Supra Smoking?
+ Reply to Thread
Results 1 to 15 of 15
Thread: Supra Smoking?
  1. #1
    Join Date
    Jul 2008
    Location
    Kiln, Mississippi
    Posts
    13
    Supra Smoking?
    My 94 single turbo supra smokes a little on start up... It smells like fuel and a little oil, could this be anything really bad, or is it running really rich and needs a tune, which it does, to fix the smoke? When running regular you can smell a ver potent fuel smell coming out of the exhaust, but no smoke... what should I look for or listen to??
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member joeBPUsupra's Avatar
    Join Date
    May 2008
    Location
    fayetteville,nc/ Germany
    Age
    31
    Posts
    1,187
    a common problem in supras are the valve stem seals usually need to get replaced. does it only smoke during start up?
    Click here to enlarge
    Joe
    97 MKIV 6spd Black APU GT42R 7275 CEA(My car) FOR SALE
    97 MKIV 6spd Green BPU+ (Wifes old car)SOLD
    04 Evo Silver (Wifes NEW car)
    98 Expedition (Family car)
    FIGHT ME ON http://joebpusupra.mybrute.com
  4. #3
    Join Date
    Oct 2005
    Location
    Oceanside Cali
    Age
    35
    Posts
    1,727
    lol.... yeah common... you sounded scared...
  5. #4
    Join Date
    Jul 2008
    Location
    Ontario
    Posts
    3
    why are you running regular?!
  6. #5
    SupraForums Member civic_guy's Avatar
    Join Date
    Dec 2007
    Location
    Houston, TX
    Age
    31
    Posts
    1,099
    Quote Originally Posted by tacoboy View Post
    i dont think he means regular as in fuel, but regular as in normal driving.
  7. #6
    Join Date
    Jul 2008
    Location
    Kiln, Mississippi
    Posts
    13
    It smokes only during start up for like 3 seconds, and it is like 2 seconds after the motor has started, besides that it does not smoke the rest of the time it runs.
  8. #7
    Join Date
    Jul 2008
    Location
    Norway
    Posts
    16
    Smoke
    Yes, this is the same problem that i have. The valve stem seals. It's does no damage to the engine, so no hurry to fix. But i agree it doesnt look good.
  9. #8
    Join Date
    Jul 2008
    Location
    Kiln, Mississippi
    Posts
    13
    it smells a lot like fuel, I am on the stock fuel system and a stock computer... with the single turbo i didn't think it was that great of an idea, could my injectors be dumping on start up, or could it be old fuel i am burning off on start up.
  10. #9
    ex BPU'er
    Join Date
    Jul 2007
    Location
    Orlando
    Age
    31
    Posts
    5,094
    Quote Originally Posted by Roger Supra/Rx7 View Post
    That is not that bad
    1997 Supra TT- PT67/QSV/Vipec/HKS/AEM/SSR
    2004 G35 Coupe -Brembo pkg- daily/track
    2010 G37x Sedan- Wife's
  11. #10
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,390
    Do you have a wideband (you should)? We need to know if it is oil or fuel that is causing the smoke. If it is oil, then it could very possibly be the valve stem seals like people have said. If it is fuel, then it could be a lot of things. Do you have any leaks in your piping or vacuum lines?
  12. #11
    Join Date
    Jul 2008
    Location
    Kiln, Mississippi
    Posts
    13
    I very well may have leaks in my vacuum lines... would this cause the car to overcompensate and dump fuel and oil?? Also if it is the stem seals would it be a disaster to fix or not so expensive. Also does the fact that i dont have an oil catch can make it likely to burn oil??
  13. #12
    ex BPU'er
    Join Date
    Jul 2007
    Location
    Orlando
    Age
    31
    Posts
    5,094
    If you do the stem seals yourself, not expensive at all~ $150 for parts. It does take some time though. Apparently, as told by my friends, my car smokes too, but during hard boosting~ maybe turbo seals going bad?
  14. #13
    SupraForums Member
    Join Date
    May 2004
    Location
    San Diego
    Posts
    3,390
    You really should be searching because most of these questions have been answered. Valve stem seals are easy if you take it to a shop that knows how to work on Supras.
    As for your other problems, it sounds like your Supra has not been maintained very well. I would do the general maintenance on it, like replacing the vacuum lines and going over everything very theroughly. We can't see your car and you refuse to give us detailed information about your setup and what is wrong. The search button will reveal all the info you need.
  15. #14
    Its the valve seals...not costly to replace.
  16. #15
    Join Date
    Jul 2008
    Location
    Kiln, Mississippi
    Posts
    13
    The problem was BLOWN TURBO SEALS lol thank god it wasn't a valve stem seal job.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. smoking
    By jcmiral in forum MKIII (1986.5-1992)
    Last Post: 09-06-2006, 11:01 AM
  2. Poll, Smoking and your Supra MKIV
    By Kyle Hunter in forum General Supra Forum
    Last Post: 05-11-2005, 07:00 AM
  3. supra smoking problem - help
    By neowasabi in forum MKIV (1993-1998)
    Last Post: 02-25-2003, 10:03 AM
  4. my supra was smoking
    By ChadMk3 in forum MKIII (1986.5-1992)
    Last Post: 05-01-2002, 07:53 PM
  5. Supra Smoking...
    By nickphs7 in forum MKIV Technical
    Last Post: 01-13-2002, 08:11 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
