+ Reply to Thread
Page 10 of 79 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 60 ... LastLast
Results 226 to 250 of 1968
Thread: Stock twins replacement/upgrade - Hybrid GT28R's
  1. #226
    SupraForums Member
    Join Date
    Apr 2001
    Location
    Cerritos, CA
    Posts
    1,549
    Any new updates from anyone?
  2. #227
    SupraForums Member
    Join Date
    Feb 2001
    Location
    Hilliard, OH
    Posts
    365
    Triple T
  3. #228
    SupraForums Member
    Join Date
    Apr 2007
    Location
    Las Vegas/San Diego
    Posts
    349
    Virtual Works installed my (Stu and Aaron) Hybrids. They also did the wastegate spring mod although my boost still drops at redline about 2 psi. I only have the bleeder T mod to control boost for now which is a big issue. I am boosting 14-15psi with a second of 16psi. I am going to get a MBC and turn it up to 19-20 psi and tune my SAFC-2.
    The turbos seem really laggy though. Well maybe just the second turbo, it's hard to tell. The first turbo seems to boost up instantly but it takes all the way untill 5k maybe more rpm to get full boost with both turbos. I don't know if this is because the bleeder T mod or what.
    The turbos seem to have a lot of potential though. It seems like they have way more in them, which I'm sure they do. Will I have to use a boost controller for both turbos like Stu to eliminate the second turbo lag?
  4. #229
    GO 'Cats! bonz's Avatar
    Join Date
    Sep 2005
    Location
    Austin/South Padre Island, TX
    Posts
    1,002
    Hammerhead...any news? I hope all is well with the Dawg and fuel system/upgrades etc.
  5. #230
    Join Date
    Oct 2005
    Location
    in the casino. LV
    Age
    32
    Posts
    158
    stock fuel... meth kit with 100% meth for added fuel 21.4psi falling to 20.5 by redline 500/480. Feels great. Under closer examination Turbos are definitly laggy. Not incredibly noticable on the street.
    Even with a Huge spring on the WG I cannot make anymore than 21.5psi. I think the OEM WG actuator was stronger! I have some Ideas, if all else fails. Ill weld it shut and put a Tial on it.
  6. #231
    SupraForums Member
    Join Date
    Feb 2001
    Location
    Hilliard, OH
    Posts
    365
    Is there anyway you could post up some graphs?
  7. #232
    SupraForums Member 93 twintrbo's Avatar
    Join Date
    Sep 2004
    Location
    Bay Area
    Age
    35
    Posts
    3,020
    Quote Originally Posted by Hwilli View Post
    2nd that also.
  8. #233
    SAP R/3 Guru 2DIE4's Avatar
    Join Date
    Sep 2001
    Location
    Sweden of course home of the Vikings
    Posts
    907
    Would be intresting to know if there are any difference between the "Hammerheads" and the CT/T28 that Tomsid used a few years back ?
    http://www.supraforums.com/forum/showthread.php?t=79889
  9. #234
    Stock Twins King Stu Hagen's Avatar
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    3,701
    Quote Originally Posted by 2DIE4 View Post
    Don't think you will ever get a good answer on this. As I recall, he dyno'd in the mid 300's with these hybrids. Was really dissapointed. Had issue with the actuators. By the time he got around to getting things in order, he sold them off. Then, the new owner of these got his car stolen with the Hybrids and all. That is where it all died away. But they were almost identical to ours.
    There is so many other factors involved in order to compare things. So far, hammerheads GT28's have not proven any gains to the T3 Aarons. Which really doesnt surprise me since these are so close in design, power wise. ALthough hammerheads dyno at around 500 is from a basic BPU car. So that is encouraging.
    I assume he will be posting up his latest dyno here any day after fixing is wacky waastegate issues.
    1997 TT 6 Sp-GT28 Hybrid Turbo's
    2012 TX12 Dyno-623HP SAE 30-32psi. E85 tuned Vipec
    Technical Info/Scans & Specs
    New Sequential FAQ write-up Latest Drag Video: (ET 11.67 Trap 125.22) Click Here 3-Lap Warm-up at PR:Click Here
  10. #235
    SupraForums Member aaron300's Avatar
    Join Date
    Aug 2002
    Location
    Cincinnati OH
    Age
    43
    Posts
    281
    Quote Originally Posted by Boostys View Post
    Glad to hear that they got you up and running anyway. I don't know anything about the 'bleeder T' mod, so you might want to ask Stu directly about your set-up. You can definitely improve the spool on the sequential system with Stu's BC set-up, but you need to be carefull not to set the BC on the #2 too high or it will cause problems. I think for startes just leaving the #2 alone and getting a BC set up on the #1 should be good. Once you get that tuned in at 18-20 psi then you can think about adding a BC on #2 and delaying the prespool a little.
    Regards,
    Aaron
    89T 325 RWHP
    Ported head 1mm over valves
    Probe/Eagle/Std Clevite/Titan 1.4mm
    60-1 CT26
    Lex Afm Venom 550's
    Defcon DP, Blitz Nur Spec
    Profec B Spec 2
    3.73 Torsen ('Personal' model LOL)
    20X12X3 IC ($400 home brew kit)
    Apex-i SAFC
    Haste Radiator & twin Flex-a-lites
    XTD Clutch
    Autometer AFR & FP Gages
    Aeromotive AFPR
    Trust/Grex front strut bar, Eibach Springs, ST Sway Bars
    94 Supra TT
    Profec B Spec 2
    Old school Trust/Greddy Twin 3" catback 3" DP
    02 Lexus IS300
    Revived from the depths of repo hell
  11. #236
    SupraForums Member
    Join Date
    Apr 2001
    Location
    Cerritos, CA
    Posts
    1,549
    Quote Originally Posted by Stu Hagen View Post
    Stu,
    Did he use the stock exhaust manifold, or the new one that we saw earlier in this thread?
  12. #237
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    3,701
    Quote Originally Posted by Guido View Post
    Stu,
    This set up has to go back 3 years. At that time, I dont think anyone had ventured into a custom manifold like hammerhead has done. I'm almost positive that TomSid had the stock manifold.
    Stu
  13. #238
    Join Date
    Sep 2001
    Location
    Posts
    907
    Tomsid used a modified stock manifold and the last dyno he made around 420 rwhp here in sweden which propaby is like 450+ in the US since our dynos often show lower hp than the dynos in US, that power was made around 1,2 bar if i remember correct.
    I spoke with the company here in Sweden that still do the CT12/T28 hybrids and they are full BB so i think i will have a go with this setup.
    Stu
    A evil Protomotive Beetle :-).
    EU-Spec. 6-speed Supra MKIV aka Eagle II.
  14. #239
    Join Date
    Jan 2002
    Location
    Kirkland, Wa.
    Posts
    3,701
    I remember contacting a company called GK Turbo over there. Is the company your referring to? I also remember TomSid stating that he had over $5000 invested in these. A little steep for 3 years ago.
    Stu
  15. #240
    Join Date
    Sep 2001
    Location
    Posts
    907
    Correct the company is GIK in Gothenborg on the west coast the price nowaday for a set is around 24000 skr = $3400 but these are ballbearing T28 they say they are good for 660 hp for a pair , which seems to be the common sensus i have a pair of these for my Skyline as well.
    Stu
  16. #241
    Join Date
    Sep 2001
    Location
    Posts
    907
    Come on guys we want updates and more dynos on this setup ....... :-)
    Keep up the good work
  17. #242
    SupraForums Member
    Join Date
    Oct 2003
    Location
    Fairfax, VA
    Age
    27
    Posts
    131
    Yea i thought Ken Henderson was suppose to dyno his like last week?
  18. #243
    Twin Meister KenHenderson's Avatar
    Join Date
    Feb 2002
    Location
    SoCali
    Posts
    8,009
    Quote Originally Posted by Shabib67 View Post
    True, but my "to do" list is extensive, but that's not really the problem. Murphy's Law was invented for guys like me...issues with my wheels, various gaskets (BNIB OEM) fan shroud and the residue left in my intake manifold by the polisher of the SF member I purchased it from. There's more, but you get the point. If I'm lucky, by this coming Friday. If not, and you already know I'm not a lucky guy, sometime next week.
    Ken.
    www.sp-power.com
    HKS 3.4L: 1110 all-boost whp/839 lb-ft @ 2.6KG/CM^2
    1994 "SP ENGINEERING" TWIN HKS GT3240 TOYOTA SUPRA TURBO
    1985 P-Type Celica Supra 5MT
    1995 Toyota Supra Turbo 6MT (APU)
    2006 Toyota 4Runner Limited V8
    2007 Lexus IS 350
    2010 Lexus IS-F
  19. #244
    I love sequentials! turbosupra's Avatar
    Join Date
    Dec 2001
    Location
    MD
    Posts
    2,687
    Can you look at the pictures I posted on the first page, I believe those are a set of GIK turbos, but I'm not 100% sure as I got them second hand. Let me know, thanks!
    4 six speed turbos
    Quicksilver TT
    Blue Supra TT
    Red Supra TT
    Corolla XRS (beater, still not turbo actually)
  20. #245
    Join Date
    Sep 2001
    Location
    Posts
    907
    If you think murphy is a problem then you should meet Oreilly he thinks Murphy is an optimist :-) sorry to hear about all problems. Either way it will be very intresting to see the results of the dyno .
    Quote Originally Posted by KenHenderson View Post
    Ken.
  21. #246
    Join Date
    Feb 2002
    Location
    SoCali
    Posts
    8,009
    Thanks, my friend,
    I'm impatient by nature, but one thing the MKIV Supra aftermarket has taught me over the years is patience. I take a pretty comprehensive and thorough approach to modding because I only want to do things once and enjoy the car for years thereafter. My tuner, SP Engineering usually has almost everything in stock or immediately available. The problem is that we've never ordered new parts for the OEM twins or, in this case, the Aaron hybrids because the twins have ALWAYS been coming off cars that SPE has built. So my turbo gaskets, studs and whatnot have been trickling in, literally, one day at a time.
    BTW, if any of you in the western U.S. need a fan shroud and can't find one, it's because, LOL, I own them all. Not literally, but I had a cracked fan shroud on my black car. Ordered a new one and it came scratched. Went through this exercise FIVE times and called Curt. Curt said every shroud he had in stock (5) had the same scratches and that they all come that way because of shipping and handling issues. Finally, I took the shroud off my red car and installed it on my black car so I'd have at least one Supra to drive around, used some 5000-grit on my new, scratched shroud for the red car, along with some ABS plastic polish and got it to look reasonably OEM new.
    As you guys know, a day in the MKIV Supra aftermarket can easily turn in to a week and a week into a month. I deal with delays better than I have in the past, but it is still a lot of work for me. If I don't work at it, I'll start jumping out of windows again so, hopefully, things will be all good within a day or two. As always, time will tell.
    Ken.
  22. #247
    Administrator
    Number One Hardtopper
    Steve Theodore's Avatar
    Join Date
    Dec 1999
    Location
    North Bend, WA
    Age
    39
    Posts
    25,077
    Blog Entries
    1
    LOL @ Ken's stories. You'll get through it my friend!
  23. #248
    Now...Whitesupra94
    Join Date
    Nov 2001
    Location
    Lancaster, PA
    Age
    28
    Posts
    3,483
    You guys that are running lean...what ecu are you running? I may have missed it in the thread.
    Im surprised to see running lean at 500whp. Well, not completely surprised, but with OBDII im seeing 18psi and no leaning out. In fact, i had to lean it out some to even get into the 11's A/F wise. This is with a 67mm DBB, which also makes ~500whp at ~18psi
  24. #249
    Join Date
    Oct 2005
    Location
    in the casino. LV
    Age
    32
    Posts
    158
    Ken.
    HOLY SH!T I had the same problem. I ordered a New OEM Shroud and sure enough it came scratched to shit... Any pics of yours after you cleaned it up. I surely didnt want to spend money on a New part and have it scratched up. But if you had 5 that had the same scratchs I guess its time to start polishing.
    BTW where do you get 5000 Grit Sand paper... all i have local is 2000.
    Also, regarding running out of fuel. 11.6 a/f 500whp injectors will go 100% and car will lean out to 12.0. It is going to keep going further so there was no need pushing it till I get a fuel system. Aem computer.
  25. #250
    SupraForums Member
    Join Date
    Sep 2007
    Location
    my house
    Posts
    17
    hammerhead, any update's ?
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
