Single Turbo Setup
+ Reply to Thread
Results 1 to 17 of 17
Thread: Single Turbo Setup
  1. #1
    SupraForums Member Michael Jones's Avatar
    Join Date
    Mar 2004
    Location
    Tyler, Texas
    Age
    37
    Posts
    313
    Single Turbo Setup
    Something I have always wanted to see as a sticky on here is pics of different single turbo setups for the 1jz, how they ran the intercooler pipes on each one, the spool up rpm of each, power band, and a cost comparison. Now that I have decided to go single, this would really help me make my decision
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Join Date
    Mar 2004
    Location
    Tyler, Texas
    Age
    37
    Posts
    313
    Does anyone have any pics of their single turbo setup???
  4. #3
    SupraForums Member iwantamk3's Avatar
    Join Date
    May 2006
    Location
    CA
    Age
    29
    Posts
    184
    this is mine. its not running yet so i cant tell you when it spools or the powerband. how much hp are you going to go for?
    90 supra turbo-1jz t67 microtech 44mm wastegate 255lph walbro fuel pump 550cc injectors Aeromotice FPR 3" turbo back exhaust Custom FMIC Tial BOV
    2000 miata:stock
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    MK3 Owner For Life zoonwen's Avatar
    Join Date
    Oct 2004
    Location
    Lake Dallas
    Age
    35
    Posts
    1,822
    Here is a pic of my brothers setup
    Click here to enlarge
  7. #5
    Join Date
    Oct 2008
    Location
    USA
    Posts
    46
    What exhaust manifolds are you guys using?
  8. #6
    SONICSUPRA IS BACK!! 86_sports_1jz's Avatar
    Join Date
    Aug 2006
    Location
    OK
    Age
    32
    Posts
    1,287
    Quote Originally Posted by Michael Jones View Post
    i don't have any current pics of my set up but i'm using the drewgo manifold with a pt70 (.81 a/r hotside, .75 a/r coldside), hks knock off 50mm wastegate, 4 inch dp and exhuast, an ebay ic (core is 18x12x3) and 2.5 inch ic piping. as of right now the ic piping is ran across the top of the motor but i'm about to upgrade the ic and ic piping and change the way the ic piping is ran. my turbo has a short powerband but it pulls hard during that short time, it fully spools around 52-5300 rpms at 19-20 psi (redline stock). so i have like a 2000 rpms of fully spool time. it probably cost me around 2300 for my turbo setup.
  9. #7
    Join Date
    Oct 2008
    Location
    USA
    Posts
    46
    Why are you spooling so late?
  10. #8
    SupraForums Member
    Join Date
    Dec 2007
    Location
    NC
    Age
    38
    Posts
    198
    Quote Originally Posted by OEM Turbo View Post
    cause he has a big a** turbo...i would guess...maybe a little more tune can help, but with a turbo that size it's a given...which is ok with me
    1988 starion (18g, FMIC, 2.5 exhaust 15psi)
    1988 Mightymax (4g63T swapped, 4.11 gears, 2500lbs)
    1974 Nissan 260z (1jz swap, 62-1, 3in exhaust..etc)http://www.youtube.com/watch?v=g7OSF...e=channel_page
    2000 Lexus ES300 (Daily Driver)
    Real hip-hop http://www.youtube.com/watch?v=nB6ue...eature=related
  11. #9
    JZ POWERED 91turbosupra's Avatar
    Join Date
    Apr 2005
    Location
    ny to ct
    Age
    30
    Posts
    649
    heres mine
    i got a 1jz with a gt 40
    87 1.5jz single GREDDY T78
    91 2jz 74gts 400whp @16psi *sold*
    05 evo 8 bpu 13.0@108mph
    tuned by BD Performance
  12. #10
    ma70-7m=1JZ becauseican's Avatar
    Join Date
    Jan 2002
    Location
    B.C Canada
    Posts
    2,892
    My setup, DBBT61, .58 turbine, P trim, Haltech E11v2 EMS, 720cc injectors, 3.5" exhaust....423 whp at 17 psi. I love this turbo it is the most responsive single that I have driven on a 1j, boost at any rpm once the gas pedal hits the floor, and full boost at about 3700 rpms. For a 500-600 HP turbo I wouldnt use anything else!!!
    I logged some driving with the Haltech a few weeks ago, the car was making boost at 600 rpms, driving up my driveway!!!
    I recently tuned a 1j with a T67 (.68 a/r) with a Microtech EMS, it was very laggy 5300 ish for full spool, but it did pull very hard, even at 10-15 psi. We have a swap in the shop now that will be running a GT35R on the 1J, I think it will be similar to my T61...we will see.
    1jz, BW 88-75, Haltech Sport 2000, 3.5" BIC Thunder exhaust, OS Giken twin plate. 605 RWHP 550 TQSOLD
    bicperformance.com
    JZ swap specialist
    Tuned by Bill
  13. #11
    Join Date
    Aug 2006
    Location
    OK
    Age
    32
    Posts
    1,287
    my turbo spools late because it is a bigger turbo with a larger a/r on the hotside and i'm running 19-20 psi of boost. as of right now i'm on a crappy street tune with a safcII, i plan on getting an ems in the next couple of months before new years so we will see how that goes. if you want to watch a vid of my car check the link below.
  14. #12
    Poopra King pituala's Avatar
    Join Date
    Jan 2005
    Location
    Ft. Lauderdale
    Age
    44
    Posts
    2,239
    '85 Supra P-Type 1JZ PT6262A
    557rwhp/449rwtq @ 25psi w/93 octane HESS
  15. #13
    SupraForums Member aowe501's Avatar
    Join Date
    Mar 2003
    Location
    Sunshine State
    Posts
    432
    Here is mine. Too many mods to list. Does put down 500 rwhp at 18psi.
    1989 1JZ-GTE 5spd Supra
    Built Motor 2.5 L //EMS Standalone -Too Many Mods To List
    573 rwhp//485trq @ 24 psi on 93 octane
    2008 Lexus LS 460
    2010 Lexus GX 460
    2011 Scion XB
  16. #14
    Join Date
    Jan 2005
    Location
    Ft. Lauderdale
    Age
    44
    Posts
    2,239
    Very nice!!!
  17. #15
    going broke fast tsuper92's Avatar
    Join Date
    Jan 2005
    Location
    somerset,ma
    Age
    46
    Posts
    2,401
    this is when i first started doing my single.it's an ebay china mani
    precision t61 which needed an elbow welded to the compressor and a spacer under the turbo for clearance
    a couple of pic's after it was done
    this turbo spooled nice,till i through cam's in it.it was running really rich down low.it was only on the stock ecu with safc and never really tuned
    i ended up swapping a 2j into my car and used the same turbo.the 2j didn't like the turbo's little .58a/r hotside.it hit fuel cut everytime you stepped on it(1bar)
    a pic with my new gt40 bolted to it.this turbo has a .96 a/r on the exhaust side,time to lag.i'm waiting on a cast alumnum elbow to weld onto the compressor cover.it's pretty tight space,hope it fit's
  18. #16
    Look, Its a hat! Jayhall's Avatar
    Join Date
    May 2005
    Location
    Surrey BC
    Age
    32
    Posts
    1,520
    SP67GT .80a/r, Microtech. Im using an Ebay manifold. The mani had to be bent in about an inch to clear the frame rail, and i had to get solid motor mounts to fit my tial wastegate, as it would not clear the stock motor mounts (well, the ones i had atleast) As for Intercooler pipes, I have a modified version of BIC's 1J 2.5" Pipes for the stock twins, but as i said, slightly modified to accomidate the single. Im bulding boost around 3500-3700, and dont usually go much past 6200.
  19. #17
    Toyota Street Pilot 2.5TSoarer's Avatar
    Join Date
    Oct 2003
    Location
    Tampa, Fl
    Age
    41
    Posts
    263
    Quote Originally Posted by Jayhall View Post
    Me loves your setup !
    here is mine
    Built Not Bought
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
