Hi:
I have a general technical question for the professionals (like suprasport):
How do you guys calculate the right compression rate for a car that is being introduced to a turbocharge system. Like if I had a s2000 with compression ratio or 11.0:1 (that's stock), and I want to add a Garrett T-04 in it with compression inducer of 40mm, what should the new compression ratio be? What are all the littles things that goes into calculating the compression ratio? I just want to learn more about turbos and how they effect the engines. Thx for all your help!!!
What are stuff should I also change other than:
1. Exhaust system
2. Fuel injection
... to make the car better?
Thx
Ricky Cheung![]()
