NGK vs Denso Iridium Spark Plugs
+ Reply to Thread
Results 1 to 11 of 11
Thread: NGK vs Denso Iridium Spark Plugs
  1. #1
    Wholesome creamy goodness Supraman16's Avatar
    Join Date
    Apr 2001
    Location
    Burbank, CA
    Age
    38
    Posts
    629
    Hi everyone,
    I was wondering if anyone has compared Denso vs NGK Iridium plugs. I know that the Denso's are about 2x more expensive than the NGK's, but is there really a difference between the two? From what I know, the Denso's have a smaller tip, 0.4mm vs 0.7mm on the NGK's, but from doing a Google search, I didn't find any concrete evidence to show that this size difference produced any better performance results. I wanted to see if anyone has tried both on our beloved Supra TT's.
    2008 Star Fire Pearl Lexus IS-F
    1997 Custom Pearl White Supra TT BPU+++
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    67
    Posts
    13,551
    A well-designed smaller tip seems like it would be better for spark intensity but I've only used the NGK6988/BKR7EIX-11 which work great for me.
    Nick 95 6sp
    Twin Garrett GT2860's w/TiAL exhaust housings, WG's and BOV's, on V-band moded HKS twin manifolds, AEM v2, AEM WB, ID1000's,
    AEM meth/water spray kit, GSC S1 cams, ported head Ferrea valvetrain, +0.020" CP pistons w/crown & skirt coatings, Carrillo H-beams,
    OS Giken triple clutch & Super Lock LSD, Racelogic TC, TRD gen2 catback
    street wheels: Veilside EvoV 9-1/2"F X 10-1/2"R with 265/35F & 285/35R NT05's
    track wheels: CCW LM5 10"F X 11-1/2"R with 285/30F & 315/30R R888's
    Click here to enlarge
  4. #3
    Ex-hardtopper Boostrush's Avatar
    Join Date
    Nov 2005
    Location
    New Jersey
    Age
    40
    Posts
    1,920
    I use Denso Iridium IK24's and have been using them since day one. They perform flawlessly under all conditions, so I've never tried anything different. Only downfall is that they are a bit expensive.
    If anybody uses the NGK's with no hiccups, I may try them out next time around.
    Greg
    GJK Photography
    1993.5 APU Hardtop 6-speed (sold 9/7/12)
    2008 Acura TL-S Carbon Bronze Pearl
    PS3 Username - Suprahuman
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member truesbluz's Avatar
    Join Date
    Oct 2005
    Location
    Washington, D.C.
    Age
    62
    Posts
    356
    I use the denso IK22s. You're right, they are expensive, but in my travels last about twice as long as the NGKs. So there you have it...6 inone hand and 1/2 dozen in the other.
  7. #5
    Over Medicated kbprice's Avatar
    Join Date
    Jun 2002
    Location
    St Petersburg, FL
    Age
    45
    Posts
    2,692
    I've used both the Denso IK22's and the NGK BKR7EIX-11. Actually just put in a new set of NGK's yesterday. Both worked the same. Only 2 reasons I use the NGK's is cost and the NAPA by me stocks them, always.
    FYI: I think the tips on the NGK's are 0.6mm not 0.7mm
    '96 NA-T, 542rwhp 5-speed
  8. #6
    Banned Spoolin Turbo's Avatar
    Join Date
    Mar 2003
    Location
    Canada
    Age
    36
    Posts
    2,385
    denso's have been known to lose the plug ceramic. Happened to me and others on here.
  9. #7
    SupraForums Member Taimur's Avatar
    Join Date
    Feb 2001
    Location
    Long Island, NY
    Posts
    1,628
    I've been boosting on IK27's gapped at 0.30 for two years and never had an issue.
    '97 Black 6 speed (BL 74-GTS) - Built & Tuned by Chevyeater-on-sf
    '17 Corvette Z06 M7 - Stock
  10. #8
    SupraForums Member
    Join Date
    Jul 2006
    Location
    San Antonio Tx
    Age
    35
    Posts
    283
    Where do all of you guys get these and do you have a part number?
  11. #9
    Boost Junkie 1A1's Avatar
    Join Date
    May 2003
    Location
    Indiana
    Age
    43
    Posts
    11,417
    Blog Entries
    1
    I used to use the NGK standard 6097s and had to replace them every oil change (2 months). I changed to the IK24s about a year ago and haven't replaced them yet. I haven't had a misfire with them either.
    Steve
    1993.5 Anthracite 6 SPD//PRO EFI//PTE6766//3-Row//E-85Fuel Sys//PHR I/M//GSC//IP 10/1 motor//Manley//RPS C/C//CCW C14//Brembo BBK//TRD LSD//930WHP/38PSI
    2006 Lexus LS430 UL Package
  12. #10
    Join Date
    Jun 2009
    Location
    North East
    Posts
    46
    Has anyone actually ever came to a concensus on which spark plugs are better the Denso vs the NKG iridium?
  13. #11
    SupraForums Member SupraSonic's Avatar
    Join Date
    Apr 2005
    Location
    SoCal
    Age
    49
    Posts
    1,094
    NGK's here, ran both and both seem fine to me.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
