Factory Toyota clamp that holds hose to power steering fluid resevoir.
1994 Toyota Supra turbo
90080-46355 Clamp From Rack List 7.82 Cost 5.97
90467-21010 Clamp To Pump List 2.84 Cost 2.17
Thanks,
Curt
eparts@elmhursttoyota.com
www.elmhursttoyota.com
630.279.2265 parts direct
630.835.0122 parts fax
My weekly hours are 3:45am CST-4:00pm CST M-F CENTRAL STANDARD TIME
You can call me or use e-mail. If you use e-mail I need your name,address,phone number and CCinfo and items requested.
I apologize if this has been listed - I just got the car and don't even know if this is a real part:
1994 Supra
Floor Mat hook or clip or holder???
--- I have two round holes and a sliding floor mat
I think I will have a list ready for my order after this part # as i used search and found the rest of the part#'s THANKS!!!
00206-00801 Clip,carpet List 1.03 Cost 0.79
Curt - ready to place order - I wil email you after I get pricing on last few stragglers -
00206-00801 Clip,carpet List 1.03 Cost 0.79 X 1
90080-46355 Clamp From Rack List 7.82 Cost 5.97 OR 90467-21010 Clamp To Pump List 2.84 Cost 2.17 I need the smaller top clamps that holds the rubber hose to the resevoir x1 to replace band clamp in this pic http://s223.photobucket.com/albums/d...t=IMG_1202.jpg
90466-41008 Hose Clamps List 5.63 Cost 4.29 Ea X 2 (Upper Rad hose clamps)
1994 Supra owners manual need X 1 and Toyota repair manual x1 (Depending on pricing)
I need clip or bolt that holds drivers side kick panel that goes in middle of the panel by left foot. X 1
I need clips or bolt that holds passenger side kick panel that goes in middle of the panel by your feet X 2
I need clips that hold passenger side carpet down - I have two holes in the top of the carpet where you would pull back to see the ECU X 2
Cruise control cable clamp 78183-14030 X1
Cruise control cable clamp 88276-14120 X 1
75441-14190 "TOYOTA" LIST 12.49 COST 9.24 X 1 dark grey or black is one I want
75471-14010 EMBLEM REAR LIST 18.01 COST 13.31 X 1 dark grey or black is one I want
info here on manuals:
http://www.supraforums.com/forum/showthread.php?t=65514
Estimate Q 74392 $59.96
E-mail Addy Please.
recieved
If its not too late can you add one more part – if it is I will just get the part later.
I need the round clip that holds the driver’s side rear quarter panel plastic inside the driver’s side door jam – basically if you opened the driver’s side door and looked to your right, you would see a round hole where something is suppose to be - to hold the backseat plastic that goes around the window.
Ok I'll Add It
I didnt see any charges on my credit card yet - I assume something is on "special order"?
If it hasnt shipped yet ?? - Could you add:
74407-14020 X1 battery bolt hold down
63297-14020 Plug List 5.57 Cost 4.18 Ea x 1 -** if thats the right part # for the passenger side rear plastic screw/cover piece when the Targa top is off (94 Supra)**
Also in the back hatch where you store the targa top/ passenger side next to the rear seat - on the Targa holder I'm missing the "small rubber piece" on the passenger side front holder ---x1
Is that piece seperate or do I have to order the whole holder? If its seperate I'll take it --if its the whole part then I do not want.
88276-14120 is coming from japan.
OK i'll add the other items.
The rubber peice is part of the holder, I will not send it.
I think you shipped my last order already - ??? Either way
New order:
I have keyless entry with no remote when I bought the car last month and when I hit the reset button on the ECU under the drivers seat, it makes the horn beep 1 time - then I hit it again and the horn beeps 2 times and my pdl both work with the key, so I assume I just need the remote for keyless entry? 94 supra TT - ECU for keyless has BAB-MW-8250 wrote on it.
08191-00870 Transmitter List 84.14 Cost 64.24 Ea X1
Also need the clips If you pop the Hood theres a rubber seal between the hood and engine compartment in the back by the wipers - I need the "Clips that hold Rear rubber seal "?? all of them - I think 12 total ?
08191-00870 TRANSMITTER LIST 84.14 COST 64.24
With the key in the on position, Press the green button , then press the remote button to program.
90467-10146 CLIP list 1.01 cost 0.76 ea x 12
e-mail sent - thx for all your help!
recieved
If its not too late on my 2nd order can you add
Anti-theft horn /w turbo X1
E-mail Recieved.
Curt,
I would like to order:
33504-14130 Knob 6 Speed List 112.09 Cost 85.59 X1
Anti-theft horn /w Turbo X1
BTW TY again --the keyless transmitter works like a charm!!!!
ok i'll add it to your horn order. The horn is intransit from Japan to me.
I changed my spark plugs today and noticed I was missing one of the 6 bolts the hold the coil packs to the head. Could you add one of these bolts to my order - 10mm head thats a few inches long.
And I used Search - so I'm not going too ask you about the gray wiring harness clips -- Buahahahha THX
wrong thread
