+ Reply to Thread
Results 1 to 13 of 13
Thread: Antifreeze boiling over in overflow
  1. #1
    Wheel Whore SupraWillis's Avatar
    Join Date
    Mar 2003
    Location
    UT
    Age
    32
    Posts
    1,925
    I know I know another annoying question but the search is mia.
    I'm just curious to know if anyone else has experienced this. After driving, my antifreeze is bubbling and/or seems like it is boiling in the overflow tank. I have a fluidyne and there can be a few variables. I also forgot to mention that I am not overheating the temp needle stays in the middle.
    My questions are:
    1. Would there be obvious signs of a blown headgasket such as the red toyota antifreeze getting into the oil. (In my case no because I checked the oil).
    2. Bad radiator cap/thermostat? Although I have a fluidyne I do not have a fluidyne rad cap it is a generic rad cap.
    3. It has never done this before up until this week however we have been hitting 100+degree temps this week. Could it just be getting hot and I have air inside the system?
    Other than that I think it might be a blown headgasket because I've been running it at the track. And I am running rich (10.9-11.0 AFR's) on 1 bar and pump gas but at the end of the night my exhaust tip is white as if there were a powdery residue on it.
    I just want to get some opinions before I roll up my sleeves and tear the head off. Thanks for any help sorry for the novel, I wanted to be as specific as possible describing all my symptoms.
  2. #2
    When cars say, "NO MORE!" SJ's Avatar
    Join Date
    Apr 2002
    Location
    PA
    Age
    30
    Posts
    2,112
    radiator cap then head gasket
    generally when the HG is bad it will blow coolant out the overflow while driving not afterwards. I would stay away from that idea.
  3. #3
    SupraForums Member
    Join Date
    Feb 2001
    Location
    San Diego & Spring Valley, CA.
    Age
    36
    Posts
    1,081
    SupraWillis, I had the same thing happen to me and it ended up being the radiator cap. Found out the rubber part with the spring had broken.
  4. #4
    i always say toyota !
    Join Date
    May 2003
    Location
    bayarea, CA
    Age
    35
    Posts
    2,762
    if it only bubbling after driving. it could be something loose. hose, clamps, plugs.... or like the guy above the cap.
    which means you got a very very small leak.
    lets go !
  5. #5
    Join Date
    Mar 2003
    Location
    UT
    Age
    32
    Posts
    1,925
    Thanks for the replys everyone. Just for example, I took it out yesterday for some gas. then on the way back i did about 3 pulls. When I shut the car off the antifreeze was bubbling/boiling in the overflow tank. I didn't get a chance to see whether if it was doing this while the car was running. I had to tear off the turbo kit this afternoon to let a friend borrow it.
    Thanks again for the replys.
  6. #6
    Join Date
    May 2003
    Location
    bayarea, CA
    Age
    35
    Posts
    2,762
    Quote Originally Posted by SupraWillis View Post
    now sounds like you have a bad head gasket.
    get ready.
  7. #7
    The GT-R hate is strong. Dego Red's Avatar
    Join Date
    Apr 2005
    Location
    Overhaulin'
    Age
    32
    Posts
    1,021
    When mine let go (at 7psi during clutch break-in, ironically enough), I lost coolant out the overflow and also had a very definative, audible bubbling somewhere between cylinders 2 & 5. I guess its a moot point since you cant start the car to check...BUT, even if you don't have coolant in the oil, you may have oil in the coolant. I ended up with both.
    Just an FYI of my experience I guess. Hope it's nothing serious - Good luck!
    << UNDER CONSTRUCTION >>
    '97 DJG 6spd | PT6765 - 1000cc - AEM - Stock long block
    11.14@122mph, 1.64 60' - pump/18psi
    507whp, 92oct
    743whp, C16
  8. #8
    SupraForums Member
    Join Date
    Apr 2006
    Location
    MD
    Age
    31
    Posts
    265
    Typically headgaskets blow between the cumbustion chanbers and the water jacket. I'm not sure why everyone is talking about oil in coolant and vise versa. I guess your not getting any smoke while driving? So there is not coolant being burned. I have never seen a HG cause bubling after the car is shut off, because there is no combustion taking place. However, if you were blowing compression into the water jacket while driving and not kowing it then when you stop it could continue to boil out the air in the system.
    E
  9. #9
    Wholesome creamy goodness Supraman16's Avatar
    Join Date
    Apr 2001
    Location
    Burbank, CA
    Age
    34
    Posts
    594
    I had the same issue about 2 weeks ago...turns out to be a bad radiator cap. Trying changing this first, it's the least expensive thing to do before changing out your headgasket, radiator, etc. I paid 10 bucks for a new radiator cap and so far it's holding up like a champ!...Darshana S...
  10. #10
    19in 795R HRE's FTW.... WOTM's Avatar
    Join Date
    Feb 2001
    Location
    AZ
    Age
    32
    Posts
    6,670
    It can be air in the cooling system as well... Burp it, check the cap, etc.
    Then go eat some Layton Rolls
    Ryan Woon
    Best 1/4 8.37@177.47mph
    Best Mph 179.47mph
    Best 60ft 1.31
    Former Worlds Quickest AND Fastest 6spd Supra
    WOTM AUTO 8.28@170 on Drag Radials
    New 6spd Car: 1406rwhp All Boost 1.31 60ft
    And Larry is Gay
  11. #11
    Join Date
    Mar 2003
    Location
    UT
    Age
    32
    Posts
    1,925
    Quote Originally Posted by WOTM View Post
    Can't do anything until Cody is done with my turbo kit!
    And I don't know why you and Gina didn't like those. I had two orders for lunch today! Deep frid goodness in wasabi mayonnaise, which by the way was the special sauce...mmmmmmmm
  12. #12
    Supra Owner Since 1996 Hands On's Avatar
    Join Date
    Dec 2003
    Location
    Idaho
    Age
    31
    Posts
    2,721
    I don't know if mine is boiling over, but after some spirited driving, some coolent is pushed into the puke tank. Well it filled up and now out the overflow. Did it before I pulled my head and replaced the gasket (unrelated issue) and after. I have never changed my radiator cap. I figure if it's not over heating or loosing power, give her hell!
    KO Racing T04R | KO Racing 1000cc fuel system | AEM | RPS C/C | KO Racing intercooler | KO Racing 4" exhaust
  13. #13
    SupraForums Member Supraofthecorn's Avatar
    Join Date
    Jan 2009
    Location
    South of Chicago
    Posts
    274
    I seem to be having a similar issue with my car the overflow cap is popping off under boosted conditions and spraying waiting on a radiator cap then burp the system again. It doesn't smoke while driving haven't found any tell tail signs in the radiator fluid or the oil that I have a blown head gasket so hoping its the cap.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
