targa top leaking
+ Reply to Thread
Results 1 to 15 of 15
Thread: targa top leaking
  1. #1
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
    targa top leaking
    my targa top was leaking like a siv, so i replaced all the seals. most of the leaks have stopped but it still leaks at the corners of the targa top and on the passanger side there is a actual gap at the rear corner of the passanger side window. do all the targa tops leak like this or is there something i can do to fix it.
    any help would be sweet
    thanks
    nick
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member joeBPUsupra's Avatar
    Join Date
    May 2008
    Location
    fayetteville,nc/ Germany
    Age
    31
    Posts
    1,187
    sometimes its just the way you tighten them up. Mine use to leak at the front driver side corner but then I changed the sequence in which I tightened them and it hasnt leaked since. Hope that helped
    Click here to enlarge
    Joe
    97 MKIV 6spd Black APU GT42R 7275 CEA(My car) FOR SALE
    97 MKIV 6spd Green BPU+ (Wifes old car)SOLD
    04 Evo Silver (Wifes NEW car)
    98 Expedition (Family car)
    FIGHT ME ON http://joebpusupra.mybrute.com
  4. #3
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
    no ive tried tightening the targa different ways and it doesnt make a differance. do all the targas just leak?. i really want to fix this problem before i put the interior back together cause everything is new and i dont want to ruin it.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Feb 2008
    Location
    Louisiana
    Posts
    229
    My 95 has 114k and doesn't leak even in the worst rainstorm. I'm probably jinxing myself but did want to let you know it wasn't universal. Sorry though, I can't tell you how to solve your problem.
  7. #5
    SupraForums Member
    Join Date
    Feb 2003
    Location
    Pensacola, FL / Jackson, MS
    Age
    29
    Posts
    514
    i've never had a leak on my 93 or my 94 but i have seen some problems with the drain lines getting clogged. I believe mkiv.com has an article about checking and cleaning them
  8. #6
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
    ya i already replace the drain lines and resealed them. the problem is were the targa top seal meets the the front and rear seals of the car at the pass and driverside windows. there is a gap between everything. is there any way to adjust the windows so they are pushed more inward to make a tigher seal?
  9. #7
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
  10. #8
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
  11. #9
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
  12. #10
    SupraForums Member crazyone2044's Avatar
    Join Date
    Nov 2003
    Location
    Orange County
    Age
    34
    Posts
    838
    Try using some vaseline on the seals. It will make it a bit softer and stop most of the small leaks. This is the only thing that helped when i had 300zx with T tops.
    PoWeReD by EbAy
  13. #11
    SupraForums Member neloner's Avatar
    Join Date
    Mar 2009
    Location
    honeoye falls ny
    Posts
    421
    i have absolutely no leaks on mine, i condition them a few timea year and rub them down with a product thats supposed to condition rubber seals and such, must be working because they look good and perform well
  14. #12
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    67
    Posts
    13,531
    If you look in the factory shop manual, you'll see a procedure for "jacking" the windows in various directions with these cam-sort-of-things inside the door. If those are not adjusted properly, the window doesn't push against the seal the way it was intended. Since you have that gap, it sure sounds to me like that's the problem.
    Nick 95 6sp
    Twin Garrett GT2860's w/TiAL exhaust housings, WG's and BOV's, on V-band moded HKS twin manifolds, AEM v2, AEM WB, ID1000's,
    AEM meth/water spray kit, GSC S1 cams, ported head Ferrea valvetrain, +0.020" CP pistons w/crown & skirt coatings, Carrillo H-beams,
    OS Giken triple clutch & Super Lock LSD, Racelogic TC, TRD gen2 catback
    street wheels: Veilside EvoV 9-1/2"F X 10-1/2"R with 265/35F & 285/35R NT05's
    track wheels: CCW LM5 10"F X 11-1/2"R with 285/30F & 315/30R R888's
  15. #13
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
    nick yea i talk to my shop forman today and asked him about that and he said the same thing too. im gonna try that and see what happens but the only thing is i dont have the shop manual. hopefully that works cause im getting sick of stairing my car and not driving it. does anyone have any links or something for the shop manual?
    thanks
    nick
  16. #14
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    67
    Posts
    13,531
    you can find most sections, including that one at Stu Hagen's site: http://www.97supraturbo.com/Tech.html ...thanks, Stu.
  17. #15
    Toyota Hybrid Tech
    Join Date
    May 2007
    Location
    c
    Posts
    803
    thanks man i hope this will fix it
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
