Coolant hose
+ Reply to Thread
Results 1 to 8 of 8
Thread: Coolant hose
  1. #1
    grease monkey kronizer's Avatar
    Join Date
    Jun 2006
    Location
    Penticton
    Age
    28
    Posts
    317
    Coolant hose
    the final task before i can drive my supra again.... a coolant hose which i have pointed to in cygnusx's diagram it is on the exhuast side at the back of the engine and pokes about 3 inches from the block
    and this is wat it looks like
    TIA
    Cameron
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    =1/2π(√k/m) MK3Brent's Avatar
    Join Date
    Feb 2003
    Location
    Pittsboro NC
    Posts
    9,724
    Then what happened?
  4. #3
    NO SOUP 4 U IamWedge's Avatar
    Join Date
    May 2007
    Location
    (Live) Duluth, MN / (work)Minneapolis, MN
    Age
    53
    Posts
    1,683
    Blog Entries
    3
    Thats the line that is blocked off? I just used a 3-4" piece of heater hose and a Brass plug with clamps to hold it all in place. You dont have too much to do to get it running.
    Wedge
    Its not getting any smarter out there. You have to come to terms with your stupidity and make it work for you. FZ
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member PbXAssassinX1524's Avatar
    Join Date
    May 2004
    Location
    NNJ
    Age
    28
    Posts
    1,251
    Just felt like using some bandwidth?
  7. #5
    Join Date
    Jun 2006
    Location
    Penticton
    Age
    28
    Posts
    317
    the other side is plugged (intake side). so should they both be plugged or is the wrong side plugged? the diagram that i linked has one side plugged (intake) but not the other
  8. #6
    Join Date
    May 2007
    Location
    Age
    53
    Posts
    1,683
    Blog Entries
    3
    I have an 87 Supra T On mine... the exhaust side is plugged. If thats the way you got the car.... might as well stick with it. Im sure the coolant flows the same way. I asked about this before. I was told that Turbo and NA models switch plugged sides. Also the right hand drive models switch sides.
    Wedge
  9. #7
    SupraForums Member
    Join Date
    Nov 2005
    Location
    Southlake, Texas
    Age
    35
    Posts
    3,877
    89+ didn't use the same hardpipes for all the versions, so they don't have that horrible cap...
  10. #8
    Supra Moderator Zumtizzle's Avatar
    Join Date
    May 2006
    Location
    NorCal
    Posts
    4,595
    Quote Originally Posted by IamWedge View Post
    Wedge
    You're Right.
    Quote Originally Posted by kronizer View Post
    That Link You sent is a Non-North America Car. If you look, you will see the Driver side running to the Heater Core. and the Passenger or Turbo/EX side plugged.
    Welcome to my nightmare!
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
