wiring diagram for keyless entry/remote start
+ Reply to Thread
Results 1 to 4 of 4
Thread: wiring diagram for keyless entry/remote start
  1. #1
    SupraForums Member
    Join Date
    Jul 2004
    Location
    NJ
    Age
    31
    Posts
    559
    Does anyone have a wiring diagram for installing a basic keyless entry/ remote start system on a 1989 turbo 5spd? mine also has the stock alarm system.. thanks to anyone who has this info, trying to install a compustar 1W900FM-S
    1989 MK3 60-1
    2001.5 Audi S4 2.7T - stock
    Click here to enlarge
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    THE LAST NA SupraCooled's Avatar
    Join Date
    Mar 2009
    Location
    Bohemian Grove, CALIF
    Posts
    1,228
    bump
    WTB ASAP: ABS COWL/DASH harness, glove box striker, wheel bearing dust cover FL.
    WTS: NEW AND USED SPEEDO CABLE, 83710-14700, 89+ 7MGE INJECTORS, AND RADIATOR SHROUD
    WTB: 340E TRANS, 3:73+ DIFF, NA ENGINE HARNESS, AFTERMARKET DOWNPIPE AND EXHAUST, WIPER SPRAY NOZZLE, BRAKE CYLINDER, FLOOR MATS, HEATER VALVE, GAS TANK LID, HOOD STRUTS, REAR STRUTS, TRUNK STRUTS, TRUNK SEAL, OEM CD PLAYER, MAROON INTERIOR PARTS, STEERING WHEEL, WHITE TARGA TOP, WHITE HOOD, ANTENNA AND MOTOR, DRIVERS DOOR LOCK, DRIVERS WINDOW SWITCH, KEY IGNITION SHROUD, GLOVEBOX SHROUD, FUEL SENDER GAUGE, BLOWER MOTOR, THERMOSTAT HOUSING, AND A GOD DAMN WORKING CUP HOLDER.
  4. #3
    Join Date
    Feb 2011
    Location
    Wichita Falls Texas
    Posts
    42
    Old Thread, but that means you obviously found this by searching.
    Hope this will help
    http://www.the12volt.com/installbay/...tail/2128.html
    Its pretty basic and most companies such as Viper or Compustar have a million how to videos for other cars you can use as reference, just search Youtube.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Registered User porn-adkt's Avatar
    Join Date
    Mar 2002
    Location
    Up in Vagina next to the Anus
    Age
    42
    Posts
    3,366
    Quote Originally Posted by supracooled View Post
    bump
    fucking Google
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
