+ Reply to Thread
Page 1 of 23 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 25 of 570
Thread: 93.5 - 96 Dash Panel Restoration
  1. #1
    Your Neighborhood Pikey HamsMKIV's Avatar
    Join Date
    Nov 2002
    Location
    Dallas, TX
    Age
    37
    Posts
    3,340
    Good evening all,
    I am posting because I was faced with an interesting dilema. My 93.5's dash panels were showing a little wear that really pained me. They weren't entirely noticeable unless the car's roof was off and in direct sunlight. The only panels that really show any wear are the shifter console and the radio panel.
    Normally, I suspect the common answer that most MKIV owners would throw out is to replace the panels with the 97-98 because they are more resiliant. Well, everyone is entitled to their own opinions and personally, I prefer the black panels on the 93.5-96.
    That said, I wondered if there was/is a way to restore the finish. I happened to be tooling around my local Lowe's today while my wife is shopping for new interior paints to re-decorate our son's room. While there, it occurred to me... Plastic paint....
    Before you start assuming, please read on!
    I started browsing around when I stumbled upon a nifty product, Valspar Clear Plastic Primer. I bought a can to test out my shifter panel thinking: "Well it's already jacked up, I have nothing to lose, let's test it out and see".
    First, I chemically stripped the rubberized coating off the panel with an aerosol version of Goo Be Gone, actually it is called "GOOF OFF". I sprayed the panel down enough to thoroughly soak it, then I let it sit for about 5 minutes. Next, I used a regular old dish brush to scrub away at the panel. With minimal effort, the rubberized coating crumbles up and washed right off. When I stripped the panel, I ended up with a naked piece of plastic that looked like this:
    Notice that it's smooth and a little ashy... It's a very clean surface. I must apologize, I didn't take pictures of the shifter panel stripped because I had no idea it would turn out so well. In case someone asks, I removed the Premier Edition Emblem with Dental Floss and using a sawing motion back and forth. I was able to remove the emblem without bending it or damaging it. I will re-apply the emblem once complete.
    Next, I used the Valspar Clear Plastic Primer. I dusted a thin base coat and let it dry approximately 1 hour. I applied 3 more coats in the same fashion, dusting and let them sit 1 hour. 6 hours has passed by and the finish is quite smooth, and very resiliant. It looks like this:
    Here is the ash tray complete:
    The shifter console complete:
    Curious, the panel has a satin look to it. It isn't shiny, but not flat either. It's very black, it has a darker hue than the rubberized panels. The finish is very smooth. The nice thing, it is very hard as well. I was testing the side of the panel to see if I could scratch it with my finger nail. I was unsuccessful! The finish is very hard so far.
    I will continue to add pictures to this account, but I wanted to offer up my experience to others out there who might wish to do the same. Personally speaking, money isn't the factor when it comes to spending $450 on a new set of panels. For me, it's a matter of principle. I'd rather spend the money elsewhere on the car if I can restore the finish to like-new. I think that once completed, the untrained eye won't notice the difference.
    I'll keep everyone updated.
    - Hams
    Out of the game for a while.
  2. #2
    SupraForums Member DawgOnIT's Avatar
    Join Date
    Feb 2001
    Location
    Texas
    Age
    41
    Posts
    298
    nice job.. I agree completely with fixing it before replacing it.. Does this primer seal and prep the plastic for regular paint too?
    Brent
    93.5 Antracite TT - BPU
  3. #3
    Join Date
    Nov 2002
    Location
    Dallas, TX
    Age
    37
    Posts
    3,340
    Quote Originally Posted by DawgOnIT View Post
    YES it does. I also purchased satin black from Valspar for plastic as I was planning to use the primer as a base coat. As it turns out, the primer only creates a finish that so closely replicates the original finish that I didn't go any further with it.
    I also have to note that on my initial dusting of the panel, I used 2000 grit sandpaper and lightly wet-sanded to remove any imperfections. The result is really impressive.
    Like I said, I'll definitely post more pictures as I continue with the process. I'm just so excited with how it turned out on the one panel, I wanted to share the result!
    - Hams
  4. #4
    aKa Blk96SupraTT Da BlaCkMoBiLe's Avatar
    Join Date
    Sep 2005
    Location
    Long Beach, CA
    Posts
    3,864
    Wow that looks very clean. I used a darker gray bumper paint and it came out nice but i like hows yours came out looking more like the stock interior. Might have to re-do mines in the future.
  5. #5
    SupraForums Member
    Join Date
    Apr 2006
    Location
    MD
    Age
    31
    Posts
    265
    Where did you buy the primer?
  6. #6
    Join Date
    Nov 2002
    Location
    Dallas, TX
    Age
    37
    Posts
    3,340
    Quote Originally Posted by vwluv10338 View Post
    Sorry, I think I stated in the thread. I purchased the primer at LOWE'S.
  7. #7
    SupraForums Member OdyOwnage's Avatar
    Join Date
    Jul 2007
    Location
    Houston, Tx.
    Posts
    2,624
    Please post more pictures.
    I would definately be interested in doing this method.
  8. #8
    Join Date
    Nov 2002
    Location
    Dallas, TX
    Age
    37
    Posts
    3,340
    UPDATE.... I finished the Ash Tray...
    I will post updated pics on the 1st post to keep things easy...
    Ash Tray Complete:
    - Chris
  9. #9
    Join Date
    Jul 2007
    Location
    Houston, Tx.
    Posts
    2,624
    Ok, I am off to LOWE'S TOMORROW
  10. #10
    Life begins @ 30psi....
    Join Date
    Sep 2001
    Location
    Pensacola, Fl
    Age
    44
    Posts
    2,509
    Did you source everything at Lowes?
    This looks great mine are in pretty good shape but not as good as like stuff to be so I will be doing this project soon.
    Thanks for sharing this!!
    Bob
    1998 Black 6 speed - BL 4" kit with a Billet 6765, BC 272 cams, TPS ported and polished head, setup for E-85, RPS triple carbon, AEM V2, 1600cc inj in my own custom fuel system, Greddy3 row, ect , ect, Alpha tuned. Numbers coming soon!!!
    1994 Single Turbo Supra - BL / SP Hybrid 71-GTS / 760+rwhp with all the goodies. Singled, Stalled, Sprayed, AEM. 9 Second capable and one awesome street car.****SOLD 6/5/2008**** but not forgotten.
  11. #11
    Join Date
    Nov 2002
    Location
    Dallas, TX
    Age
    37
    Posts
    3,340
    Quote Originally Posted by Bob Tompkins View Post
    Bob
    Yes sir,
    I purchased both products at Lowe's.
    I will be happy to post pics of the two products for you guys if you'd like.
    Update, I installed the shifter piece and the ash tray back in the car so you guys could see the difference.
    If you notice, the color differences are VERY close to one another. The radio console is OEM, the shifter console is complete.
    In shaded light, the difference is essentially unperceptible. With the flash, you notice a color difference. The idea is that the finish closely replicates the stock finish without being prone to scratches.
    Enjoy! I will keep posting updates.
    - Hams
  12. #12
    BPU is so 1997
    Join Date
    Feb 2001
    Location
    Ohio
    Posts
    6,939
    Looks better than stock actually. I will have to do this sometime when mine get really bad.
  13. #13
    SupraForums Member
    Join Date
    Apr 2004
    Location
    Brooklyn, NY
    Age
    33
    Posts
    566
    Wow, looks great, can you post a picture of the products you used?
  14. #14
    Wingless by Choice poorman's supra's Avatar
    Join Date
    Apr 2005
    Location
    UT
    Age
    27
    Posts
    1,424
    Quote Originally Posted by Hua View Post
    +1 Looks great. thanks for sharing
  15. #15
    2turbos1supra Capacity4Action's Avatar
    Join Date
    Feb 2006
    Location
    NorCal - South City
    Age
    28
    Posts
    1,666
    Wow, I have to try this!
  16. #16
    SupraForums Member
    Join Date
    Oct 2004
    Location
    Fresno, CA
    Age
    34
    Posts
    952
    looks great. Do you want to do my, haha. I notice on my panel, it produces oily spot here and there. Like the panel are sweating. Weird. Wonder what you guys use to clean them or get rid of the oily spots.
  17. #17
    War Junkie supra steveo's Avatar
    Join Date
    May 2004
    Location
    Newcastle, UK England
    Age
    33
    Posts
    95
    wow! awesome might have to do mine now
  18. #18
    Join Date
    Sep 2001
    Location
    Pensacola, Fl
    Age
    44
    Posts
    2,509
    Can you post the pics of the actual products used? I will be off an Friday and I will be heading to lowes anyways for some other stuff.
    Thanks!
  19. #19
    Join Date
    May 2007
    Location
    Staten Island, NY
    Posts
    1,794
    wow that looks amazing i feel a service coming on.....
    so you used only two items? right? since thats all you mentioned.
  20. #20
    Highway Demon 95jza80tt's Avatar
    Join Date
    Sep 2001
    Location
    In the driver seat
    Posts
    3,117
    I did this to an extra odo housing that I had laying around and OMFG!! it rocks. It is hard to explain how it looks as to just say it looks like an entirely new panel all over again. It matches up realy close to the stock dash panels that I have not painted yet. Thanks for posting this up. I am tempted to start doing the rest of my dash panels now. Mine came out as nice as what is already pictured above in the 1st post
    Brian
    Click here to Email me 95 red supra tt 6spd BPU+++
    http://youtu.be/1XSTOqvXAOY
    '95 Toyota Supra TT 6spd
    '01 Subaru Impreza GC6 5spd
  21. #21
    Join Date
    Nov 2002
    Location
    Dallas, TX
    Age
    37
    Posts
    3,340
    Quote Originally Posted by 95jza80tt View Post
    I did this to an extra odo housing that I had laying around and OMFG!! it rocks. It is hard to explain how it looks as to just say it looks like an entirely new panel all over again. It matches up almost completely to the stock dash panels that I have not painted yet. Thanks for posting this up. I am tempted to start doing the rest of my dash panels now. Mine came out as nice as what is already pictured above in the 1st post
    Brian
    Brian,
    Glad you confirmed my exercise. I discovered this process by accident! I also purchased black plastic paint to cover the primer. When I realized how well the clear primer turned out, I quickly realized that I was done.
    To anyone who is thinking of doing this, I highly recommend you try. You will be shocked at how close the panel comes out to the original.
    - Hams
  22. #22
    Join Date
    Sep 2001
    Location
    Pensacola, Fl
    Age
    44
    Posts
    2,509
    Hams -
    Can you take some pics of the cans I want to get the exact stuff you got. I will be doing this ASAP.
    Bob
  23. #23
    Join Date
    Nov 2002
    Location
    Dallas, TX
    Age
    37
    Posts
    3,340
    Hams -
    Bob
    Ask and ye shall receive:
    - Hams
  24. #24
    All Access Motorsports AdamSupra's Avatar
    Join Date
    May 2005
    Location
    Long Beach, SoCal
    Posts
    1,544
    WOW, Very clean... Great job !!
    The Largest Supra Event on the planet !!
    Will you be there ?
    SILV Show-and-Shine Activity Sponsor and Coordinator
    '92 Toyota Soarer (SC300) - Daily Driver and Drift Machine
    XS Power - HKS - ACT - NISMO - Blitz - Koyo - Sun Auto - Carbing - Daizen - Tein - Vertex - Greddy - Apexi - LexTech
    '95 Toyota Supra HardTop (-mods-Top secret)
  25. #25
    Join Date
    Sep 2001
    Location
    Pensacola, Fl
    Age
    44
    Posts
    2,509
    Quote Originally Posted by HamsMKIV View Post
    - Hams
    Thanks Dude!!!
    I will print the pics and bring them with me, much appreciated.
    Bob
+ Reply to Thread
Similar Threads
  1. Dash Panel Quote
    By AndrewLindquist in forum Elmhurst Toyota Scion
    Last Post: 12-29-2006, 07:26 AM
  2. dash panel
    By MkIVSylver in forum Elmhurst Toyota Scion
    Last Post: 06-17-2005, 01:08 PM
  3. dash panel paint.
    By shak in forum Elmhurst Toyota Scion
    Last Post: 06-09-2005, 10:53 AM
  4. 97-98 dash panel color?
    By spooler21 in forum Exterior , Interior, and Detailing
    Last Post: 02-03-2004, 08:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
