 2006
    Location
    Washington
    Age
    30
    Posts
    936
    Quote Originally Posted by scottiedawg66 View Post
    ~scott
    wow... priceless
  13. #11
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Age
    43
    Posts
    2,644
    Listen, I'm very serious about this. Enough of the Fast and the Furious talk.... The reason I need this head work advise, is because I live my life a 1/4 mile at a time, for those 10 seconds or less, I'm free.
  14. #12
    Join Date
    Dec 2002
    Location
    Age
    33
    Posts
    2,989
    waaaahahaahahahaha awesome response! Ive got some overnight parts from japan that would make that 2jzge decimate all.
    ~scott
  15. #13
    Join Date
    Jul 2006
    Location
    ocala
    Age
    32
    Posts
    1,586
    1mm oversized valves can use the stock seats, maybee even 1.5 os... but any bigger than that and your looking at spending 20 per valve seat... big money
  16. #14
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Age
    43
    Posts
    2,644
    I'm no head expert, but doesn't that defeat the purpose of using oversize valves if you are going to keep the stock size seats?
  17. #15
    Grumpy Old Man
    Join Date
    Oct 2005
    Location
    AUS
    Age
    54
    Posts
    4,210
    Stock seats but they open up the throat to suit the 1mm os valve.
    Any larger than 1mm and you start shrouding the valves and this hurts flow, even at 1mm you really need to work the combustion chambers to suit.
    LMAO @ the FnF refs!
  18. #16
    SupraForums Member
    Join Date
    Jan 2003
    Location
    Age
    43
    Posts
    2,644
    I see. Thanks..
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
