Garret vs. Greddy
+ Reply to Thread
Results 1 to 25 of 25
Thread: Garret vs. Greddy
  1. #1
    Junior Member
    Join Date
    Aug 2008
    Location
    n/a
    Posts
    116
    Garret vs. Greddy
    I've been searching through this forums on single turbo set-ups. I've seen many dabates on people who mention the T88 from Greddy. I would assume that the Greddy T78/88 are the same as the GT47-78/88. Whats the difference? Some say the the powerband on the T88 isnt as big as you would think. If I was to use my single turbo set-up on a daily driver, would I go for the Garret turbos or the Greddy turbos, and what size? Thanks for any help in advance
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Jul 2001
    Location
    SoCal
    Age
    35
    Posts
    1,281
    The T88 is not the same as a GT47. The T88 is much smaller. You might get 800hp out of the T88 where as the GT47 is good for well over 1000hp.
    moreboost.org
    turbobygarrett.com
    Daniel
  4. #3
    SupraForums Member
    Join Date
    May 2005
    Location
    Mobile, Alabama
    Age
    31
    Posts
    911
    Greddy didn't name their turbo's by mm like most other companies
  5. #4
    Engmaineer kamiraa's Avatar
    Join Date
    Dec 2007
    Location
    Houston / Chicago
    Posts
    2,409
    t78 = 67 mm
    t88 = 76 mm
    if I remember correctly, I could be slighty off with that.
  6. #5
    SupraForums Member
    Join Date
    Oct 2005
    Location
    Killeen, Texas
    Age
    32
    Posts
    221
    greddy's technology is a few steps behind garrett in terms of turbos
  7. #6
    Big Things Happening Soon 30PSIBLK's Avatar
    Join Date
    Nov 2007
    Location
    Miami, Florida
    Posts
    1,040
    T78=67MM wheel good for 750-775rwhp
    T8833d=70mm wheel good for 800-825rwhp
    T88h34d=72MM Wheel good for over 900rwhp
    T88hGK=76MM wheel good for over 1000
    These turbos are made by Mitsubishi. Very good turbos but a little out dated. Good power easy and cheap to fix but lag is a killer on these b/c of the large hot sides. Garrett Technology is great good power fast spool times. Precision is made by Garrett and so are the SP turbos. The greddy kit for the amount you pay is the best bang for the buck as a complete kit.
    Manifold is great
    Waste Gate is great
    Turbos are good
    Down pipe bolts up
    All lines and hard ware bolt up no fabrication.
    I personally made 813 RWHP & 602 on pump gas on a stock and head through a BL tranny. On my T88H set up. (72mm wheel)
  8. #7
    Junior Member
    Join Date
    Aug 2008
    Location
    n/a
    Posts
    116
    Ohh, thanks a lot guys. I never knew that about how they don't match the name w/ the size. That's very sneaky of them o.O
    So, GT4LYF, huh?
  9. #8
    SupraForums Member StokerSix's Avatar
    Join Date
    Dec 2004
    Location
    Cape Canaveral FL
    Posts
    980
    My pte67dbb with .68ar doesn't outspool my old T78 by much worth mentioning. The greddy's may have the large ar, but they also have both a divided manifold and exhaust housing.
  10. #9
    Twin Meister
    Moderator
    KenHenderson's Avatar
    Join Date
    Feb 2002
    Location
    SoCali
    Posts
    9,774
    Quote Originally Posted by cptpain View Post
    Please explain.
    Ken.
    www.sp-power.com
    HKS 3.4L: 1110 all-boost whp/839 lb-ft @ 2.6KG/CM^2
    1994 "SP ENGINEERING" TWIN HKS GT3240 TOYOTA SUPRA TURBO
    1985 Toyota Celica Supra P-Type 5MT
    1991 Toyota Supra Turbo Hardtop/Sunroof 5MT (BPU)
    1993.5 Toyota Supra Turbo Hard Top (BPU)
    1995 Toyota Supra Turbo 6MT (APU)
    2006 Toyota 4Runner Limited V8
    2010 Lexus IS-F
    2016 Lexus IS 350 F Sport
  11. #10
    Junior Member
    Join Date
    Aug 2008
    Location
    n/a
    Posts
    116
    Oh man, getting some debate going here, eh? Not criticizing your inteligence, but I would like an axplanation as well. Thanks
  12. #11
    SupraForums Member Boostage's Avatar
    Join Date
    Nov 2002
    Location
    South Florida
    Posts
    1,985
    I know this is a Zombie thread but would really like to hear the reasoning, because for weeks I been readng the same thing How Garrett uses "Newer technology" "Better aero design on the wheels" but have yet to see a comparable Garrett outpower a MHI Turbo. or stand up to the same amount of Boost.
  13. #12
    SupraForums Member Evolved 6-speed's Avatar
    Join Date
    Jan 2009
    Location
    Central NJ
    Posts
    1,211
    Quote Originally Posted by 30PSIBLK View Post
    Wow.
    Explain that 813rwhp on pump.
    Do you mean e85?
    1995 Super White Supra TT 6-Speed: 30,211 original miles & basically stock when bought......BPU since 2010 and beyond???
    Click here to enlarge
  14. #13
    Super Moderator Wreckless's Avatar
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,007
    Quote Originally Posted by Boostage View Post
    Reviving threads this old rarely goes well.
    The OG Greddy T78 and T88's are awesome turbos for their given HP levels. They're very Japanese in design, focusing on low exhaust pressures via huge hotsides and efficient turbine wheels. This makes them laggier than many similar sized turbos.
    The lower the exhaust pressure, the lower the EGT's, and that helps the Japanese tuners safely push bigger power numbers on their pump gas, since pump gas is all they get. It's good pump gas, but they don't have race gas/meth/etc readily available in Japan like we do here in the US.
    Naturally, people just assume that more lag = crappier technology. I'd put the durability of a Greddy T78 or T88 up against any other journal bearing turbo out there. But because people rag on them so much, they're seriously cheap, and easily one of the best used turbo deals out there.
    The only downside is that older T78/T88's had a 4-bolt DP flange instead of a V-band, and that 4-bolt flange can be a PITA to find if you're buying the turbo used.
    I'm sure that with modern billet compressor wheels and newer, lighter modern materials one could make a much better turbo than those old T78/T88's, but just because something's better doesn't mean the old stuff just stopped working.
    My first high HP Supra ride was in a T88H car making 875whp back in 2002 or so. I'll never forget it lol.
    Quote Originally Posted by Evolved 6-speed View Post
    Wow.
    Do you mean e85?
    Please notice you're asking a question of a post ~2 years old.
    IIRC he was on pump + meth.
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
    Click here to enlarge Originally Posted by KING Click here to enlarge
    Who would have ever thought.....the impact an automobile can make.....
  15. #14
    SupraForums Member
    Join Date
    Oct 2006
    Location
    supra land
    Posts
    1,911
    pretty cool
  16. #15
    SupraForums Member
    Join Date
    Apr 2004
    Location
    Frederick, MD
    Posts
    3,820
    back from the dead...... i bought my t78 used and iv had it for 6 years never given me a single problem tho it is old school and their are better turbos out on the market.
    ill be upgrading this winter to a new turbo to get up with the times other then that my greddy has never let me down A+++ turbo.
    14 Mustang
    14 Explorer XLT
    96 RHD Supra hardtop built 3.0
  17. #16
    Join Date
    Jan 2009
    Location
    Central NJ
    Posts
    1,211
    Quote Originally Posted by Wreckless View Post
    Didn't see the date .
  18. #17
    Join Date
    Nov 2002
    Location
    South Florida
    Posts
    1,985
    Jeff, what do you think of the smaller Mitsu turbos vs Garrett, like 14b,16g vs the Gtxxxr turbos. I cant find proof that one spools better than the other.
  19. #18
    SupraForums Member
    Join Date
    May 2005
    Location
    Dirty South.
    Posts
    322
    i have a few T78 turbos and they are soild performers.
    also ran duel ball bearing turbos before and they are pretty kick ass but personally i dont think as solid as the t78,
    duel bb developed more than normal shaft play after only a few thousand miles.... might just be a special case in my application.
    t78 right now with lots of two step and seems to be doing ok.
    the lag isnt really that much of an issue. just make sure you are in the right gear and the lag is not toooo bad... or maybe im just used to it :P
    "do sex to me"
  20. #19
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,007
    I've played with some DSM stuff, having installed a couple of 16G's and the like into 1G DSM's but my experience ends there. I have no apples-to-apples knowledge comparing them to other turbos.
    Same thing really applies though - they are proven turbos and just because there's newer stuff out there doesn't mean the old stuff quit working. There are a ton of variables in turbo configurations that small, so it'd be hard to even make a fair comparison.
    If you're looking for ultimate spool, though, I'm sure that new generation Billet offerings from Precision & other makers for similar HP targets would spool faster than those OG Mitsubishi counterparts by a significant margin.
    Whether or not they will stand the test of time and prove reliable for 100k + miles of abuse like a lot of those old 14B's and 16G's remains to be seen.
  21. #20
    SupraForums Member
    Join Date
    Oct 2009
    Location
    Chicago
    Posts
    341
    GT47-88 all tha way
    1jz NO Shit!!!!!
  22. #21
    im a fan of the billet 6765 precision and the gt40r garret......but im also a fan of quick spooling and use a 67mm precision on my car full boost at 3600 rpm at 19psi
    :( no pics yet
  23. #22
    Dewayne bb6 -2- MKIV's Avatar
    Join Date
    Apr 2008
    Location
    El Dorado, Arkansas
    Age
    34
    Posts
    561
    i got a polish t88 -34d in my bedroom right now..
    Just trying to decide if it is worth installing..
    94 BPU Baltic Blue - Sold
    98 Quicksilver Hardtop - Current
    Click here to enlarge Originally Posted by slither Click here to enlarge
    The 7 p's should be seared into the brain of anyone who gets a mkiv, period!
    Prior Proper Planning Prevents Piss Poor Performance
  24. #23
    Turbo Guy Smokey Mike-ata's Avatar
    Join Date
    May 2006
    Location
    Barrow, Alaska (Currently in SoCal)
    Age
    32
    Posts
    532
    I've been checking up on garrett for years. I've spoken as well with Ron Lummus when after he stopped drag racing VWs. At the time he said they're switching to the mustang from the sunfire he had and they're gonna use their new GT series turbos. From what I've noticed, they're very active with their turbocharger development. They always have new releases and have a large variety of turbochargers. I think they have alot of money for R&D, plus being owned by Honeywell, talk about a fat wallet.
    Is Greddy more catered to turbos for production cars?
    I admire the fact that Garrett is very concentrated in turbochargers.
    Heres what I know about turbo innovations ... Journal Bearing then comes Ball Bearing (double, triple etc ) then Billet Wheel is the hottest trend for recent turbos. I like the Billet, the structural integrity of the impeller is increased and the center of the turbo is much skinnier allowing for more air to flow. (I'm excluding actual Twin-Scroll and Variable Vane Turbochargers, variable turbos using a sealed oil within the bearing housing. I rarely hear about these being used)
  25. #24
    1002hp denim blue beast justanmk4's Avatar
    Join Date
    Nov 2009
    Location
    krazy kali
    Posts
    1,271
    i will stick with garret turbo any day of the week,one of the best turbo around
  26. #25
    Wheel Fitment Guru
    Join Date
    Nov 2007
    Location
    Up here
    Posts
    3,643
    Quote Originally Posted by justanmk4 View Post
    That’s a pretty bold statement.
    R.K.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Replies: 110
    Last Post: 03-30-2005, 09:06 PM
  2. HorsePowerFreaks intercooler vs Greddy 3 row
    By magicsupra721 in forum Shops & Part Reviews
    Last Post: 01-15-2005, 06:31 PM
  3. Greddy Product Supprt - Turbo Kits
    By fencekey in forum MVP Motorsports, Inc.
    Last Post: 12-10-2004, 12:15 PM
  4. Greddy install!!
    By Michael90T in forum MKIII (1986.5-1992)
    Last Post: 11-24-2002, 05:48 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
