+ Reply to Thread
Page 5 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 101 to 125 of 570
Thread: 93.5 - 96 Dash Panel Restoration
  1. #101
    Wingless by Choice poorman's supra's Avatar
    Join Date
    Apr 2005
    Location
    UT
    Age
    27
    Posts
    1,424
    ^^ just be careful that goof off shit is scary to use. I already mest up my ash tray. spray it on once and ONLY once or your plastic will melt away trust me.
  2. #102
    SupraForums Member edenward's Avatar
    Join Date
    Jan 2003
    Location
    Orlando, Fl
    Age
    11
    Posts
    2,129
    Quote Originally Posted by vwluv10338 View Post
    Didnt read the post did you because there was no color used.
    Yes, I read the post, like mentioned below, I did it 6 months ago, and I was just mentioning that I didn't use the same product.
  3. #103
    Alpha for president runs11's's Avatar
    Join Date
    Apr 2005
    Location
    Albany,New York
    Age
    31
    Posts
    1,099
    Quote Originally Posted by poorman's supra View Post
    i messed a few pieces up too...i would recommend to just use the steel wool...takes longer but no worry about mess up
    INDUCTION PERFORMANCE BUILT
    95 6spd fullrace, Precision 8285
    JE, Carrillo, Pro Gram billet mains,
    HKS 280's, VWR race head +1 valves,
    VWR intake manifold, Tilton,
    SP IC, Proefi, ID 2000's,
    Weldon 2345 w/BAP, 150 shot, E85
    1333hp @44psi all boost!
    Old set up Alpha tuned
    http://www.youtube.com/watch?v=mE24tQMR1BY
    93 Anthracite Hardtop 34k (stock) ***SOLD****
  4. #104
    Join Date
    Apr 2005
    Location
    UT
    Age
    27
    Posts
    1,424
    Maybe this is a dumb question but what steel wool should I look for??
  5. #105
    Join Date
    Jan 2003
    Location
    Orlando, Fl
    Age
    11
    Posts
    2,129
    I used 0000 steel wool, that is the finest I believe, then used 2000 grit wet dry sand paper.
  6. #106
    Join Date
    Apr 2005
    Location
    UT
    Age
    27
    Posts
    1,424
    Thanks, I'll go look for some this weekend.
  7. #107
    Highway Demon 95jza80tt's Avatar
    Join Date
    Sep 2001
    Location
    In the driver seat
    Posts
    3,117
    Yeah I melted the panel with the dimmer switch on it. It was not fun But luckily I had a spare panel which I took my time with. *Note* the goof off is strong enough to melt the plastic and it is faster to use but you cannot rush it though. You must still take your time with it and be very careful. I posted that once earlier too but I guess I need to stress it more that you need to BE VERY CAREFUL WITH GOOF OFF.
  8. #108
    Join Date
    Dec 2007
    Location
    Hawaii
    Posts
    150
    I just finished my panels, I will try and post pics soon. I used a paper towel and sprayed the Goof Off on it then wiped down the panel, The top layer came off so easily no problem. Just to ensure a cleaner finish, I used the 0000 steel wool. Didn't use primer, just a plastic paint with no primer needed and came out with a nice glossy coat.
  9. #109
    Former 1.5jz-Powered MKIV Shitzu's Avatar
    Join Date
    Sep 2002
    Location
    Lakewood, CA
    Posts
    645
    great thread, I gotta give this a shot when my panels get jacked up, gotta love the oem look....
  10. #110
    SupraForums Member brianwilson2525's Avatar
    Join Date
    Jul 2007
    Location
    SL, UT
    Age
    28
    Posts
    386
    Quote Originally Posted by 95jza80tt View Post
    haha, i guess we shouldnt be goofing off with the "goof off" haha.
  11. #111
    SupraForums Member
    Join Date
    Apr 2006
    Location
    MD
    Age
    31
    Posts
    265
    Well I am in the middle of spraying my panels with the Valspar primer and I cant for the life of me get an even finish. I have tried light coats, heavy coats and sanded between. It just wont go down with that oem look like others are getting. No big deal I guess. I can always just hit it with some paint if I need to.
    E
  12. #112
    SupraForums Member
    Join Date
    Jul 2002
    Location
    Out of this World
    Age
    32
    Posts
    489
    I used the carb/choke cleaner and steel wool. The combination would just melt the coating off but doesn't look like it hurt the plastic at all. The key was to spray it on and make sure you could let it sit on the plastic in one spot for 4 to 5 seconds, then use the steel wool in the area that the spray sat and it came right off. Probably did all of my panels in about 30 minutes. I won't have pictures of mine done for quite a while as my car is in about 10000 pieces right now.
  13. #113
    SupraForums Member
    Join Date
    Apr 2007
    Location
    Washington
    Posts
    94
    So Im wondering if this is as easy as the original poster decsribed or if those who had problems are just special.
    I wanted to do this, but now Im having second thoughts, seems pretty easy.
    1. Spray with Goo Off, set sit for 5 mins
    2. Brush off rubber paint.
    3. Wet Sand, this seems to be optional.
    4. Apply 3 lights coats of clear vespar primer, one hour apart.
    5. Done.
    Am I missing something? How are you guys ruining these panels? Im honestly concerned, cause I need to do the whole thing, minus the 6 speed panel (which I just replaced.) I have bad luck with projects like this sometimes, but it seems really easy.
    What defines ruined? Either way you just sand and paint?
    BP
  14. #114
    SupraForums Member
    Join Date
    Apr 2006
    Location
    MD
    Age
    31
    Posts
    265
    Well I tried another panel to see if I am just "special". Well it seems to do it right you need to go lighter than a light coat and do a "dusting", as described in the origional post. If you do anything heavier than a dusting you will not get an even texture. I just dusted my shifter panel and it looks ok, now I will have to resand the other panel I shot first and do them again. No big deal.
    E
    EDIT: ruining comes form leaving the goo off on too long and melting the plastic beyond a light sanding will repair
    EDIT AGAIN: Goo Off will easily remove the primer if you mess up and spray it too heavy.
    Quote Originally Posted by bpalmer21 View Post
    5. Done.
    BP
    IS300 DD (60-1 turbo kit sold)
    Supra '95 TT 6sp. BPU
    89 FJ60 w/ Toyota 2H Diesel swap w/ 5sp
    2H engine rebuild
    240SX 'vert w/ SR20DET swap - SOLD
  15. #115
    SupraForums Member
    Join Date
    Jul 2002
    Location
    Out of this World
    Age
    32
    Posts
    489
    Here are mine. It will be a while before they are back in the car.
    I didn't use the storm grey everyone else used, I am using gunmetal (sorry don't remember the can code) because I had like 3 cans of it around the house from when I painted my Stock Talon wheels about 7 years ago. Paint was still good, couldn't beleive it.
  16. #116
    SupraForums Member
    Join Date
    Apr 2007
    Location
    Washington
    Posts
    94
    I didnt mean "special" I should have just said special situations. Sorry.
    Thanks for clearing it up, I wont let the goo off set that long.
    Those gray panels look badass!!!
  17. #117
    SupraForums Member
    Join Date
    Mar 2007
    Location
    Japan
    Age
    40
    Posts
    289
    I redid my dash about 5 months ago and had a friend professionally paint it. The only this that I did differently was that I used paint thinner to get off the rubber. Patience is definitely key when getting that crap off. I just took a little paint brush and kept adding the thinner in portions. Seemed to work fine for me and there was no melting. Took me awhile to figure out the cigarette lighter though.
    95 TT in Japan (currently restoring) my thread is at
    http://www.supraforums.com/forum/sho...d.php?t=485706
  18. #118
    Join Date
    Apr 2005
    Location
    UT
    Age
    27
    Posts
    1,424
    KILURV8: can you tell me how you got the cig lighter out??
  19. #119
    Supra + DSM = heaven gixxer_drew's Avatar
    Join Date
    Feb 2001
    Location
    Yokohama, Japan
    Posts
    5,013
    All I got to say is that goof off shit is like sulfuric fucking acid be careful!!!!
  20. #120
    SupraForums Member
    Join Date
    Jul 2002
    Location
    Out of this World
    Age
    32
    Posts
    489
    Honestly I dont remember. I know in all my other cars there is a lock nut on the back side of the plastic that has to be removed then the lighter should push out the front. I don't remember if that is the way this car was or not. I took them out about a month ago and am working on rewiring all my gauges since I wasn't happy with the wire job.
  21. #121
    Join Date
    May 2007
    Location
    Staten Island, NY
    Posts
    1,794
    stuck on how to get the lighter out anyone know how to do this?????
  22. #122
    SupraForums Member Will84's Avatar
    Join Date
    Dec 2006
    Location
    Huntsville, AL
    Age
    36
    Posts
    980
    ^ I forget exactly... it's been a while, but I had the same problem. Seems like there's a couple tabs back there that you have to get by. The black plastic cup thing stays in place and the rest of the unit can be pushed from the back out the front.
  23. #123
    SUPRA 7 2JZPWRD's Avatar
    Join Date
    Aug 2007
    Location
    Tempe, Arizona
    Posts
    2,182
    That looks really good KILURV8. Props..
    Be sure to post pictures of them installed.
  24. #124
    Join Date
    May 2007
    Location
    Staten Island, NY
    Posts
    1,794
    also for the piece thats all the way to the left with the light bulb thing that you can turn i can't get that out either....
    its a little white box that says "toyota ABS"
  25. #125
    SupraForums Member
    Join Date
    Jul 2002
    Location
    Out of this World
    Age
    32
    Posts
    489
    Pull the knob off the light adjuster, there is a small nut under the knob, remove the nut and the adjuster will fall backwards.
+ Reply to Thread
Similar Threads
  1. Dash Panel Quote
    By AndrewLindquist in forum Elmhurst Toyota Scion
    Last Post: 12-29-2006, 07:26 AM
  2. dash panel
    By MkIVSylver in forum Elmhurst Toyota Scion
    Last Post: 06-17-2005, 01:08 PM
  3. dash panel paint.
    By shak in forum Elmhurst Toyota Scion
    Last Post: 06-09-2005, 10:53 AM
  4. 97-98 dash panel color?
    By spooler21 in forum Exterior , Interior, and Detailing
    Last Post: 02-03-2004, 08:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
